2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Mar 9, 2019 at 12:10 PM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    LOL, hey I figured I would throw it out there. I am very careful to not touch the painted surfaces with my nasty hands when doing anything with brake fluid.
    That's pretty much it. It doesn't flow that fast, maybe 2-3 drips per second with the bleeder open. Just let it go for 5-10 minutes and the close the bleeder and make sure the reservoir stays topped off.
  2. Mar 9, 2019 at 12:11 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    For whatever reason, modern stuff isn't as bad as it use to be. I've had DOT4 leak all over my bike fairing for over a week and there is not a mark.
  3. Mar 9, 2019 at 12:18 PM
    JARStacoma
    JARStacoma Well-Known Member
    Alaska
    17' inferno TRD OR MT
    Thanks! Excited about the delete. I’ll move my other q’s over to that thread.
  4. Mar 9, 2019 at 12:34 PM
    Shellshock
    Iowa
    I just shoved a pair of needle nose pliers in the end and stretched it a bit. It contracted and sealed perfect around the bleeder
    tonered likes this.
  5. Mar 9, 2019 at 12:38 PM
    iexc
    iexc WerXED BH2.0 AD
    Kalede
    Toronto
    2023 TRD Sport MT
    So I unplugged the upper sensor on the clutch peddle to see if it would eliminate the lag in in the throttle response,no go!
    However I did discover that once the truck is moving as slow as 2mph the lag is present.
    BallsDeep09 and MOC221_ like this.
  6. Mar 9, 2019 at 12:42 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Yes but, that upper switch might be open when the clutch is all the way out. Did you get the good ol meter out?
  7. Mar 9, 2019 at 12:56 PM
    iexc
    Kalede
    Toronto
    2023 TRD Sport MT
    It doe
    by bypassing the sensor i got that snappy throttle clutch in or out. Went for a boot and found that all it did was made the rev hang worse.
    Put it all back and did some more tests and found it was speed related.
    I don’t understand why Toyota would have a snappy throttle when your stopped and not moving.
    Possibly for an initial thrust:confused:
    MOC221_[QUOTED] likes this.
  8. Mar 9, 2019 at 1:00 PM
    MOC221_
    Frank
    Interesting. I suspected this about that switch when stopped, as you can push the clutch in just a little bit (not enough to disengage) and the response will be just as snappy as when it's to the floor. This rules out anyone thinking it's extra mechanical load from the trans slowing things down.
    iexc[QUOTED] likes this.
  9. Mar 9, 2019 at 1:02 PM
    MOC221_
    Frank
    BTW, Mat also said there's a map for Neutral in our M/T trucks....
    tonered and iexc like this.
  10. Mar 9, 2019 at 1:06 PM
    lapoltba
    CT - 06076
    Maybe it's for making your dongle bigger at stop lights.... It probably just revs faster, hangs longer, and makes more noise. :rofl:
  11. Mar 9, 2019 at 1:09 PM
    MOC221_
    Frank
    CLINKY!
    :cheers:
  12. Mar 9, 2019 at 1:11 PM
    iexc
    Kalede
    Toronto
    2023 TRD Sport MT
    I think it’s more like cutting emissions by like .0000000000000000000000001%
    02Duck, pinochle and Shellshock like this.
  13. Mar 11, 2019 at 2:39 PM
    TD90S
    TD90S Cool as a cucumber in a bowl of hot sauce
    GA
    ‘18 TRDOR 6MT
    I’ve often wondered how mid grade fuels sell. My thoughts are most go cheep or to the highest octane, with mid grade the fuel could be old.
  14. Mar 11, 2019 at 2:42 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    AFAIK, mid grade is mixed at the pump by blending regular and premium? It shouldn't be any older than either of the other fuels.
    TD90S[QUOTED] likes this.
  15. Mar 11, 2019 at 2:48 PM
    TD90S
    GA
    ‘18 TRDOR 6MT
    Learned something today!
    tonered[QUOTED] likes this.
  16. Mar 11, 2019 at 6:21 PM
    charlieyankee88
    charlieyankee88 Well-Known Member
    2017 TRD OR DCSB MT
    RADFLO Suspension, JBA HD UCAs, Mobtown low pro bumper, Mobtown bolt-on sliders, Engo SR10s, SCS Stealth 6, AFE CAI, URD Spec U, OV Tuned, Gobi Rack, Softopper, CMC
    Why not flash to 93 FOB if you are going to be running 93 fuel?
  17. Mar 12, 2019 at 12:34 AM
    Tharris242
    Tharris242 Technically
    Houston, TX
    2017 TRDOR DCSB 4X4 A/T FP TO BL
    Solid Fold 2.0, Air Dam
    I'm told it is mixed when it is pumped into the tanker at the truck rack.
  18. Mar 12, 2019 at 5:20 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks!
    @Tharris242
    My info in the previous post was from a while back. I just did some googling and it confirmed mixing at the pump:
    https://www.google.com/search?q=is+....69i57j0l4.12191j0j7&sourceid=chrome&ie=UTF-8
    There are a lot of sources there, but none that I would consider definitive other than BITOG. Although, that discussion didn't go in the direction that I had hoped.
  19. Mar 12, 2019 at 7:33 AM
    charlieyankee88
    2017 TRD OR DCSB MT
    Hmm. I may try this. I am in DE not sure on the quality of the gas.
  20. Mar 12, 2019 at 7:34 AM
    Shellshock
    Iowa
    Yup. I run the 87 tune and higher fuels if I can find it. Even on the stock tune, the truck likes 91+
Thread Status:
