2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Mar 13, 2019 at 4:01 PM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    @OVTune
    Stupid question but replacing my battery wouldnt default my ECU back to a factory tune would it?
  2. Mar 13, 2019 at 5:00 PM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    No,the OVTune overwrites the factory tune,at best you cleared learned values and may notice some odd behavior until it "relearns" trims.
    VangaSTL[QUOTED] likes this.
  3. Mar 13, 2019 at 5:18 PM
    M1Awolf
    Rob
    Montana
    It finally warmed up enough to dry out the roads a bit and I was able to go play with the Torque app for the first time. For reference truck has 265/75/16 E tires,sliders bumpers/winch/gear 5200# est.
    DISCLAIMER Testing was done on a lonely county road right where pavement turns to gravel,zero traffic and seat belt was worn ;)
    It's no speed demon but it pulls hard all the way to 7k....:burnrubber:
    tonered and orangeracer like this.
  4. Mar 13, 2019 at 8:20 PM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Keep in mind that not all reviews will be up to date and reflect the current iteration of the tune (1.05B). For example, I posted when on 1.03 and updated it when on 1.04A I think (?) and that was late spring/early summer I think. I never updated my post after that. I doubt others did either
  5. Mar 13, 2019 at 8:26 PM
    mZiggy
    mZiggy Honey badger
    Marc
    In addition, it's a little unreasonable to ask for just quantitative data over word of mouth, since that means you can basically only go off of what Mat says and posts with regards to hard numbers from Dyno runs, and no one/nothing else. Which means you should actually ignore the review thread. So if purely quantitative data is all you're after, you'll be severely limiting yourself since even people's reports of fuel economy and whatever else shouldn't be included in your compilation of data, due to differences in driving styles, mods, and just the plain finnicky behavior each individual truck clearly displays.
    TL;DR is that you're doing yourself a disservice by searching for an extremely small pool of information to base your decision off of: to buy or not to buy.
    Ruggybuggy and GF8er like this.
  6. Mar 13, 2019 at 10:35 PM
    BearWithMe
    BearWithMe Well-Known Member
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    I just got OVtune a few weeks ago and had been driving on the 87 FOB for the first two and thought it was a nice upgrade from stock, but the throttle mapping was too twitchy, mainly when on trailing throttle down hills -- just breathe on the gas pedal and you're accelerating when I meant to just maintain a constant speed. The last week or so I've been on the 91 FOB tune and it seems much less twitchy.
  7. Mar 13, 2019 at 10:37 PM
    Shellshock
    Iowa
    I thought it was twitchy at first. Now that I’ve got a few hundred miles on it, it doesn’t bother me. Not sure if it settled down a little or I just got used to it.
    Melmantaco likes this.
  8. Mar 14, 2019 at 6:19 AM
    MT-TACO
    MT-TACO Well-Known Member
    Edward
    3rd-Gen
    Can some one tell me what the diff with the FOB & Performance ?
    i did the 1.05B whe is was first out !
    I notice NOW that we can pix options
  9. Mar 14, 2019 at 6:30 AM
    nxcess
    nxcess Well-Known Member
    '17 Tacoma MT 4x4
    OVTuned
    FOB is for manual. It's a modified Full OTTO version for us. Base and FOB applies to manual. All other versions are auto.
  10. Mar 14, 2019 at 6:34 AM
    MT-TACO
    Edward
    3rd-Gen
    great thanks
  11. Mar 14, 2019 at 6:53 AM
    M1Awolf
    Rob
    Montana
    @2001 4x4
    1.05B FOB 91
    2001 4x4 likes this.
  12. Mar 14, 2019 at 7:29 AM
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
  13. Mar 14, 2019 at 8:10 AM
    M1Awolf
    Rob
    Montana
    One thing I noticed when I did my test runs yesterday,you cannot launch this truck no matter how hard you try. Dead spot from stop,it bogs terribly, would be a pita/dangerous if you were stopped and needed to GTFO of something coming your way....
  14. Mar 14, 2019 at 9:14 AM
    mZiggy
    mZiggy Honey badger
    Marc
    Disagree. You can launch it, but you'll be slipping the clutch way more than you'd like to
    fatboyfirebass likes this.
  15. Mar 14, 2019 at 9:25 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yeah, I'll be the third wheel here and respectfully disagree about both? :D
    I can't say that 8sec-ish 0 to 60 has bog or is slow and I don't feel that it takes much slip to do it.
    I'm still not sure if I want to post the vids publicly. ;)
    And, I didn't get a chance to try some while I was on FOB 87.
  16. Mar 14, 2019 at 9:26 AM
    M1Awolf
    Rob
    Montana
    I tried slipping it a bunch and still same results,instant bog. FWIW I used to do some bracket racing back in the day in the SW division. I had an 83 Z28 w/5 speed and was pretty good in the lights...
    Roddy13 likes this.
  17. Mar 14, 2019 at 9:37 AM
    Shellshock
    Iowa
    but guys! this isn't a race car! :bored:
    pinochle and Melmantaco like this.
  18. Mar 14, 2019 at 9:41 AM
    M1Awolf
    Rob
    Montana
    I know it is not a race car but the flat/dead spot is how can I say it...BAD. Say you are sitting at a light and see someone careening out of control towards you. You hit the gas and dump the clutch to get out of the way and it bogs as the truck starts moving,it is a good two,three seconds before the engine catches up to the throttle demand.
    Roddy13 likes this.
  19. Mar 14, 2019 at 9:46 AM
    Shellshock
    Iowa
    It was real bad on the stock tune on my truck, better but still existed to an extent on the tunes. I haven't tried yet with FOB since its been slick and crappy around here.
  20. Mar 14, 2019 at 10:27 AM
    M1Awolf
    Rob
    Montana
    I had it on the stock tune as well under "normal" driving conditions. Dead spot/bog/lag just off idle as you were pulling away from a stop under light/moderate acceleration. It was greatly improved with 1.03 IIRC and that was the one everyone said was too aggressive but IMHO was the best.
    It may be because my truck is heavy and likes the extra grunt/aggressive tip in... The other version that seemed to do well was the original 1.04 FO? (pre TSB FO tune), my truck really liked that one.
    Boxerocks likes this.
Thread Status:
