2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Apr 5, 2019 at 1:15 PM
    Shellshock
    Iowa
    I think different maps for the different mode makes sense (2h/4h/4l).
    tonered likes this.
  2. Apr 5, 2019 at 1:17 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    There is more free space in the MT since there isn't any shifting business, so we've got a lot of room to add things. But figuring out what to add is the question.
    What do you guys want?
    AFMurse2014 and MOC221_ like this.
  3. Apr 5, 2019 at 1:18 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    I like it!
    Although we don't have the ECT button, I'll bet u a hundred bucks the input is still there in one of the connector pins thru to the internals on the ECM.
  4. Apr 5, 2019 at 1:19 PM
    MOC221_
    Frank
    Maybe optimised "engine braking" tables (throttle angle/intake VVT etc) for 4 low?
    TD90S and tonered like this.
  5. Apr 5, 2019 at 1:22 PM
    OVTune
    OVTune
    quite possible, but it's not setup to record the PIN, place it into the ECUs RAM (memory) etc.
    MOC221_[QUOTED] likes this.
  6. Apr 5, 2019 at 1:22 PM
    Shellshock
    Iowa
    I'd want 4lo as controlled as possible (engine braking etc). More muted throttle response
    Some way to flip between towing (more power/braking) / normal driving (more economy) would be nice, whether magically or with a button combo.
    tonered likes this.
  7. Apr 5, 2019 at 1:25 PM
    OVTune
    OVTune
    I can stuff an entire new tune into the ecu when in 4Low, with ignition / vvt / throttle targets / etc
    Melmantaco, MOC221_ and tonered like this.
  8. Apr 5, 2019 at 1:26 PM
    MOC221_
    Frank
    Hmmmmmmm...
    Is this where we ask for 2WD low mode via coding? Maybe use some other input to do it.
    Transfer case shift to low range, ignoring the fol requirements
    1. Transfer case indication of 4WD mode (4H);
    2. ADD (front axle) indication of engaged.
    Edit: The ECM gets an indication of 1, then proceeds to lock up the ADD, then gets indication 2 under normal circumstances.. then you can get 4low. I'm not sure if it's mechanically possible in the T-case to shift the planetary gearset to low without engaging 4WD though... if it isn't, just allow the mode change to 4WD but don't send the ADD lock command to the front axle and also don't worry about (or fake) the feedback that it's locked.
    Boxerocks, pinochle and tonered like this.
  9. Apr 5, 2019 at 1:28 PM
    Shellshock
    Iowa
    :fingerscrossed:
  10. Apr 5, 2019 at 1:29 PM
    Shellshock
    Iowa
    Some of us do have ATRAC - you could probably tie something to that button press since it only does something in 4lo... hmm..
  11. Apr 5, 2019 at 1:34 PM
    MOC221_
    Frank
    Oh yeah... I forgot about that one.
    LOL, sorry Sport nerds :D
    nxcess likes this.
  12. Apr 5, 2019 at 1:34 PM
    Shellshock
    Iowa
    yeah we need something @tonered can't have!
    pinochle and MOC221_[QUOTED] like this.
  13. Apr 5, 2019 at 1:36 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :luvya:
    :jerkoff:
    :brianr:
    :D
  14. Apr 5, 2019 at 1:41 PM
    MOC221_
    Frank
    DO IT.
    Like @Shellshock said, give us very linear/predictable throttle in 4low without too crazy on the tip-in.
    FIX THE RETARDED ENGINE BRAKING CYCLE FOR GOD'S SAKE! It needs to be as strong as you can make it IMO.
    RedBeard1 and tonered like this.
  15. Apr 5, 2019 at 1:43 PM
    Shellshock
    Iowa
    what you dont like whiplash in 4lo? lol
    1000-2000 rpm in this truck is definitely my current biggest gripe...well and rev hang in 1/2...and lack of engine braking...
  16. Apr 5, 2019 at 2:03 PM
    Steelhead Taco
    Steelhead Taco Oncorhynchus mykiss
    Fred
    2016 OR DC SB MT
    Oh my Mat it feels like early Xmas!!
    If we can have extra torque in the 2100-2400 range for us heavy trucks it would be incredible. Button or special heavy tune... Top end is of no matter when carrying weight but the ability to get up and go is a god send! If you need a heavy truck to dyno (MT) let me kno when your in SoCal. I’m lv Louisiana headed for Texas and can expedite my arrival in Cali if you need me for the benefit of the heavies.
    Oh yes engine braking can be wildly used on heavies!
    Thx
    Fred
    Roddy13, tonered and Shellshock like this.
  17. Apr 5, 2019 at 2:46 PM
    TD90S
    TD90S Cool as a cucumber in a bowl of hot sauce
    GA
    ‘18 TRDOR 6MT
    This ^^
    But would take it one step further and add 4 Hi.
  18. Apr 5, 2019 at 2:49 PM
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    @OVTune
    Have you driven a Jeep Cherokee trail hawk? The throttle mapping in 4low is great.
    I think if you took 0-75% of the throttle and adjust it to 500-2500 rpm it would make the pedal super responsive for the manual guys going slow off road. Just an idea.
    Melmantaco likes this.
  19. Apr 5, 2019 at 3:07 PM
    offgrid taco
    offgrid taco Well-Known Member
    ned
    mass
    24 trd off road bronze oxide
    Count one more computer idiot as tuned. It was so easy a cave man could do it, if he read the directions and watched the video. Brand new tank of 93 ready to go. It's going to be a good weekend.
    Ned
  20. Apr 5, 2019 at 3:19 PM
    Burro09
    Burro09 Well-Known Member
    Miami, FL
    2017 Tacoma TRD Pro Cement MT
    For simpletons like me, the stock tune power is fine.
    Please make the throttle behavior as close as can be to a 1990 4x4 manual toyota pickup. CABLE. At least give us a full cable variation lol. Anything such as extra power, less hiccups, and improved engine braking would be icing on the cake. It is so infuriating to take off swiftly in this truck and have the revs stick and hang for what seems like 2-3 seconds when you need to shift. It completely kills the vibe, and you are left either standing on the clutch waiting for the rpm to fall close to where you need it, or you let go of the clutch and it jerks the truck or roasts clutch. Thats the only thing that would make me whip out that credit card like yesterday. Its been done with hondas, and hopefully it can be done here.
    Boxerocks, 02Duck and TD90S like this.
Thread Status:
