2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. May 18, 2019 at 8:01 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    I did say that I didnt recommend it if offroading by yourself. I was more conservative than reasonable I think. Especially with plug and play solution, I would recommend for anyone.
    More write up here https://www.tacomaworld.com/threads...w-3rd-gen-diy-mod.536677/page-8#post-20652705
    Adding DPDT switches to give actuator overrides would make it more reliable than stock (in my opinion)
    tonered likes this.
  2. May 20, 2019 at 1:21 PM
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
  3. May 20, 2019 at 1:26 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    ?? :D
    Did you just flash?
    0uTkAsT likes this.
  4. May 20, 2019 at 1:56 PM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    Uh huh... :)
    A first gear that does something? A second gear I can actually roll through stops with? Some semblance of engine braking?
    Are these tears of joy? or madness? or just the wind tearing at my ducts?
    iexc, pinochle, Shellshock and 3 others like this.
  5. May 20, 2019 at 1:57 PM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    How accurate have folks found the voltage reading on the p5flash tool? It had my battery voltage at around 12V for some reason, which would be a bittersweet end to my day if my battery is going bad...
  6. May 20, 2019 at 1:57 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Nice! I'm glad that you are digging it.
    Just wait until you realize that you can completely forget about the throttle and just drive and drive.
  7. May 20, 2019 at 2:00 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    From what I have seen, USB can sometimes underreport voltage. That said, 12v is going to be normal when you are sitting with the ignition on and is what I see when flashing. ECUs will cut out in the low-10s.
    You can check it with a multimeter on the battery posts.
  8. May 20, 2019 at 2:02 PM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    Yeah just didn't want to dig through my packed up stuff to find the multimeter. That's good to know that 12V is normal for that situation. Was worried as I'm used to reading 12.4+ on a good battery, but have never tried reading through OBDII/USB.
    tonered[QUOTED] likes this.
  9. May 20, 2019 at 2:04 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I have an Italian bike, it lives out in the open. :rofl::rofl:
    Torque will show the commanded and adapter voltages, since we have an ECU controlled regulator. Fusion can probably do the same.
  10. May 20, 2019 at 2:05 PM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    I haven't gotten out of 2nd yet, but that's exactly how it started to feel. Finally a throttle that can accurately express my intent! Looking forward to putting it through the paces this summer.
    B
    @OVTune, when you check back in with us, you've got another happy manual customer :D
    Tacoma816 and tonered[QUOTED] like this.
  11. May 20, 2019 at 2:07 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is all that we want!
    :cheers:
  12. May 20, 2019 at 2:13 PM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    I was lucky to already have the tactrix so could send in my reg info as soon as I ordered.
    I'm running 87 base to start. Dry weight is approximately 5650 lb, but can push up to 6000 fully loaded. Even with base first is pretty ON from the get go and will take some getting used to compared to the wet noodle response from 04b13. Thankfully I don't even remember how bad 04b10 was.
    I haven't done any highway driving yet or under full weight so can't tell how it'll do for me there, but my biggest issues were first and second and those feel great so far.
    Will also be interested how break-in affects things after a few tanks.
    0uTkAsT[QUOTED] and tonered like this.
  13. May 20, 2019 at 2:16 PM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    I definitely understood all the words in that sentence...I'm a software engineer, so I'm not super smart about electricity lol
  14. May 20, 2019 at 2:18 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Ha! I suck with electrons of all kinds.
  15. May 20, 2019 at 4:16 PM
    xxtavixx
    xxtavixx Well-Known Member
    Jacksonville fl
    2018 6MT
    ARB rear locker OVtune Mobtown sliders Core-shifter short throw Trd bro-phony grill Caliraised bumper light bar Caliraised ditch lights Rigid ignite back up lights FN Five Star 16x8 Et0 255/85/16 cooper st maxx MesoJDM fuse box cover MesoJDM led interior lights Bilstein 6112 fronts Bilstein 5100 rears Headstrong 3 aal Toytec 3* shims Mesjodm dome and map lights Diode dynamix ss3 pro yellow Mobtown aluminum front skid 2lo mod SOS front recovery point
    So...are 87 fob and 87 base the same tune in lower rpm?
  16. May 20, 2019 at 4:24 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    No. Very different. Give them both a try to see what you like best.
    0uTkAsT likes this.
  17. May 20, 2019 at 7:54 PM
    Kamille.bidan
    Kamille.bidan Well-Known Member
    2017 Blue TRD OR MT
    Is everyone running the 91oct tune okay? I feel like it's time to buy this
  18. May 20, 2019 at 7:59 PM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    All I have ever run is the 91 tunes,all have been an improvement over the previous version.
  19. May 20, 2019 at 8:09 PM
    BearWithMe
    BearWithMe Well-Known Member
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    So far I've tried the 87 FOB, 91 FOB, and the 87 base. The base seems to drive the smoothest, without any stumbling or surging going up hills in low gear & low RPM.
  20. May 21, 2019 at 6:11 AM
    cylon58
    cylon58 Active Member
    Geoff
    East Tennessee
    2018 TRD Pro MT Black
    I’m at the dealership for regular maintenance and they told me there is a recall on my radar sensor. Something about moisture getting in the unit. They said they have to reflash the system after the repair.
    Should I flash to stock prior to them doing the repair? Are they flashing some calibration missing from 1.05? If I flash back to 1.05 will it mess up the radar sensor?
    Anybody have any advice?
Thread Status:
