2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Dec 16, 2017 at 3:53 PM
    #1121
    su.b.rat
    su.b.rat broken truck
    from using your motor normally?
  2. Dec 16, 2017 at 3:54 PM
    #1122
    Scruffie
    Scruffie Well-Known Member
    Arsie
    Surrey B.C Canada
    2016 QuickSand Access TRD OR Manual
    265/75/16Dura,SSO Hybrid,X20,CruisinSliders,Skids
    Nope. You maybe smoked some tire rubber and maxed your rpm limiter. But you won't do squat to your clutch by cutting a u'e and punching it.
    su.b.rat likes this.
  3. Dec 16, 2017 at 4:00 PM
    #1123
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    Love the Speed3's. My buddy's car is pushing 600hp right now after he did all the engine internals and added meth on E85. It's fast as fuck.
    Ares32[QUOTED] likes this.
  4. Dec 16, 2017 at 4:03 PM
    #1124
    Toytaco2k17
    Toytaco2k17 Well-Known Member
    Kenneth
    Chapmansboro Tn
    2016 Nissan Titan XD Pro4x Diesel
    Stock
    Oh no, the pedal was to the floor. It was accelerating. When it hit about 3k where the engine starts to make power, that's when the clutch disc went up in smoke. Not tune related unless you talk about the extra power it makes. The truck seems fine though. The clutch may have lost a little bite but I bet some of its glazed a bit. It seemed to get better today driving it around normal.
  5. Dec 16, 2017 at 4:05 PM
    #1125
    Toytaco2k17
    Kenneth
    Chapmansboro Tn
    Stock
    The tires were not spinning. I know the difference in smell from rubber to the smoke boiling out of the middle of the truck
    MOC221_ likes this.
  6. Dec 16, 2017 at 4:36 PM
    #1126
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Whoa..
    That's not right (like no kidding). Free play out of whack? Contaminants on the disc/pressure plate.. like oil?
    No way this engine is roasting a new(ish) clutch that is fully engaged. Unless the damn accumulator delayed it too much.
    I find under high load conditions (taking off on a steep hill) the clutch engagement feels different (worse).
    Wow
    su.b.rat and Toytaco2k17[QUOTED] like this.
  7. Dec 16, 2017 at 4:47 PM
    #1127
    Toytaco2k17
    Kenneth
    Chapmansboro Tn
    Stock
    It was odd. I have had them burn while shifting from gear to gear. But not while rolling and then just let loose. It probably spun about 3 seconds before I realized what was happening and pressed the pedal back in. I coasted into a parking lot and let it cool down. It never slipped any after that or all day today. It did feel a little soft and less jerky.
    MOC221_ likes this.
  8. Dec 16, 2017 at 5:12 PM
    #1128
    su.b.rat
    with the stress I've put on this clutch i am extremely surprised to hear that. iI agree with Frank, something there is not right, whether there's an adjustment to make, some contaminate, maybe just a bit of a dud clutch, but that's just not something to let be. if the dealer wouldn't help me for whatever reason I'd be looking aftermarket at a minimum.
    but whatever, in a perfect world Toyota would find the issue and fix it. your clutch should be no less than a very long way from just slipping and spinning from this motor's power.
    Toytaco2k17 likes this.
  9. Dec 16, 2017 at 5:18 PM
    #1129
    Toytaco2k17
    Kenneth
    Chapmansboro Tn
    Stock
    I'm going to roll it for a few days and see how it does. I have noticed that sometimes when I let the clutch out, a few seconds later you can hear the pedal pop up a half inch or so. It is rare that it does it. I wonder if the pressure plate was not holding like normal. On my FJ, I tore the clutch disc from the center of the clutch at Windrock OHV park. That clutch never slipped one time. I beat on it all the time.
  10. Dec 16, 2017 at 5:22 PM
    #1130
    su.b.rat
    let us know how it goes.
  11. Dec 16, 2017 at 5:27 PM
    #1131
    Ares32
    Ares32 Well-Known Member
    America
    2016 MGM TRD off road DCSB M/T
    I believe it! I'm running a GT2871 on 50/50 Ethanol self tune with a Cobb Accessport. I'm nowhere near 600, little above 400 though:)
    Trident904[QUOTED] likes this.
  12. Dec 17, 2017 at 6:29 AM
    #1132
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    Ive actually experienced what @Toytaco2k17 is talking about when I took my truck to a drag strip, albeit I was launching and not cruising in gear already and stepping on it. Released the clutch in first and revs started climbing but wasn't going anywhere or making tire smoke so I let the engine wind down a bit and tried to release it again and that time it went into gear and was fine. It seems like maybe it could be an accumulator issue as some have said, or maybe it could be that the factory clutch is just not up to the task. Ive experienced a lot of clutch slip while towing as well
  13. Dec 17, 2017 at 6:40 AM
    #1133
    Ares32
    America
    Any updates for the folks running the 1.03 test tune on 04B10 @OVTune? Hows the development going? Thanks!
  14. Dec 17, 2017 at 6:50 AM
    #1134
    stevotivo12
    Stephen
    1.03 test tune has been stable and reliably awesome for me! It's consistently had more power and torque from low rpms. No development to speak of since 1.03TT dropped though
    Ares32[QUOTED] and dg108 like this.
  15. Dec 17, 2017 at 9:24 AM
    #1135
    Ares32
    America
    Oh yeah same here, just no ignition changes for us. I remember something about a ecu being ordered to figure out 04B10. Was just wondering what kind of progress was made.
    stevotivo12[QUOTED] likes this.
  16. Dec 17, 2017 at 9:45 AM
    #1136
    stevotivo12
    Stephen
    Me too! @OVTune what's good with 1.03?
  17. Dec 17, 2017 at 11:11 AM
    #1137
    Ares32
    America
    :notsure:
    stevotivo12[QUOTED] and MOC221_ like this.
  18. Dec 18, 2017 at 3:21 PM
    #1138
    tekoma
    tekoma Member
    Apex, NC
    24 Tacoma TRD Off Road Manual
    Method MR318 17x8.5 Bronze BF Goodrich KO3 285/70R17 XPEL Partial PPF XPEL 70% tint windshield XPEL 35% tint front sides
    Got my tracking number! :burnrubber:
    MOC221_ likes this.
  19. Dec 18, 2017 at 3:59 PM
    #1139
    SWPRO
    SWPRO Well-Known Member
    Jeff
    Rindge NH
    '17 Super White TRD PRO
    I have been watching and reading this thread, but I feel like I missed the ecu code differences. How do we know what one we have and what differences would the tune have?
    I have a 17 Pro.
    I apologize in advance if this is a stupid question to some. I have searched and read through this thread since it started. Not sure if I missed it?
  20. Dec 18, 2017 at 4:34 PM
    #1140
    Yzkiley
    Yzkiley Well-Known Member
    British Columbia, Canada
    2016 MGM Tacoma Sport DCSB MT
    rain guards, hood deflector, oem tonneau, BFG ko2's, led lightbar behind grill, highlift jack mount side rail, husky Xact front & rear mats, bedrug, AFE cold air intake with scoop, TB spacer, Spec U exhaust, Hikari - lumileds Led's, any time backup cam and gps, OV tune 103B, TRD pro grille, Cali raised pod fog lights, ECGS needle bearing, Bilstein 5100's, Low range offroad 3-1 level kit, SPC light racing ctrl arms, spidertraxx 1.25in spacers, Ride right airbags, clazzio seat covers, carrier bearing spacer, diff drop spacer.....
    Got mine too, today... Yamon :woot:
Thread Status:
