2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Jul 12, 2019 at 7:04 PM
    Foozer
    Foozer Well-Known Member
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    So it's way better, that's what you mean?
    CygnusX191 likes this.
  2. Jul 12, 2019 at 7:17 PM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Yep. I'm assuming you're MT since you are here. All around it is a serious improvement over the stock tune. I feel like it was well worth the $$ and it is far superior to how the truck was delivered from the factory. Throttle response is better, engine runs smoother (sounds happier and not like it's going to blow up $> 4k), power delivery is more consistent and better, some slight power gains on 87, and fuel mileage hasn't changed or is slightly improved.
    If you want to run the 91 or 93 tunes there is definitely more power available, and with the 2.0 version coming you won't have to worry about flashing different versions for different octanes. Torque tables (still an issue) are going to be revised in 2.0 as well as the AICS system, so that will only make things better.
    I realize you are probably on the fence but I am sure you won't be disappointed.
    CygnusX191 and tonered like this.
  3. Jul 12, 2019 at 7:46 PM
    CaptainVoodoo
    CaptainVoodoo Well-Known Member
    Charles
    Quebec
    2019 TRD Pro Voodoo Blue M/T
    None yet
    I don't even understand how you can heel-toe the way the pedals are, unless you have gigantic feet lol Sounds like someone thought he got a sport car because it had a clutch.
  4. Jul 12, 2019 at 10:11 PM
    Garab
    Garab Well-Known Member
    2018 TRD Sport MT6 DCSB
    OVtune 2.0 TRD Sema wheels 265/70/17 Falken Wildpeak AT/3 SL ADM BAKflip mx4
    The correct way of downshifting is doing it before the turn in so your drive train is settled and you can lay the power down through the turn much smoother and with more control.
  5. Jul 12, 2019 at 11:02 PM
    CaptainVoodoo
    Charles
    Quebec
    None yet
    Unless you're on a slippery road, then you don't downshift at all... Don't ask me how I know.
  6. Jul 13, 2019 at 1:11 AM
    Garab
    Well I roll around in 6th at 40 so i definitely need to downshift before making a turn or id stall it and never make it out of the turn. Isnt it safer to engine brake when its slippery?
  7. Jul 13, 2019 at 1:13 AM
    AnotherPDXTacomaGuy
    AnotherPDXTacomaGuy Member
    2018 OR White Tacoma MT
    Just speakers, wheels and plastidipped emblems
    In my state, the octanes available are 87, 89 and 92. Does it make more sense to go with the 91 or 93 tune?
  8. Jul 13, 2019 at 6:30 AM
    CaptainVoodoo
    Charles
    Quebec
    None yet
    You wouldn't be in 6th at 40 on a snow packed road but in the event you would, yes it would be safer to engine brake and then downshift, probably in 4th, maybe 3rd depending on conditions but not any lower unless you want your tires to lose grip.
  9. Jul 13, 2019 at 8:08 AM
    Garab
    I've got 4wd and experience driving in icy conditions. A little slip isnt scary or difficult to correct.
  10. Jul 13, 2019 at 8:28 AM
    CaptainVoodoo
    Charles
    Quebec
    None yet
    Where do you live? 4wd is only useful in giving you confidence to drive faster when you shouldn't. As we say around here, 4wd makes you slide further, because you are driving too fast lol
  11. Jul 13, 2019 at 9:54 AM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Ordered the tune. Should I go 87 standard or FOB?
  12. Jul 13, 2019 at 11:02 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is up to you! Try two or three tanks on each to see for yourself.
    I tried them all and am happiest on 87 FOB. But, that is just me.
  13. Jul 13, 2019 at 2:46 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Bigges problem I see is people using their brakes to turn in snow.... Gotta use the gas ever so lightly and let the 4wd do its job.
    pinochle likes this.
  14. Jul 13, 2019 at 6:12 PM
    Jon760
    Jon760 Well-Known Member
    2016 TRD Sport 4x4 MT
    265/70 R17 Nitto Terra Grappler G2 on TRD Pro wheels BAMF Grill
    Me likely 87 base
  15. Jul 13, 2019 at 6:14 PM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Is there a noticeable difference between standard and fob?
    tonered[QUOTED] likes this.
  16. Jul 13, 2019 at 6:36 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. Big torque down low.
    Shellshock likes this.
  17. Jul 13, 2019 at 7:13 PM
    Jon760
    I like 87 base better, the FOB seem to loose power in the mid range. Noticeable going up mountains
  18. Jul 13, 2019 at 8:08 PM
    BearWithMe
    BearWithMe Well-Known Member
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    Running 87 base here; the FOB 87 and 91 both stumble at low RPM / high load.
    Foozer likes this.
  19. Jul 14, 2019 at 1:28 AM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    I'll probably try 87 base and see how it goes. Hoping its noticeably better than stock.
  20. Jul 14, 2019 at 6:58 AM
    venezian
    venezian Well-Known Member
    Los Angeles
    2022 7545E
    I will be putting my MT TRD OR on market in a few months. I'd like to keep it but life happens. I babied the shit out of it.
    Tacoma816, CygnusX191 and tonered like this.
Thread Status:
