2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Jul 26, 2019 at 11:56 AM
    su.b.rat
    su.b.rat broken truck
    should be good. i didn't get a clean assessment of the catless tubes due to an exhaust leak. but the sound wasn't quite right even looking past that on my exhaust, it was too metallic and raspy for sure, but that's what you expect from a full cat removal on this kind of exhaust.
    i'm sure he'll have some versions for 2.0. all i can say now is your regular 2.0 file is the fat kid tune you're looking for. it's much more than the previous fat kid tune (BFO 1.05 93).
    0uTkAsT, M1Awolf[QUOTED] and tonered like this.
  2. Jul 26, 2019 at 12:21 PM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    2001 4x4, CygnusX191, Burro09 and 2 others like this.
  3. Jul 26, 2019 at 12:23 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Holy shit-snacks!
  4. Jul 26, 2019 at 5:28 PM
    basshole
    basshole Well-Known Member
    chicagoland
    2018 OR MT
    What issues? What tune?
    87fob still going strong after a few hundred miles past couple weeks. It will still buck here and there, but even with the stock tune, I blame myself for loading it up at low rpm without using enough clutch.. Say rolling a stop sign.
    CygnusX191 and Shellshock like this.
  5. Jul 26, 2019 at 5:33 PM
    basshole
    chicagoland
    2018 OR MT
  6. Jul 27, 2019 at 5:53 AM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    I second that. I also have a camping trip coming up in Sept to the Rockies for three weeks and pull a 4800lbs TT. I need all I can get out of my 3.5.
    CygnusX191 likes this.
  7. Jul 27, 2019 at 9:06 AM
    M1Awolf
    Rob
    Montana
    Only the one going through the mud puddle.
  8. Jul 27, 2019 at 2:02 PM
    Kamille.bidan
    Kamille.bidan Well-Known Member
    2017 Blue TRD OR MT
    i ordered mine more than a week ago. how long is the usual fulfillment time?
  9. Jul 27, 2019 at 2:59 PM
    su.b.rat
    just remember Mercury is still in retrograde, folks. stay safe now.
    :turtleride:
    Shellshock and tonered like this.
  10. Jul 27, 2019 at 9:27 PM
    Foozer
    Foozer Well-Known Member
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    This comment was very helpful..
  11. Jul 29, 2019 at 1:03 AM
    92ehatch
    92ehatch Well-Known Member
    Kinley
    Hendersonville NC
    2019 Cavalry Blue DC TRD OR 6MT
    Guys who have this, does it help with how the truck reacts from a dead stop?
    It seems to me that the truck bogs down at every take off and it drives me nuts. On flat ground it's not an issue, but on hills it seems the more throttle you give while letting the clutch out, the worse it bogs down.
    Also, when trying to pull out on a busy road, if you are too aggressive it seems to throw out the middle finger and won't let you accelerate.
    I even tried a higher rpm take off, didn't dump the clutch but let it off quicker, at a red light, and it just fell on it's face.
    I have this feeling, that if i wanted to burn the tires, the truck would tell me no. (I don't want to burn the tires)
    I can drive my 87 4 runner with 22re like a dream.
    I like everything about this truck except how it takes off from a stop. I don't need fast i just need predictable. I will get to the ADM soon but this seems more like a throttle input nanny to me.
  12. Jul 29, 2019 at 1:29 AM
    Shellshock
    Iowa
    Yes. Significant improvement
    CygnusX191 and MOC221_ like this.
  13. Jul 29, 2019 at 3:17 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Yes, but - even on 1.05 BFO files the truck still doesn't like to get moving when taking off on a steep incline (just off idle). Apparently 2.0 solves this :fingerscrossed:
    0uTkAsT and Melmantaco like this.
  14. Jul 29, 2019 at 9:09 AM
    basshole
    chicagoland
    2018 OR MT
    87FOB tune has been great for me this past couple weeks and 600miles. Better response off the line, it doesn't fall flat. But I'm used to working the clutch (no ADM)
    I'm really enjoying the better response off of idle. Better mpg and easier to cruise at low speeds in 5th & 6th
  15. Jul 29, 2019 at 9:45 AM
    basshole
    chicagoland
    2018 OR MT
    It has to be.. I do a lot of local driving, stop and go. But I can manipulate this truck now to the point where im in 5th gear at 25mph city roads cruising. My average mpg (computer calculation) with mixed driving has been 19-20mpg.
  16. Jul 29, 2019 at 9:59 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Few questions here, most probably answered before but.....I live in Utah, a higher elevation state so they only sell 85,88 and 91octane at 99% of the gas stations here. Will that affect my tune at all, being its for 87/93? Also, I plan on probably using an older MacBook Pro with bootcamp on it to flash, will that cause any issues? I know it said not to use a VM but I couldn't find anything on Matt's site about using bootcamp.
    And my last question..I have a ShiftSensePro , do people still run that even after the tune? I'm debating if I should sell it to help cover the cost of the tune.
    EDIT: Just realized this is for the manual trucks. Meant to post in the automatic thread.
  17. Jul 29, 2019 at 10:06 AM
    Shellshock
    Iowa
    just run a higher octane than the tune. 85 is *generally* fine with the 87 tune as you are at elevation. My truck has always liked higher octane even from the factory on the stock tune FWIW
    Use bootcamp. works just fine
    shift sense pro isnt recommended to use with the tune or necessary as mat is adjusting shit points.
  18. Jul 29, 2019 at 10:09 AM
    MOC221_
    Frank
    My shit points are fine. Quite regular. No adjustment necessary. :poking:
  19. Jul 29, 2019 at 10:15 AM
    Shellshock
    Iowa
    :rofl::rofl::rofl::rofl::rofl:
  20. Jul 29, 2019 at 10:42 AM
    MOC221_
    Frank
    ...... and this is what happens when the M/T crowd is edged too long.
    pinochle, 0uTkAsT[QUOTED] and tonered like this.
Thread Status:
