2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Sep 23, 2019 at 5:58 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Gratzie!
  2. Sep 23, 2019 at 5:59 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It's back now! @lapoltba has put it all in one link.
    :cheers:
  3. Sep 23, 2019 at 6:09 PM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Yes sir. I archive the most useful stuff (useless acording the the wife sometimes). It's the same config file. Honestly, the more different places it is posted the better.
    tonered likes this.
  4. Sep 23, 2019 at 6:13 PM
    Taco16LB
    Taco16LB Well-Known Member
    found it on post 3292
    Mar 14, 2018 at 7:15 PM
    #3292
    OVTune [OP] Well-Known Member
    Start a Conversation
    OVTune
    one sec I will post the list of stuff to select,
    Vehicle Speed
    Engine Speed
    Calculate Load
    Vehicle Load
    Mass Air Flow Sensor
    Coolant Temperature
    Intake Air Temperature
    Battery Voltage
    Accelerator Position
    Throttle Request Position
    Throttle Sensor Position
    Throttle Position Command
    Throttle Position Sensor Open Position No.1
    Throttle Position
    Target Fuel Pressure (High)
    Target Fuel Pressure (Low)
    Fuel Pressure (Low)
    Fuel Pump Control Duty Ratio
    Injector Cylinder #1 (Port)
    Injection Volume Cylinder #1
    Injection Volume
    High Pressure Fuel Pump Duty Ratio (D4)
    Injection Mode
    Injection Switching Status
    Injection Timing Cylinder #1 (D4)
    Injection Time Cylinder #1 (D4)
    Target Air-Fuel Ratio
    A/F (O2) Lambda Sensor B1S1
    A/F (O2) Lambda Sensor B2S1
    Short FT B1S1
    Short FT B2S1
    Long FT B1S1
    Long FT B2S1
    Fuel System Status Bank 1
    Ignition Timing Cylinder #1
    Knock F/B Value
    Knock Correct Learn Value
    Engine Oil Temperature
    A/T Oil Temperature No.1 (if AT)
    Power Mode SW
    Lock Up Status (if AT)
    Shift Status
    Intake VVT Change Angle Bank 1
    Intake VVT Change Angle Bank 2
    Exhaust VVT Change Angle Bank 1
    Exhaust VVT Change Angle Bank 2
    Intake VVT Target Angle Bank 1
    Intake VVT Target Angle Bank 2
    Exhaust VVT Target Angle Bank 1
    Exhaust VVT Target Angle Bank 2
    Misfire count (All Cylinder)
    note, in Techstream when you are setting up the logger and you have the list setup with these items, there is an option to SAVE the list, SAVE it and rename it "Tacoma List" or "Tacoma Logging" that way you can always reselect in the future.
    Now that you have that setup and connected to the truck go to
    FUNCTION > SNAPSHOT CONFIGURE
    this will open some options for the logger
    On the bottom set the time to : 30 or 60 minutes
    the data I need is >
    start the truck on cold idle, let it sit for 2-3 minutes
    driving around how you normally would until it is up to temp
    2x full throttle pulls to at least 5000 RPM in 2nd gear or higher
    idle, hot 2-3 minutes.
    you can capture all of this in 1 single log, save the snapshot (I recommend save it to your desktop, makes it easy to find) and then email me the snapshot data. Please do not export to CSV, I will do it.
    Please do not add ANY flags.
    Does anyone know what needs to be added for an AT ?
    4low, CorbinDallas and su.b.rat like this.
  5. Sep 23, 2019 at 6:16 PM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    The enthusiasm here is outstanding, I promise, but we've made it easy for you and everyone else by sharing the custom datalog file. Just import it into Techstream and then select it when about to datalog and you're set
  6. Sep 23, 2019 at 6:18 PM
    mZiggy
    mZiggy Honey badger
    Marc
    As for the AT version, it should be floating around somewhere. Or someone who uses it can export it for other AT owners' use.
  7. Sep 23, 2019 at 6:34 PM
    su.b.rat
    su.b.rat broken truck
    where please?
    tonered[QUOTED] and lapoltba like this.
  8. Sep 23, 2019 at 6:59 PM
    lapoltba
    CT - 06076
    tonered likes this.
  9. Sep 23, 2019 at 8:38 PM
    su.b.rat
    lol sorry to be 'obtuse' i was on mobile and didn't get your signature showing.
    it's one of those weeks already...
    MOC221_, tonered and CygnusX191 like this.
  10. Sep 24, 2019 at 1:05 PM
    dspec
    dspec Well-Known Member
    Can anyone please confirm that I can get my System ID before receiving the flash kit?
    Assume I download the software, install it, and get my system ID first? Or do I need the flash kit in hand first?
  11. Sep 24, 2019 at 1:08 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is exactly what you do:
    https://www.ovtuned.com/pages/instructions-downloads
    See Steps 1 and 2. You can get through Step 2 before your kit arrives and will be ready to tune immediately.
    Shellshock and CygnusX191 like this.
  12. Sep 24, 2019 at 1:09 PM
    dspec
    Thanks @tonered I'm hoping I can flash it by Friday. I'll install and setup today.
    CygnusX191 and tonered like this.
  13. Sep 24, 2019 at 1:10 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome.
    It is going to take a few days to get the REG file as that comes to OVT from the UK. The kit will take a while to arrive after it is dropped off for UPS Ground.
    CygnusX191 likes this.
  14. Sep 24, 2019 at 1:12 PM
    dspec
    It says scheduled from tomorrow from UPS out of the east coast. Hopefully that remains valid.
  15. Sep 24, 2019 at 1:14 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Ah! That is goodness. You'll just be on hold for the REG file.
    With the kit in hand, you can always install TechStream and do some customizations (turn signal flash count, seat belt chimes, etc.).
    CygnusX191 and dspec[QUOTED] like this.
  16. Sep 25, 2019 at 4:30 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    SO, it looks like the slushbox guys will be getting a new Beta this week..
    Hopefully M/T files as well.
    :tumbleweed:
    CorbinDallas and CygnusX191 like this.
  17. Sep 25, 2019 at 6:52 AM
    CorbinDallas
    CorbinDallas Well-Known Member
    Corbin
    Tacoma
    16 MT OR
    Support ticket 10288.
    Thoughts after 2 tanks of gas:
    Overall drivability has gone way up. Shifts are smooth, as others have said. The immediate power and throttle response after shifts is amazing.
    My personal MPG have gone up ~2
    As for tip-in/ throttle response. I think a VERY mild tweak would be in order. It is slightly aggressive as others have also mentioned. While not as pronounced as previous files, it does feel a touch touchy. With that, however, 5th and 6th hear have never been this good. I can actually accelerate up fairly steep canyon roads. Truly amazing.
    Overall, bar none, the best file ever.
    nxcess, MOC221_ and CygnusX191 like this.
  18. Sep 25, 2019 at 8:10 AM
    MOC221_
    Frank
    Yah yah yah.
    Uh-huh.
    yup.
    Just 04B41 over here :lalala:
    R242, 06ltd, CygnusX191 and 1 other person like this.
  19. Sep 25, 2019 at 8:19 AM
    CorbinDallas
    Corbin
    Tacoma
    16 MT OR
    :rofl::rofl:
  20. Sep 25, 2019 at 8:24 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Mah package is due to arrive Tuesday Oct 1 :kona::taco::taco::taco::taco::kona:
Thread Status:
