2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Oct 25, 2019 at 1:13 PM
    basshole
    basshole Well-Known Member
    chicagoland
    2018 OR MT
    I'm interested in the "tune on the fly" dealio. I seen with the auto the terrain switch is used. How will it be incorporated into the manual?
    CygnusX191 and tonered like this.
  2. Oct 25, 2019 at 1:15 PM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Crawl control buttons were ditched in favor of using the Cruise Control buttons.
  3. Oct 25, 2019 at 1:15 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    There's a new TSB for the clutch with new part numbers. TSB-0112-19.
    For the 10min it takes to flash the TSB tune at home, I wouldn't waste my breath at the dealer. Since you have OVT, you have 90% of what you need to flash it.
    pinochle and CygnusX191 like this.
  4. Oct 25, 2019 at 1:17 PM
    su.b.rat
    su.b.rat broken truck
    i am also letting my squeak and groan increase so i can try the new TSB in the next few weeks. right now i'm just trying to find exactly how to reproduce it in all conditions. because the conditions seem to change. i want to tell the SA how to reproduce it. so that when he doesn't i can tell him again how to before the next time he doesn't so i can tell him again.
    just getting ready for the dealer experience yo.
    CygnusX191 likes this.
  5. Oct 25, 2019 at 1:19 PM
    basshole
    chicagoland
    2018 OR MT
    Thanks for the reply.
    I can't seem to keep up around here like all you diehard taco guys.
  6. Oct 25, 2019 at 1:20 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Mine clicks and slightly squeaked a bit last winter. It went away as soon as the heater got some temp in it. What about full blast a/c on the floor vents?
  7. Oct 25, 2019 at 1:22 PM
    basshole
    chicagoland
    2018 OR MT
    I've been running 2.0 Beta a while now. Since upgrading tires to 33" skinnies second gear can be a bitch for me. Lugging, jerky. I used a Dremel to mod the accumulator, which changed the feel of the clutch, but not so drastic.
    Does anyone else experience 2nd gear dead spot and lugging with larger tires?
    I'm going to flash back to 87fob to compare
  8. Oct 25, 2019 at 1:28 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    I just want to see a pic of that M/T pro Mat bought :drool:
    @OVTune ?
    iexc, Livinserene, CygnusX191 and 3 others like this.
  9. Oct 25, 2019 at 1:50 PM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    I am running 265/75/16 e plys and also did the dremel mod. Second gear in mine is insane,it pulls like a mofo,no stumbling,jerkiness at all,I had it up to nearly 80mph the other day while checking my latest exhaust mod. Running the 2.0 91 dump tube Beta file.
    CorbinDallas, CygnusX191 and tonered like this.
  10. Oct 25, 2019 at 1:53 PM
    basshole
    chicagoland
    2018 OR MT
    No doubt it pulls hard in 2nd..
    I guess I wasn't to clear on my post. If I don't rev 1st high enough around town, 2nd gear shift is dull and lifeless until it picks up. Sometimes I'm slipping the clutch to smooth it out, other times without slipping it will be smooth, but still dull. Other times.... Well I'm shifting at higher revs lol
    su.b.rat likes this.
  11. Oct 25, 2019 at 1:55 PM
    Shellshock
    Iowa
    Yeah I do that sometimes. The gap from 1-2 is too big imo. Kinda sucks but it’s way better now than it ever was on the factory tune
    CorbinDallas and CygnusX191 like this.
  12. Oct 25, 2019 at 1:57 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    In my experience with the Betas, it was very consistent and smooth. Less torque than FOB, but nothing that 2nd or 3rd struggled with at any RPM.
    I am back on FOB for other reasons. That bottom end torque is very nice, but it isn't a limitation of Beta in my mind.
  13. Oct 25, 2019 at 1:57 PM
    M1Awolf
    Rob
    Montana
    I tend to shift at higher rpms for the most part but yes if I shift in lower rpms it takes a bit for second to catch up. I feel this is completely normal and to be expected YMMV
  14. Oct 25, 2019 at 1:59 PM
    M1Awolf
    Rob
    Montana
    Bingo,kinda reminds me of the old GM tranny's with "Granny Low"
  15. Oct 25, 2019 at 2:02 PM
    basshole
    chicagoland
    2018 OR MT
    The 1-2 gap is obvious, and the cause I'm sure. Just bringing my issue to the thread to see what others have to say. Before skinny 33s I was running 265/75r16 C load, it wasn't so much an issue then. If anything, it was a lot smoother.
    I'm planning to flash back to 87fob tonight. I feel beta is missing that torque curve off idle.
  16. Oct 25, 2019 at 6:25 PM
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    Did you delete your accumulator yet? Id start there, and when you go to refill use some good dot 4 and make sure to bleed the clutch line pretty good. Its not perfect after that but at least makes the pedal more consistent. You still get that gravelly feeling every once in a while but not as bad.
  17. Oct 26, 2019 at 6:58 AM
    Hugopreston
    Hugopreston Well-Known Member
    Hugo
    Tampa, Florida
    20 TRDOR MT DCSB
    Finally got around to doing the accumulator delete mod. What a difference! If anyone is on the fence, DO IT! Shoutout to @Trident904 for his kit.
    InfernoPhil, iexc, tonered and 3 others like this.
  18. Oct 26, 2019 at 7:56 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Seconded, HUGE difference
  19. Oct 26, 2019 at 8:27 AM
    su.b.rat
    no substitute for spinning up the motor going into second. every tune I've tried required it. big gap from 1 to 2 and the tq isn't there. gotta spin up to get it.
    this is where the value of that ADM shows. you'll have a spun up motor and that's where your clutch feel let's you modulate the power to keep it smooth.
    almost 3 years in and I'm about 98% consistently smooth. lots of practice to get that right. and yeah it pulled super hard and i can spin tires second gear no problem.
  20. Oct 26, 2019 at 8:29 AM
    apowers
    apowers '23 TRDPro6MT Solar Octane
    Third. Should have come from factory without the stupid accumulator!
Thread Status:
