2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Jan 21, 2020 at 10:46 AM
    Livinserene
    Livinserene Thejerkyguy
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    Woooohooo :D:burp:
    MOC221_ and tonered like this.
  2. Jan 21, 2020 at 10:54 AM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    File received,I will have to wait until after work 5pm MST to flash and test.
  3. Jan 21, 2020 at 10:58 AM
    Kamille.bidan
    Kamille.bidan Well-Known Member
    2017 Blue TRD OR MT
    What happened with the dump tubes/down pipes are those still for sale?
  4. Jan 21, 2020 at 10:59 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Yes, I am waiting for 15x more sets to arrive to us
    CorbinDallas likes this.
  5. Jan 21, 2020 at 11:02 AM
    Kamille.bidan
    2017 Blue TRD OR MT
    Are they sold already? Or can I purchase a set?
  6. Jan 21, 2020 at 11:03 AM
    OVTune
    OVTune
    They are sold out. You can purchase on our site when they are in stock. We expect to have them in February
    CygnusX191 likes this.
  7. Jan 21, 2020 at 11:27 AM
    M1Awolf
    Rob
    Montana
    Ok I am at home for lunch downloading the file in preparation for testing tonight and had a couple of questions for clarification purposes. I just want to make sure I am on the same page as the rest and especially Mat,so I can give him accurate feedback.
    First,everyone's perception/definition of defco and rev hang may vary,can someone outline and explain the characteristics of each. Second what method/technique/scenarios will give me the best results for assessing these?
    CygnusX191 and MOC221_ like this.
  8. Jan 21, 2020 at 11:31 AM
    OVTune
    OVTune
    1. Decel fuel.
    - Put the truck into 1rst gear. Drive slowly to about 10mph or about 2500 RPM.
    - let the truck decelerate, on it's own, no braking, down in speed.
    - observe when the truck stops decelerating and the engine is now fueled / driving again. You should be able to feel it.
    - Note, the RPM limit for it on the test file is low (explained in the email). If you go under 1000 rpm and the truck is still decelerating on it's own with no noticeable change don't let it stall.
    2. Rev Hang
    Drive the truck up to 2nd gear.
    Accelerate in second gear until about 5000 RPM
    Push the clutch in and observe how quickly the RPM of the engine falls. Normally it will fall, and "hang" right about 4000 rpm (according to users here) and drop at a slower rate.
    If you guys have anything to include please do!
  9. Jan 21, 2020 at 11:32 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    I can help test. Message sent to Zendesk.
    MOC221_, tonered and Shellshock like this.
  10. Jan 21, 2020 at 11:36 AM
    M1Awolf
    Rob
    Montana
    I just opened the email on my flashing computer and saw you sent a P5flash file,I am old school dongle PCM...please advise
    MOC221_ likes this.
  11. Jan 21, 2020 at 11:38 AM
    OVTune
    OVTune
    Reply to your ticket requesting pcm
    got your reply
  12. Jan 21, 2020 at 11:39 AM
    Shellshock
    Iowa
    Welcome back to the party stranger!
    :taco::taco::taco::taco::taco:
  13. Jan 21, 2020 at 11:39 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    For me, Rev Hang is spotty. I will do my best to assess it. It mainly happens when I am playing on an on ramp or accelerating hard from a stop. At the same time with the on ramp, I am checking traffic and such, so it is hard to tell exactly what I am doing when I hear and feel it hanging.
    For DFCO, I usually experience it most when coasting down a hill in slow moving traffic and 1st gear. Getting on and off the gas is really inconsistent, even above about 1,500. I can see when DFCO kicks in and verified it many times with the PiD on OBD Fusion. Sometimes, the throttle will hang open and it will drive ahead until I hit a bit of brakes. Once the revs drop below the DFCO RPM, I can see the injectors turning back on and the engine will surge a bit.
    Like I have said in the past, idle uses 0.2gal/hr. I will see fuel flow rates at 0.8 or greater when DFCO should be saying 0.0gal/hr. Fun stuff.
    This is why I am really interested to see what this test tune does. In the end, these oddities are very manageable and not what I would call dangerous in any respect. I'm just looking for consistency.
    MOC221_ and Shellshock like this.
  14. Jan 21, 2020 at 11:47 AM
    Shellshock
    Iowa
    Rev hang is most noticeable in first. Hit 5-7k rpm and clutch in. It’ll feel like an eternity for the revs to fall before you can goto 2nd.
    low speed driving in first or second gear is quite noticeable. My truck is quite jerky around 1500 rpms. I’ll also notice it coasting to a stop while still in 5/6. You’ll be slowing down, then suddenly you aren’t
    TacoTim85, iexc, MOC221_ and 2 others like this.
  15. Jan 21, 2020 at 11:51 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Agreed. I've seen those situations. More 2nd / 3rd on the latter though.
    I am going to do what OVT posted and also my normal stuff. :woot:
    TacoTim85, CygnusX191 and MOC221_ like this.
  16. Jan 21, 2020 at 12:07 PM
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    Yes, this is very noticeable for me in 2nd gear.
  17. Jan 21, 2020 at 12:17 PM
    M1Awolf
    Rob
    Montana
    Standing by.
    tonered and MOC221_ like this.
  18. Jan 21, 2020 at 2:23 PM
    92ehatch
    92ehatch Well-Known Member
    Kinley
    Hendersonville NC
    2019 Cavalry Blue DC TRD OR 6MT
    Dfco drives me nuts. I engine brake first gear in traffic a lot.
    That 1500 rpm release is a killer. If it was 1000 that would be wonderful. 800 even better, as long as it can catch itself before stalling.
    I regularly ride 6th down to 1000 coming to a stop then pop neutral.
    Rev hang is worse for me between 1st and 2nd. Timing gets way off. I notice it worse when you accelerate the 4k or so in first gear, then for some reason you have to back off (ie car turning, light changes) when you push the clutch in to either coast out it shift to second gear it just sits there, forever, waiting. i usually feather the clutch out to slow it down, but this creates more wear i don't want.
    MOC221_, tonered, TacoTim85 and 2 others like this.
  19. Jan 21, 2020 at 3:39 PM
    TacoTim85
    TacoTim85 Well-Known Member
    Vancouver, Washington
    2007 4Runner Sport Edition 4WD (Current)
    This.
  20. Jan 21, 2020 at 3:42 PM
    OVTune
    OVTune
    test files sent out to several of you guys.
    ONLY looking for feedback. They are not full tunes or meant to really be driven on.
    Most important feedback is the DFCO, as there are a few other tables for rev hang that may need some modification if that primary table doesn't do the job.
    Also while I'm digging in here. What else can I quickly include into this upcoming release? (if there is anything specific)
    I've been working on a TON of tables. and I recall someone asking me a long time ago about modifying alternator output, for example
    CygnusX191, tonered, PB FAB and 2 others like this.
Thread Status:
