2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Jan 6, 2018 at 6:10 PM
    #1481
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    OK, welcome back smartass :D
    Amusing ourselves while waiting for the next release lol
    Reluctanse[QUOTED] likes this.
  2. Jan 6, 2018 at 6:25 PM
    #1482
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    Tune file received, flashing now. One question for OVTuned,is this file the updated version with data from this past weeks Dyno Day?
  3. Jan 6, 2018 at 6:33 PM
    #1483
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Our volvo wagon was the last one to go into limp mode. The worst part was that it was still under warranty and wouldn't throw a code. I had to drive it around in limp mode for a while just to get it to store a code.
    That is about all that I have at the moment. Just mainly that the large angle is what makes folks unhappy with DFCO. Getting a normal amount of engine braking would go a long way toward justifying a tune purchase for me.
    MOC221_[QUOTED] likes this.
  4. Jan 6, 2018 at 6:48 PM
    #1484
    MOC221_
    Frank
    If the file name doesn't have 103B in it, then it's doubtful.
    LIST OF GOODIES UPCOMING IN 1.03B M/T and A/T IS UP OVER ON THE DEV THREAD!!! - POST 9404
  5. Jan 6, 2018 at 7:43 PM
    #1485
    M1Awolf
    Rob
    Montana
    Just got back from a test drive after the tune,you can definitely notice a difference in throttle response and low end power/torque increases. Roads were getting a little slick and it was hard to keep from breaking loose, it didn't do that before the tune unless I really got into the throttle. I will be out and about tomorrow after it warms up and the roads thaw out for more evaluation. So far I am impressed.
  6. Jan 6, 2018 at 9:42 PM
    #1486
    Reluctanse
    Reluctanse Granny shiftin, not double clutchin
    Sam
    Newberg, Oregon
    '17 Tacoma DCSB Inferno TRD OR 6MT
    OVTuned, Grabbers, 5100s, Bakflip VP
    :thumbsup:
  7. Jan 6, 2018 at 11:12 PM
    #1487
    Tharris242
    Tharris242 Technically
    Houston, TX
    2017 TRDOR DCSB 4X4 A/T FP TO BL
    Solid Fold 2.0, Air Dam
    My SGII/Tacoma reports throttle in PERCENT. Maybe the 7 and 17 is an apples and oranges situation?
    tonered[QUOTED] likes this.
  8. Jan 7, 2018 at 6:23 AM
    #1488
    iexc
    iexc WerXED BH2.0 AD
    Kalede
    Toronto
    2023 TRD Sport MT
    In any drive train you will have lash .the lower the tolerance as per manufacture design the more the lash. If you ever have your truck off ground and rowtate a tire back in forth it will rowtate 1in or more. This is collective play of every gear in trany u joints and rear end.
    when decal kicks in,it will start from rear tire and move it's way up to clutch.
    when on throttle it will start from clutch and work it's way to the last spline in axle.
    This acts like a wip with a ton on ether end.add a trailer or another ton and the jolt multiplies.
    In the heavy transport world this leads to twisted shafts broken pinion gears and short trany life.
    While I can understand the short term feul and brake saving feature of DEFCO.i don't be leave it's worth the long term agravasion of altering a century old driving technique.
    That's why never buy a vehicle off some one who treats the throttle like a on off switch.
    TeecoTaco and MOC221_[QUOTED] like this.
  9. Jan 7, 2018 at 7:33 AM
    #1489
    iexc
    Kalede
    Toronto
    2023 TRD Sport MT
    I never noticed DEFCO kick in at that rpm,I will check it out,maybe that's why the gate stays open to allow air in to compression stroke with out combustion.this will allow more engine braking.this is how Diesel engine brakes work.
    By lowering feul cut in you just moving the problem lower in the driving rang,this may benefit your driving habets but not others.
    The only way I see OVTUNE can regulate DEFCO is to kick the ingectors in one at a time to make a smother transition but that sounds like a lot of RND.
    I beleave killing the DEFCO is the easiest first step (after rev hang)as it is not part of engine design like the Atkinsons is.no risk to longevity of engine.
    That is why I am pushing for a trial,that way guys can see just how much feul it saves than based on feed back OVTUNE can take further steps.
  10. Jan 7, 2018 at 8:29 AM
    #1490
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Oh crap! My mistake. I'm seeing 17% min and about 65% max. Shown in Post 441. 17% should be about 15.3deg.
    MOC221_ likes this.
  11. Jan 7, 2018 at 9:30 AM
    #1491
    iexc
    Kalede
    Toronto
    2023 TRD Sport MT
    Up to 65%!
    If no air passes through throttle plates it will reduce air pressure in combustion stroke and reduce engine braking.this may be why your seeing any opening up of throttle plates on decel.(theory)
    On heavy deasel engine braking when in decel,sensor will retard on top of compression stroke by opening exhaust valves,this will remove any down word pressure resulting in more resistance and load fart type noise.
    MOC221_ likes this.
  12. Jan 7, 2018 at 9:39 AM
    #1492
    MOC221_
    Frank
    @tonered , I think we need to monitor VVT angles during DFCO as well.. I'd be interested to see what's happening on the intake side. In theory, you'd think the best engine braking would result from high compression ratios (OTTO mode). Spitballing, of course.. but we should be able to see what's happening.
    tonered likes this.
  13. Jan 7, 2018 at 10:20 AM
    #1493
    luminous
    luminous Well-Known Member
    Disabling DFCO would absolutely kill full economy and also speed up wear of the cat due to extra unburned fuel flowing into them. Every modern car kills the injectors when off throttle so its not like this is something new. Why Toyota made theirs act this way is interesting and quite annoying.
    Injectors dont like to start up with short pulses, its the most difficult condition for an injector which makes getting back on the throttle harder just due to the way injectors work. http://injectordynamics.com/wp-content/uploads/2013/12/LowPulseIDRange.gif
    Now keep in mind at higher loads direct injection is being used, and at lower loads both direct and port injection are being used. This adds quite a bit of logic and complexity and I imagine that is why we are seeing what we are seeing. What im getting at is based on load, injector strategies may be flipping between DI only and DI and PI causing some of these inconsistencies. The below article explains how this works as well as explaining how other automakers (ford in the case) use a different strategy which always keeps both DI and PI strategies enabled just at different percentages based on load. This is a guess based on what i've felt personally, once I get the updated tune ill start looking into this a bit more as well.
    https://blog.caranddriver.com/explained-why-some-engines-have-both-port-and-direct-injection/
    tonered and MOC221_ like this.
  14. Jan 7, 2018 at 10:27 AM
    #1494
    MOC221_
    Frank
    I'm with you on not nuking DFCO completely.. that said, the way Toyota implemented it on this application is far less than optimal. What a surprise..
    nevadabugle and tonered like this.
  15. Jan 7, 2018 at 10:31 AM
    #1495
    iexc
    Kalede
    Toronto
    2023 TRD Sport MT
    Engine braking is not free.the better the engine braking the more your engine works.you will be in save now pay later senario.engine braking becomes economical when hauling two or more times your weight and brake jobs cost 1000$ plus pr axle.
    On my 4 banger sec gen I got 220 k on original pad and rotors.a trikal down effect from my days running transport.
    Now I am targeting 100 to 120k that's more than enough.
    So what I am saying is BRAKE!BRAKE!brake!
  16. Jan 7, 2018 at 10:41 AM
    #1496
    MOC221_
    Frank
    While I get what you're saying, I also don't want DFCO nuked completely. It does save gas in these trucks, that's a fact. I can see it in my trip average fuel economy every day. BTW, my top priority in this debate is not to save money on brake parts.. although that is a byproduct. I just want consistent engine braking in the scenarios I mentioned before.
    tonered likes this.
  17. Jan 7, 2018 at 10:46 AM
    #1497
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I haven't seen anything in the Torque app that show VVT. Any clues there?
    I haven't looked into the Carista app much either. There might be something in there?
    I haven't looked at Fusion at all.
    Good point about the faux Atkinson cycle. That probably works against engine braking and might be the reason for the 17% min?
  18. Jan 7, 2018 at 10:47 AM
    #1498
    iexc
    Kalede
    Toronto
    2023 TRD Sport MT
    I don't think it will kill feul economy but let's try.and if rev hang is killed it will compensate.as far as cats are conserned do we know that they last longer after intro of DEFCO
  19. Jan 7, 2018 at 10:55 AM
    #1499
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I think we are confusing exhaust braking (jake braking) with engine braking. Of course, the complex Taco motor doesn't make it easy.
    On my motorcycle that has a simple open loop EFI and no DFCO, the throttle works like a brake being that it is a lumpy L-twin. Opening the throttle progressively kills engine braking. The effect is very linear. The engine braking on that machine is excellent. Most cars that I am following with be riding their brakes and I can slow faster than them. In normal riding about the only time I touch the brakes is to finish stopping after downshifting from 2nd.
    I am not looking for that amount of braking with the Taco, just a usable amount.
    Edit: as I said above, I never felt a problem with DFCO or engine braking in any previous car. Even our DiT Forester has great engine braking.
    MOC221_ likes this.
  20. Jan 7, 2018 at 10:56 AM
    #1500
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Cats were around while carbureted cars were still being made. They did ruin cats in short order, but they were open loop. A ruined cat had no feedback loop into the AFR.
    MOC221_ likes this.
Thread Status:
