2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Jan 30, 2020 at 7:02 AM
    Shellshock
    Iowa
    The gear specific tunes are for autos. It adjusts shift points. Not necessary for the manual.
    CygnusX191, TacoTim85 and MOC221_ like this.
  2. Jan 30, 2020 at 7:04 AM
    Garab
    Garab Well-Known Member
    2018 TRD Sport MT6 DCSB
    OVtune 2.0 TRD Sema wheels 265/70/17 Falken Wildpeak AT/3 SL ADM BAKflip mx4
    Ah that makes sense. I thought it may have something to do with the speedo.
    Whats the difference between the blank file and the catted file?
  3. Jan 30, 2020 at 7:06 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Just speculating, but gear/tire size changes COULD mess with the per gear table setup Mat mentioned was in the OEM calibration... not an issue if 2.0 has single torque table..
    To what extent it COULD mess with it I haven't a clue..
  4. Jan 30, 2020 at 7:06 AM
    Shellshock
    Iowa
    Blank file is for stock trucks. Cat and decat are for the OVT dump tubes.
    CygnusX191 likes this.
  5. Jan 30, 2020 at 7:08 AM
    Shellshock
    Iowa
    I wonder if tire size corrections ever got figured out
  6. Jan 30, 2020 at 7:12 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I don't believe so as this is more about TC partial and full lockup, shift tables, and other slushbox goofiness. In my mind, only an MT 5.29 tune would be needed to overcome the lowered speedo limiter.
    MOC221_[QUOTED] likes this.
  7. Jan 30, 2020 at 7:13 AM
    Tacoma816
    Tacoma816 Microwaving a cantaloupe, you know why
    I-70E KS exit 336 rest stop, 2nd stall
    Fred and Ginger
    custom interior stains
    Bruh, size doesn’t matter.
    Right?
  8. Jan 30, 2020 at 7:19 AM
    MOC221_
    Frank
    I hear you on the A/T goofiness, and I'm just speculating...
    My mind comes back to this - in a M/T, how does the ECU know which gear you're in? The wiring to the transmission only "reads" reverse and neutral with simple switches AFAIK.
    Speed and engine RPM are the two variables that I can think of for the ECM to "guess" which gear you're in.
    tonered[QUOTED] likes this.
  9. Jan 30, 2020 at 7:27 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. That is my speculation also. This is stupid as fuck in an MT when engine table choices are probably flipping like crazy during shifts with that flowchart from hell. Most of that logic usually depends on a fully engaged clutch to determine the actual ratio (reactionary). Stuff like that exists for gear indicators. It is a popular mod on motorcycles.
    The ECU might use the clutch switches as sensors to maybe hold a certain table (previous gear??) until the fully engaged switch is sensed.
    Either way, this might be why some folks feel the shifts for certain gears are clunkier than others?
    Still, I don't see a 4.88 or 5.29 tune helping with this. Just a single map that gives consistency at the critical phase when the clutch is in use.
    I will say that for me, all cluckiness was gone with the TSB tune and to some extent the ADM.
  10. Jan 30, 2020 at 7:29 AM
    Shellshock
    Iowa
    Some of mine suck. Usually 1-2.
  11. Jan 30, 2020 at 7:30 AM
    MOC221_
    Frank
    Yep.
    ...and probably a big reason why the throttle can be soo unpredictable.
    TacoTim85 and tonered[QUOTED] like this.
  12. Jan 30, 2020 at 7:32 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The noted changes for 2.0 should flesh that out.
    BTW, fucking FOB DFCO is still killer! :D And worthy to include for now as a half measure, IMVHO.
    iexc and TacoTim85 like this.
  13. Jan 30, 2020 at 7:33 AM
    Kamille.bidan
    Kamille.bidan Well-Known Member
    2017 Blue TRD OR MT
    I watched a video of an AT owner with 5.29s he was at 75mph @ 2500 rpm. The stock MT does 75mph at 2500rpm.
    I am curious as to what the driving experience is like with 4.88s on an MT.
  14. Jan 30, 2020 at 7:37 AM
    MOC221_
    Frank
    Well, even without a shred of experience I can tell you that the driving experience IN REVERSE will be improved.
    CygnusX191, Shellshock and su.b.rat like this.
  15. Jan 30, 2020 at 7:37 AM
    su.b.rat
    su.b.rat broken truck
    correct answer. lol
    CygnusX191 and Shellshock like this.
  16. Jan 30, 2020 at 7:40 AM
    Kamille.bidan
    2017 Blue TRD OR MT
    I hear you on that. Going uphill in reverse is very tricky. Dang near have to dump the clutch 3k.
    CygnusX191 and Tacoma816 like this.
  17. Jan 30, 2020 at 7:45 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    MOC221_ likes this.
  18. Jan 30, 2020 at 7:46 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    That would be me. I went 4.88 and will never go back. I love it like the sun.
  19. Jan 30, 2020 at 7:48 AM
    su.b.rat
    did you go to 33's or something?
    has any MT guy actually gone 4.88 at stock(ish) tire size?
    Gvsukids and Shellshock like this.
  20. Jan 30, 2020 at 7:49 AM
    Sippi
    Sippi Well-Known Member
    Boca Raton, Fl
    El Taco Negro - 2017 Sport DC 4x4 6MT
    OVTune 2.0 TC Electronic BHLM 4R Sema with Nitto G2s Swing Case OEM Goodies Pro Items
    I feel like I will burn up my clutch every time I am backing my boat into its parking spot. :still looking for a good front mount hitch option:
    Tacoma816 likes this.
Thread Status:
