2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Feb 11, 2020 at 5:44 PM
    GBR
    GBR Well-Known Member
    19 TRD OR
    I get the sentiment, but I don't see that being remotely possible with these engines. Direct injection and port injection, VVT etc. Throttle is definitely funky on these and I don't think it will ever perform like you would expect an older engine to. Regardless of who is tuning it.
    AKGSD likes this.
  2. Feb 11, 2020 at 5:50 PM
    arrakis429
    arrakis429 Waiting for the Mets to repeat 1986
    Ben
    Springfield, OR
    2016 Quicksand TRD Sport ACLB 3.5L 6MT (OVTuned)
    Fuel Mavericks w/ Falken Wildpeak AT3W 285/70/17 (Soon to be SCS Ray 10 w/ Falken Wildpeark AT4W 255/80/17) Leer 100 Topper + Prinsu Cabrack Cali raised Bed stiffeners RCI Sliders RCI skids Bilstein 6112 Front 5/4 w/ Eibach 700lb Coils SPC LR UCA's Bilstein 5160 Rear OME Dakar HD Leafs Wheeler's UBolt Flip w/ Bumpstops N2 Designs MT remote starter OVTuned ARB Awning w/ Windbreak and Deluxe 'Room' SpartanXCustoms Amber Scoop light Pelfreybilt Aluminum Front Plate Bumper w/ CaliRaised 32” light bar and Baja Designs Amber Squadrons Wide Cornering Warn Zeon 10s Platinum Winch 2Lo Mod URD Stage 3 Clutch with Heavy flywheel Accumulator delete mod TacoGarage Dash Multimount Warfab Phantom Rear Bumper OVTune Dump tubes
    Hi guys,
    I've done a number of searches through various forums, including the software update forum and I thought I'd check here...
    I've got my OVTUNE software and cable, and I flashed 1.05, it was a lot better than stock as I am working from 04B10.
    My question is related to what seems like limited options thus far with 04B10 (just 87,91 and 93). I can't even get FOB to work (flash unuccessful), there are no 1.05.1 options for me that will download in the drop down, none of the 2.0 beta stuff will currently work so... My assumption is that I need to use my new cable + techstream and the software update attachments from the MT software update forum and update the ECU first, and then take advantage of the other tunes. Am I correct on this?
  3. Feb 11, 2020 at 6:16 PM
    TacoTim85
    TacoTim85 Well-Known Member
    Vancouver, Washington
    2007 4Runner Sport Edition 4WD (Current)
    I used to love and still do love sunroofs actually because I'm fancy as fuck.... but I rarely actually use them anyway. :rofl:
    Bumped my head not once, not twice, but three times on the headliner while test driving one with a sunroof. Couldn't check my blindspot without getting bopped in the head. :rolleyes:
    AKGSD likes this.
  4. Feb 11, 2020 at 6:17 PM
    Shellshock
    Iowa
    I usually keep mine closed cuz otherwise its too bright lol
    pinochle likes this.
  5. Feb 11, 2020 at 6:19 PM
    TacoTim85
    That too... lol.
    CygnusX191 likes this.
  6. Feb 11, 2020 at 6:41 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yessir. That is all that you need to get to 04B13.
  7. Feb 11, 2020 at 6:44 PM
    arrakis429
    Ben
    Springfield, OR
    Sweet, thanks!
    I've got to drive out to my clinical rotations about 100 miles tomorrow I'll do that on 87 base, I've got 3 days of rotations including a 24 hour ER rotation so I'll probably just do it up there and drive it home all updated.
    pinochle, CygnusX191 and tonered like this.
  8. Feb 11, 2020 at 6:48 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I would do it at home when life is good and your rested. Be sure to follow the instructions as well as possible.
  9. Feb 11, 2020 at 6:52 PM
    arrakis429
    Ben
    Springfield, OR
    Should i upload to the newest version of techstream (as listed in your signature) or use the 12.10.019?
    pinochle and tonered like this.
  10. Feb 11, 2020 at 6:54 PM
    Shellshock
    Iowa
    Either one will work for a 16 truck
    tonered and CygnusX191 like this.
  11. Feb 11, 2020 at 7:26 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    What @Shellshock said. Either version will do the update and the customizations.
  12. Feb 13, 2020 at 9:42 AM
    jmahad01
    jmahad01 Well-Known Member
    A little sad. There seems to be only one tune option for my 04A70 which is an 87 base tune 1.05.
    Edit - looks like there is a FOB option which looks like the Manual Transmission Performance tune. I'll give that a shot.
  13. Feb 13, 2020 at 10:06 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    FOB for the win.
    CygnusX191 and crigg93 like this.
  14. Feb 13, 2020 at 10:13 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You can also apply the TSB update, be at 04A71, and use the Beta tunes as well.
  15. Feb 13, 2020 at 10:21 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    It's related to throttle values that are learned over time. I've been trying to find a way to default set / permanent value but it doesn't seem possible, yet.
    Same issue for the ATs. Had a customer actually test and confirm he can get the brake override consistently right after a flash if he doesn't reset the values, but if he does, no brake override.
    And the truck can brake override because of throttle.
    Everything, almost all "issues" or "learn back to stock" or "feels number" etc over time is all related to this stupid throttle airflow learning.
    Now why have throttle airflow learning? It's one way for your tune to clean itself overtime for rough tables. It's another thing Toyota does to try to GUESS, not kidding, look it up in the overhaul manual, to GUESS manifold pressure differential vs baro by angle. Because adding a 0 to 5 v map sensor and writing a calibration for it is just too easy vs trying to create an equation to guess the pressure inside the manifold.
    Then, when the airflow actual exceeds calculated guess, correction factors are applied, and applied over time, and the ECU does throttle angle limiting and conditioning to "clean it up."
    This is why higher gears for example, you full throttle in 6th, and get maximum allowed 40 percent, or 45 percent throttle. Because at those low rpm that's all the ecu calculates what's needs to meet demand airflow and torque.
    The ECU uses calculated torque vs optimal torque vs torque limit, takes the mean of the value and uses it as the torque axis for allowable throttle angle by rpm.
    Optimal + limit divide by 2, compare to calculated actual, set throttle limit by ratio of difference.
    It's absolutely terrible design.
    julman99, AKGSD, CorbinDallas and 4 others like this.
  16. Feb 13, 2020 at 10:26 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I hated (hate) learning on our turbo cars and mostly hate the learning on the Tacos. Most everyone that is in tune (is an enthusiast) seems to not like ECU learning. I always hated driving our turbos after my wife had been driving it for a while. They would spool slow and low. It took a lot of wasted fuel to bring them back to life.
    It is understandable that not much can be done about it. Just that it seems to not really help anything either after the first few miles.
    Edit, based on your edits. It is amazing that Toyota does not have a MAP sensor on a dual injection motor with a heated MAF sensor, VVTi-W, and all the other hardware.
    CygnusX191 and iexc like this.
  17. Feb 13, 2020 at 10:36 AM
    OVTune
    OVTune
    Some calibrations don't have obsessive learning corrections, other than normal stuff like ignition trimming, fuel trimming, knock trimming. Standard stuff.
    Really the only calibrations I can think of off the top of my head that has absurd, multi layered labyrinth of code with complex table calculation, learning over time, 4th and 5th axis layered tables, is Ford.
    But funny enough even with Fords crazy, and I mean crazy way of how they create their tunes, axises, calculation of axises...their engines run (when they run) at near peak possible performance for conditions all the time.
    Ford goes to the far end of extreme too, calculating LSPI limits, calculating difference in heat time of the aluminum alloy block vs head. Real crazy stuff.
    Sscustoms, AKGSD, MOC221_ and 2 others like this.
  18. Feb 13, 2020 at 10:37 AM
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Ultimate Paint Protection, Borla S-Type Catback Exhaust, ME-SO Customs Gasshole, ME-SO Customs Total Tails Stage 1, ME-SO Customs Ultimate LED Turn Signals V4, HELLA Supertones, OVTuned 2.0, 2LO Mod, 16x8 0mm Enkei RPT1 Wheels in Titanium Gold, Diode Dynamics SS3 Pro Foglights, K&N Cabin Air Filter, HPS Intake Hose, Amsoil Gear Lubes in 6MT, front and rear differentials, XPEL Prime XR Plus Tint, TRD Engine Air Filter, Pioneer Head Unit, 275/75R16 Falken Wildpeak A/T3W Tires, RallyArmor UR Flaps
    Sport#!
    tonered[QUOTED] likes this.
  19. Feb 13, 2020 at 10:43 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Very interesting.
    I get that Toyota is investing a lot of its future on the 3.5l and that some of the Taco hardware and software is for long term development, but damn.
    Like you said about Ford, at least their software works.
    I still remember how whacky 04B12 was. Like driving a brand new MT that I never really adapted to. There was no relaxing, easy shifts. 04B13 and your tunes are like butter.
    CygnusX191 and Shellshock like this.
  20. Feb 13, 2020 at 10:45 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Even S# needs a couple adaption runs to get happy. I absolutely love the 2.0 DiT for what it does when the CVT gets out of the way. I still haven't had a chance to try it in the WRX.
Thread Status:
