2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Feb 13, 2020 at 10:48 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Yep and the primary changes to 04B12 and 04B13 is VVT timing and code.
    The tables like torque, throttle etc didn't really change.
    tonered[QUOTED] and CygnusX191 like this.
  2. Feb 13, 2020 at 10:52 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    So this is the hold up to 2.0?
    Tacoma816 and Melmantaco like this.
  3. Feb 13, 2020 at 11:04 AM
    Shellshock
    Iowa
    Soooooo
    how long until you can throw Toyota’s ecu logic in the trash and rewrite it the right way?
    I believe in you.
    AKGSD, TacoTim85, CygnusX191 and 2 others like this.
  4. Feb 13, 2020 at 11:07 AM
    OVTune
    OVTune
    There are a few hold ups for 2.0. Not specifically this.
    ReWriting all the code and redesigning it will take me years. The only thing I can positively do is rewrite sections, calculations, eliminating or changing steps in the code.
  5. Feb 13, 2020 at 11:14 AM
    OVTune
    OVTune
    Forced injection?
    Right now there are 3 primary hold ups.
    1. Figuring out map switch control for MT
    2. Deciding on implementing octane learning or not
    3. 6AT.
    Ahh and DFCO
    Simple torque tables, etc are done.
  6. Feb 13, 2020 at 11:26 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Depends on how many pants he's wearing
  7. Feb 13, 2020 at 11:53 AM
    Tacoma816
    Tacoma816 Microwaving a cantaloupe, you know why
    I-70E KS exit 336 rest stop, 2nd stall
    Fred and Ginger
    custom interior stains
    TL;DR. Whatcha wearing?
    CygnusX191 likes this.
  8. Feb 13, 2020 at 11:54 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The most interesting part is how those change the act of shifting. Going from extremely touchy, high attention needed on each and every shift, like you are driving a new MT vehicle for the first time on every trip, to just being easy and careless like every DD MT.
    I can say that the 2.0 Betas, esp early in the settling period gave me the best, most effort less shifts imaginable. The Beta seemed to take much longer than 1.05 to fully settle (about 1,000mi), then it became a bit notchy and the MPGs fell off. It would take a nice long drive for things to come back. I assumed that some of that was due to the Betas being not full versions?
    :cheers:
  9. Feb 13, 2020 at 11:58 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I did toss you a couple messages about the DFCO testing. Mainly that the code stuck after flashing back to FOB (@M1Awolf confirmed also after flashing back to the Dump Tube tune). I can sort of guess why. Regardless, it is fucking awesome. Even the small change in 1st gear revs makes a big difference out on the road.
    For your list, I can see how map switching and OLE would make your life simpler. Both are very nice to have. At the same time, I would run on 87 FOB / Tow and most likely be happy for the life of the Taco given the other 2.0 features that you noted.
    CygnusX191 and TacoTim85 like this.
  10. Feb 13, 2020 at 12:00 PM
    TacoTim85
    TacoTim85 Well-Known Member
    Vancouver, Washington
    2007 4Runner Sport Edition 4WD (Current)
    Oh no...look what you did now. You woke the troll.
  11. Feb 13, 2020 at 12:01 PM
    TacoTim85
    Awesome side effect.
    CygnusX191 and tonered[QUOTED] like this.
  12. Feb 13, 2020 at 12:03 PM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    I personally vote to ditch map switching.... Certainly there will be others that disagree though.
    MOC221_, mZiggy, M1Awolf and 3 others like this.
  13. Feb 13, 2020 at 12:05 PM
    TacoTim85
    x2
    I wouldn't use map switching often enough to care.
    mZiggy and RedBeard1 like this.
  14. Feb 13, 2020 at 12:05 PM
    Shellshock
    Iowa
    map switching would be nice but i dunno how many would actually use it. i feel like most people are either gonna run the base tune or FOB and never switch.
    Rainman70, iexc, mZiggy and 4 others like this.
  15. Feb 13, 2020 at 12:21 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You know it. With the injectors coming back on at about idle in 2nd on up, it is so nice to either be creeping around at those RPMs or slowing so smoothly while still getting some engine braking.
  16. Feb 13, 2020 at 12:40 PM
    CdnSldr
    CdnSldr ______________
    Canada Eh!
    *forced induction* aka FI
  17. Feb 13, 2020 at 12:52 PM
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    I have map switching on my current Cummins and on the one before. It is fun when you first get it but that fun goes away after a week or two. I just settled in on the tune that felt the best and left it alone after that. It’s overrated.
    I am fine with no map swapping and have no issues with hooking up the laptop now and then. Leave the map swapping to the hand held tuner if it Is a must have for some. Quit over complicating things for Mat.
    iexc, lapoltba, skyking3 and 4 others like this.
  18. Feb 13, 2020 at 1:09 PM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    Considering I will need to run a catless tune I am not sure if any additional maps would be available. My vote,ditch the switching and get these tunes on a plate...
    lapoltba, tonered and su.b.rat like this.
  19. Feb 13, 2020 at 1:15 PM
    CdnSldr
    Canada Eh!
    My impression is that map switching would not be necessary.
    Personally I’d only want map switching if Mat developed an eco tune, to switch back and forth from a balls out performance tune to eco, both 91 octane.
    From the previous reports it sounds like the performance tunes net the best fuel economy already when driven conservatively. If that’s still the case then it’s a moot point and a single tune would be sufficient for me.
    Ps..I take delivery of my Pro on Tuesday and am itching some fierce for 2.0 final to be released for 2020’s. Btw @OVTune of you need or would like any additional 2020 MT ECU data downloaded, or if there’s anyway I can help with testing etc, please let me know.
  20. Feb 13, 2020 at 1:18 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That was discussed early on in the 2.0 development. The Base 87 tune would be targeted for economy. That is the only time that I would look to use it, like on a long road trip.
    But yeah, 1.05 FOB gives me the best MPGs overall. The Betas on summer blend fuel did a bit better, but required some long runs to keep the MPGs up.
    CygnusX191 and CdnSldr[QUOTED] like this.
Thread Status:
