2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Feb 14, 2020 at 7:23 PM
    Tacoma816
    Tacoma816 Microwaving a cantaloupe, you know why
    I-70E KS exit 336 rest stop, 2nd stall
    Fred and Ginger
    custom interior stains
    well surely you at least took off some layers so as to not stain your clothes...
    CygnusX191 likes this.
  2. Feb 14, 2020 at 7:24 PM
    Shellshock
    Iowa
    Nope. Coveralls. They get filthy and I stay clean.
  3. Feb 14, 2020 at 7:26 PM
    Tacoma816
    Fred and Ginger
    Oh that’s smart! Plus they’re easy to get off at the end of the lube job
  4. Feb 14, 2020 at 7:38 PM
    TacoTim85
    TacoTim85 Well-Known Member
    Vancouver, Washington
    2007 4Runner Sport Edition 4WD (Current)
  5. Feb 14, 2020 at 7:43 PM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    You too,I am starting to think that Tacoma816 may have some rather non conventional proclivities...
    CygnusX191, tonered and Tacoma816 like this.
  6. Feb 15, 2020 at 4:38 AM
    Tacoma816
    Fred and Ginger
    Did you reuse the gaskets?
  7. Feb 15, 2020 at 4:45 AM
    Garab
    Garab Well-Known Member
    2018 TRD Sport MT6 DCSB
    OVtune 2.0 TRD Sema wheels 265/70/17 Falken Wildpeak AT/3 SL ADM BAKflip mx4
    The TSB replaces the MC and pedal cluster. Made my truck a completely different animal afterwards.
    Melmantaco likes this.
  8. Feb 15, 2020 at 4:47 AM
    Tacoma816
    Fred and Ginger
    How was it different?
  9. Feb 15, 2020 at 5:08 AM
    Garab
    Shifting was much more consistent and smooth. I suspect my MC was bad.
    CygnusX191 and Tacoma816[QUOTED] like this.
  10. Feb 15, 2020 at 5:09 AM
    Tacoma816
    Fred and Ginger
    Ah okay. Thank you for your prompt response. Your annual review will reflect.
  11. Feb 15, 2020 at 7:09 AM
    Shellshock
    Iowa
    First time I replaced them. Second time I didn’t bother.
    tonered likes this.
  12. Feb 15, 2020 at 11:55 AM
    GF8er
    GF8er Well-Known Member
    MT. Hood
    18 MGM DCSB TRD OR 6MT
    Same here. Had the TSB done on Monday. The clutch feels way better now.
  13. Feb 15, 2020 at 3:30 PM
    Livinserene
    Livinserene Thejerkyguy
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    Anybody have TSB info ?
  14. Feb 15, 2020 at 3:35 PM
    arrakis429
    arrakis429 Waiting for the Mets to repeat 1986
    Ben
    Springfield, OR
    2016 Quicksand TRD Sport ACLB 3.5L 6MT (OVTuned)
    Fuel Mavericks w/ Falken Wildpeak AT3W 285/70/17 (Soon to be SCS Ray 10 w/ Falken Wildpeark AT4W 255/80/17) Leer 100 Topper + Prinsu Cabrack Cali raised Bed stiffeners RCI Sliders RCI skids Bilstein 6112 Front 5/4 w/ Eibach 700lb Coils SPC LR UCA's Bilstein 5160 Rear OME Dakar HD Leafs Wheeler's UBolt Flip w/ Bumpstops N2 Designs MT remote starter OVTuned ARB Awning w/ Windbreak and Deluxe 'Room' SpartanXCustoms Amber Scoop light Pelfreybilt Aluminum Front Plate Bumper w/ CaliRaised 32” light bar and Baja Designs Amber Squadrons Wide Cornering Warn Zeon 10s Platinum Winch 2Lo Mod URD Stage 3 Clutch with Heavy flywheel Accumulator delete mod TacoGarage Dash Multimount Warfab Phantom Rear Bumper OVTune Dump tubes
    Got OVTUNE, got the cable, ran P5flash and found out I was 04B10. I already had 87 in the tank so there was only one tune I could use. For whatever reason 87 FOB failed to install multiple times... so 87 base it was (this was Tuesday 2/11.
    Thoughts on 1.05 87 Base: Big difference from stock, that lag between pushing the gas pedal down and actually seeing/feeling the engine push was practically eliminated. I really appreciate that as it has been a problem for me accelerating when passing people, making turns across traffic on arterial streets, etc. This was actually the problem I was willing to spend the dough to fix - although I heard the ECU updates alone through techstream may have remedied this. The power felt good throughout, and I had no issues (CEL's, limp mode, etc). Drive approximately 200 miles on this and ran my tank down, filled up with 91 on the hopes that today I would flash a 91 octane version.
    Thoughts on 2.0 beta 91: I used techstream and tonered's linked files to update my ECU. 04B10 to 04B13, and perused the OVTune beta page for the appropriate tune. Once I downloaded it and flashed it I used pc5flash to 'reset lv'. Let it idle for a bit and took it out on the highway. Didn't notice any lag there but actually was surprised by the feeling, the throttle response felt less powerful than the 87 base, not quite boggy but just slower? I don't think I was imagining things as I drove 90 miles on the 87 base this morning. I got to thinking about the 1.05 91 FOB and wanted to try out the get up and go everyone has been posting about, so I drove home with only about 14 miles on this tune. Not sure it was enough to really give a ton of input.
    Thoughts on 1.05 91 FOB: Pretty much what I'd hoped it would be, I am getting up to speed (and quickly at that) on the on ramps still in second gear. I'm able to pull pretty good in 5th at 70mph on a steep incline (Spokane downtown to Airway Heights). I think I'll keep this one on for a while and see how it develops, I'm sure my mpg's will be in the gutter
  15. Feb 15, 2020 at 3:44 PM
    M1Awolf
    Rob
    Montana
    I think you will be surprised,most here claim better mileage with the 91 FOB tune.
  16. Feb 16, 2020 at 5:10 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Fresh brew of hand grinded French pressed coffee - check.
    Ready to do some more DFCO testing and code today. Lets get this figured out.
    Question for you guys.
    on the AT, if you hit the rev limiter and continue to hold the gas down, (in S mode) the truck will decel until 4000 RPM when fuel will be brought back.
    Is this the case on the MT? or can you bounce off the limiter.
    CygnusX191, M1Awolf, crigg93 and 2 others like this.
  17. Feb 16, 2020 at 5:13 AM
    offgrid taco
    offgrid taco Well-Known Member
    ned
    mass
    24 trd off road bronze oxide
    Watch out, Matt has coffeeeee.
    CygnusX191 and mZiggy like this.
  18. Feb 16, 2020 at 5:33 AM
    offgrid taco
    ned
    mass
    When you hit the limiter it's a soft cut and doesn't jerk you forward. I usually shift gears when I hit it and can get right back on the power with no delay. Not sure what would happen if I held it at limiter. Definitely doesn't feel like it cuts the engine for any amount of time.
    Ned
  19. Feb 16, 2020 at 5:53 AM
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    When you hit the rev limiter it acts just like every other Toyota I have ever owned. Just “bounces” off the limit. Steep red clay hills with 3000lb trailer loaded with welding equipment and a good rain can get you in a bind.
    tonered, CygnusX191 and Shellshock like this.
  20. Feb 16, 2020 at 7:25 AM
    sorevilo
    sorevilo Well-Known Member
    Might be a dumb question but what is DFCO?
Thread Status:
