2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Feb 16, 2020 at 7:26 AM
    Tacoma816
    Tacoma816 Microwaving a cantaloupe, you know why
    I-70E KS exit 336 rest stop, 2nd stall
    Fred and Ginger
    custom interior stains
    :deadhorse:
    CygnusX191 likes this.
  2. Feb 16, 2020 at 7:32 AM
    sorevilo
    sorevilo Well-Known Member
    I like it
  3. Feb 16, 2020 at 7:48 AM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    Every time I have hit the limiter it bounces off it.
    tonered and CygnusX191 like this.
  4. Feb 16, 2020 at 7:48 AM
    92ehatch
    92ehatch Well-Known Member
    Kinley
    Hendersonville NC
    2019 Cavalry Blue DC TRD OR 6MT
    I've only hit the limiter once in stock tune. It bounced the limiter and then i shifted
  5. Feb 16, 2020 at 8:00 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Deceleration Fuel Cut Off is how I read it, but that is a GUESS
    sorevilo[QUOTED] likes this.
  6. Feb 16, 2020 at 8:00 AM
    Tacoma816
    Fred and Ginger
    Changed it yesterday. It was as easy as you described, minus having to best-guess the torque value in order to drive to buy a torque wrench to properly torque the bolts. Shifting is noticeably smoother, going from 4-5 felt like sliding a hot dog into a fresh jar of mayo. 1-2 is still kind of crunchy though. I used AMzZZZOIL, so maybe next time I'll do Redline and see if it changes anything, if I don't trade the thing in for an 80s Astrovan first.
    Did anyone else that's changed their tranny's fluid notice it tastes WAY more like Pepsi than Coke? I was shocked!
  7. Feb 16, 2020 at 8:01 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    in the automatic, in S mode, hit the limiter, continue to hold the gas, fuel will remain cut, and the truck will slow down, until you hit 4000 rpm.
  8. Feb 16, 2020 at 8:03 AM
    Tacoma816
    Fred and Ginger
    I'm 93% sure it bounces. The remaining 7% depend on your attire.
  9. Feb 16, 2020 at 9:25 AM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    i’ve experienced that multiple times, mainly with all the trac aids turned off trying to get tail happy in snow.
    You have to let off the gas for it to go again
    I would much prefer it just bounce off the limiter!!
    Also side note is there any way we could get a higher idle in low range? Trying to rock crawl at that low 500rpm idle does not make for a happy taco motor - gets real knocky sounding, tries to stall out.... it can’t idle over obstacles, not enough torque. Such a strange motor to be placed in front of a clutch
    And, curiously, i’ve noticed that on stock tune (on pavement) i could slowly let out the clutch with no throttle and it would maintain rpm, and move forward — seems much more inclined to stall out with the tune - more or less /have/ to give it throttle. Worth it for all the benefits of course — I wonder if that has to do with all the ignition timing data Toyota had at idle that you wondered about on your blog
    Melmantaco likes this.
  10. Feb 16, 2020 at 12:22 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Bounced it on mine in 2nd and 3rd. Didn't hold though.
    You're not wrong. MT90 tastes like an oilier version of the afterslick you get from flat Pepsi.
    Tacoma816[QUOTED] likes this.
  11. Feb 16, 2020 at 1:27 PM
    OVTune
    OVTune
    Ok what i'm trying to pinout. on the MT you're at full throttle, you hit the limiter, to keep your foot buried in it.
    Does it do "na na na na na na" as it continually bounces at the limiter,
    or does it hit the limiter, and start decel, even when your foot is still in it.
  12. Feb 16, 2020 at 1:41 PM
    M1Awolf
    Rob
    Montana
    Don't know if it will help but the couple of times that I have hit the limiter it gave me the na'na's 3-4 seconds until I put in the clutch and shifted to the next gear. It did not appear that it would "decel" if I kept my foot in it. Not sure I want to test that theory though...rpyqxrxKyMXHnavCpZzV.gif
  13. Feb 16, 2020 at 1:45 PM
    CdnSldr
    CdnSldr ______________
    Canada Eh!
    @OVTune If you don't get a definitive answer by tuesday, I'll test it on my truck with datalog and video. However, when I test drove a 2020 TRD Sport 6MT, I took it to the limiter in 2nd, and it DID NOT continuously bounce off the limiter. With my foot still buried the engine started to decel. I didn't see how low it took the rpm's before I upshifted.
    My recollection off how older vehicles would bounce off the rev limiter was in a late 90's/2000's GMC pickup. It was a rather violent and abrupt "bouncing".
  14. Feb 16, 2020 at 1:52 PM
    CorbinDallas
    CorbinDallas Well-Known Member
    Corbin
    Tacoma
    16 MT OR
    While I am curious now, I don't think I will go and find out, sorry :)
  15. Feb 16, 2020 at 2:04 PM
    Tacoma816
    Fred and Ginger
    I’ll test this once 2.0 is out :cool:
    CygnusX191 and CorbinDallas like this.
  16. Feb 16, 2020 at 2:10 PM
    AKGSD
    Joe
    Alaska
    It bounces if you let off the gas but it decels to 4k if you keep it floored. Did it stock, not sure if i’ve done it since it’s been tuned. As soon as you let off the throttle completely you can re-apply it
    CorbinDallas likes this.
  17. Feb 16, 2020 at 4:07 PM
    JIN
    JIN Well-Known Member
    Jin
    Olympia, WA
    2017 Super White TRD Sport 4x4 DCSB
    @OVTune , know you probably have hundreds of messages to filter through but I PM'd you and was hoping to ask a couple questions. Thanks!
  18. Feb 16, 2020 at 4:28 PM
    offgrid taco
    offgrid taco Well-Known Member
    ned
    mass
    24 trd off road bronze oxide
    I just went out in my truck and held throttle to the floor in first gear. Held rock steady at 6900rpm for 2 to 3 seconds then I let off. 2018 with latest update running 2.0 beta
    Edit
    Ok just did it a second time. It will hold 6900 for about a second or so then slows down a little to about 6500 where it will stay for the 5 seconds I held it. It is very smooth both when it first hits the limiter and as it drop to 6500. No na na na crap
    tonered, iexc and su.b.rat like this.
  19. Feb 16, 2020 at 4:34 PM
    Tacoma816
    Fred and Ginger
    super inappropriate. Mods please ban this person.
  20. Feb 16, 2020 at 5:26 PM
    JIN
    Jin
    Olympia, WA
    How was that inappropriate? I'm confused. If I did something against the rules I'll delete my post...
    RustyTacoVT likes this.
Thread Status:
