2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Feb 19, 2020 at 12:15 PM
    CdnSldr
    CdnSldr ______________
    Canada Eh!
    While it's been a while since I learned about ODBII, I would venture to say "somewhat correct". A DTC is only ever generated in response to a problem. Could be from a series of misfires due to bad gas that is self correcting the next time you fill up, bad sensor, intermittent loose connecting somewhere etc. If you have your vehicle repaired typically all DTC's are cleared at the same time. If you haven't had your vehicle diagnosed and repaired after a DTC is generated than simply deleting the DTC is a bandaid solution as it will more than likely reappear at some point, plus you're removing some of the "clues" that a tech might find valuable when it comes time to repair the reason for the DTC.
    Long story short, if clearing DTC's makes a different for you then there is probably a bigger problem going on. (or your tech was lazy and didn't delete them after repair).
    My recommendation would be to check for codes with TechStream prior to blindly clearing. If you have any stored or active codes, write them down with whatever info is available i.e. time stamp ect.
    tonered[QUOTED] and CygnusX191 like this.
  2. Feb 19, 2020 at 12:29 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Very true. But like I said, there are the deeper readiness codes associated with them. I am definitely not talking about performance, but just a clean slate for the tune to settle into.
    Also in my rare experience with stored DTCs, I have noted the code before clearing. The problems did not go away immediately after clearing. I have done this to see if the problem was constant or intermittent.
    Like you said though, if folks are going to take their car in to get fixed, clearing helps no one. And, clearing a code just before an emissions test is bad bananas also. You got to do a full drive cycle or it is just a waste of money.
    Tacoma816 and CdnSldr[QUOTED] like this.
  3. Feb 19, 2020 at 5:20 PM
    ArmoredDucky123
    ArmoredDucky123 Active Member
    2019 cement TRD sport 4x4 dcsb MT
    Not to change the subject, but, I just got back from a test drive after flashing for the first time and.....holy shat....Just.....holy shat.
  4. Feb 19, 2020 at 5:32 PM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    What version of the tune did you flash?
  5. Feb 19, 2020 at 5:32 PM
    ArmoredDucky123
  6. Feb 19, 2020 at 5:37 PM
    M1Awolf
    Rob
    Montana
    After you get a couple miles on it you should try a 91 FOB version...
  7. Feb 19, 2020 at 5:44 PM
    ArmoredDucky123
    I like that idea, a lot. lol. just got half a tank of 89 to burn through. how would you describe the difference in performance between a FOB tune and a base tune?
  8. Feb 19, 2020 at 5:46 PM
    M1Awolf
    Rob
    Montana
    I couldn't tell you,I have always run the FOB tunes and 91.
  9. Feb 19, 2020 at 6:01 PM
    CorbinDallas
    CorbinDallas Well-Known Member
    Corbin
    Tacoma
    16 MT OR
    All around better, IMHO. I think I'll flash back to it till 2.0 comes out. I'm on a beta 2.0 now but need a reminder of fob file
    Melmantaco likes this.
  10. Feb 19, 2020 at 6:09 PM
    Marcus6867
    Marcus6867 Well-Known Member
    Marc
    Northern Virginia
    2017 Barcelona Red Tacoma
    Anyone have issues with this ? I think this is next on the mod list. Just worried what it does long term—any codes or issues. Seems like tons of people are using it.
  11. Feb 19, 2020 at 6:25 PM
    Marcus6867
    Marc
    Northern Virginia
    Just want to see if anyone has had any codes or issues with the OV tune being run. Just want to see if anyone has had issues with it before I splurge on the tune. Also was going to regear later.
  12. Feb 19, 2020 at 6:34 PM
    Marcus6867
    Marc
    Northern Virginia
    Awesome! Thank you. I appreciate your help!
  13. Feb 19, 2020 at 7:46 PM
    Tacoma816
    Tacoma816 Microwaving a cantaloupe, you know why
    I-70E KS exit 336 rest stop, 2nd stall
    Fred and Ginger
    custom interior stains
    lol she said tit
    Shellshock likes this.
  14. Feb 19, 2020 at 8:11 PM
    Marcus6867
    Marc
    Northern Virginia
    Ha! Fixed the typo
  15. Feb 19, 2020 at 8:43 PM
    06ltd
    06ltd Well-Known Member
    Maryland
    2019 TRD OR 6MT
    This is the internet, if there were issues the threads would be stacked at the top of the forum. The true testament of a product is how petty the bitching about it is lol
    iexc, tonered, Tacoma816 and 2 others like this.
  16. Feb 19, 2020 at 8:45 PM
    Shellshock
    Iowa
    Nope you’ll be fine.
    the only people that have issues are the ones that can’t read and follow directions
  17. Feb 20, 2020 at 4:51 AM
    Marcus6867
    Marc
    Northern Virginia
    Thanks man. Kind of what I figured. I know a lot of people run the Ov tune And only a few issues. Did not want to be one of those few, LOL.
  18. Feb 20, 2020 at 5:06 AM
    xxtavixx
    xxtavixx Well-Known Member
    Jacksonville fl
    2018 6MT
    ARB rear locker OVtune Mobtown sliders Core-shifter short throw Trd bro-phony grill Caliraised bumper light bar Caliraised ditch lights Rigid ignite back up lights FN Five Star 16x8 Et0 255/85/16 cooper st maxx MesoJDM fuse box cover MesoJDM led interior lights Bilstein 6112 fronts Bilstein 5100 rears Headstrong 3 aal Toytec 3* shims Mesjodm dome and map lights Diode dynamix ss3 pro yellow Mobtown aluminum front skid 2lo mod SOS front recovery point
    Sorry for a dumb question here. I downloaded the beta file, but I cannot figure out how to get it to show up in flash manager.
    im the corded dongle
  19. Feb 20, 2020 at 5:32 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You just used PCM flash and look for the file on your computer (like on the Desktop) when it prompts you.
    CygnusX191 likes this.
  20. Feb 20, 2020 at 5:41 AM
    xxtavixx
    Jacksonville fl
    2018 6MT
    you mean I do it like every other file? Sigh. Thanks. Its been a while since I did a flash and my memory was off
    pinochle and tonered[QUOTED] like this.
Thread Status:
