2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Feb 20, 2020 at 7:56 PM
    CdnSldr
    CdnSldr ______________
    Canada Eh!
    @fake4x4
    yup. The trick to that is to remove the 90* barbed fitting from the Core base unit, install it on the line with everything removed, then jamb the barbed fitting back into the little grommet on the base after the shifter is in place.
    CygnusX191, TacoTim85 and tonered like this.
  2. Feb 20, 2020 at 8:01 PM
    su.b.rat
    su.b.rat broken truck
    and do you have silence as a result?
  3. Feb 20, 2020 at 8:05 PM
    CdnSldr
    Canada Eh!
    Silence?
    No, the shifter is actually quite a bit louder than anticipated. Truck only has about 150kms total on it, so hopefully the driveline noise transferred through the shifter will decrease with break in. Some sound deadening wrapped around the stick and under the console might be in order. That might be why the oem stick is so damn thick. Harmonics
    The was quite the air pressure different when that line disconnected. Not sure if it was vacuum or pressure.
    The slight whine of the shifter combined with the 3500rpm power surge REALLY helps me imagine I’m boosted!
    AKGSD and su.b.rat[QUOTED] like this.
  4. Feb 20, 2020 at 8:44 PM
    fake4x4
    fake4x4 Well-Known Member
    Los Angeles, California
    3rd Gen Tacoma TRD Off-Road DCSB
    Cool stuff
    now I gotta go back in and try this
  5. Feb 20, 2020 at 9:22 PM
    TacoJeff19
    TacoJeff19 Well-Known Member
    Jeff
    19' DCSB OR
    OVtune, ADM, Hurst Short Throw.
    I'd say mine is pretty loud. Not damn loud but not slightly loud either. I may just need fluid change
  6. Feb 20, 2020 at 9:23 PM
    TacoJeff19
    Jeff
    19' DCSB OR
    In your picture you posted. The reciever of the shifter foot shown looks like it's broke or something inside it? Is that just some optical illusion?
  7. Feb 20, 2020 at 9:51 PM
    CorbinDallas
    CorbinDallas Well-Known Member
    Corbin
    Tacoma
    16 MT OR
    Curious why you choose this over the URD short throw? How long have you had this? What benefits have you experienced vs stock?
  8. Feb 20, 2020 at 10:07 PM
    TacoJeff19
    Jeff
    19' DCSB OR
    I have one in my taco and it's the entire shifter. knob, stick, and base, down to where the shifter base bolts to the trans. You get a much more direct and solid shifter. I also had one in my Chevy k1500 it is a phenomenal shifter
  9. Feb 21, 2020 at 4:18 AM
    CdnSldr
    Canada Eh!
    I believe that piece is cast to allow oil to splash and drain out the bottom rear of the cup. The light I was shining accentuates the casting/machining.
  10. Feb 21, 2020 at 4:25 AM
    CdnSldr
    Canada Eh!
    @St.Germain can certainly weigh in on this.
    Ever thing I read lead me to believe the Core shifter was slightly superior. I picked this one up on marketplace, practically brand new, for a nice discount.
    Shift throws are greatly reduced. Even shorter than Marlins short shifter I had on my 2000 4runner (R150f).
    I’ve only put about 40kms on it since install. ADM plus OVT will be icing on the cake.
  11. Feb 21, 2020 at 5:32 AM
    su.b.rat
    ya mine is loud, much louder at times and silent at times. i think temps are the deal.
    anyway the two shifters are totally different. the URD is basically a sightly tighter version of stock. it's good in the beginning then degrades and is essentially stock but shorter. it was better than stock but weak sauce. not a fan after say 12 months. too soft and wonky. i have a stock shifter with URD on it available if anyone wants it, about 2 years on it.
    the Core is a single piece solid shaft so is much firmer, less degradation, and a lot more NVH. but if you like it clean and mechanical, this is the one.
    it's so mechanical that i replaced my 700g knob with one under 200g. it has slowed down my shifts significantly, because i don't like rushing through mechanical linkage but prefer to ease through it without force. has a bit of a bolt-action feel and has stayed clean in a few months of use.
    also the shifts are quite short on the Core which allowed me to run an extension and still have good ergonomics.
  12. Feb 21, 2020 at 5:48 AM
    Tacoma816
    Tacoma816 Microwaving a cantaloupe, you know why
    I-70E KS exit 336 rest stop, 2nd stall
    Fred and Ginger
    custom interior stains
    AMEN SISTER :wink:
    AKGSD and CygnusX191 like this.
  13. Feb 21, 2020 at 5:52 AM
    CdnSldr
    Canada Eh!
    NVH was the acronym I was looking for! Hah (noise, vibration, harshness)
    So weirdly enough, the noise increases when I’m holding the knob..
    su.b.rat[QUOTED] and TacoJeff19 like this.
  14. Feb 21, 2020 at 5:54 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Sounds great to me.
    su.b.rat[QUOTED] and CdnSldr like this.
  15. Feb 21, 2020 at 7:17 AM
    su.b.rat
    same! weird, right? i thought i had a vibration in the extension's bits. guess not.
  16. Feb 21, 2020 at 12:42 PM
    Mike2121
    Mike2121 Club-Coma
    Michael
    Georgia
    2018 MGM Tacoma TRD Sport 4X4 M/T
    TRD Cold Air Intake TRD Manual Transmission Shift Knob Tacoma All-Weather Floor Mats Tacoma Center Console Organizer Tacoma Roof Rack Tacoma Tri-Fold Tonneau Cover TRD Exhaust TRD Pro Fox Shocks (front & rear) TRD Matte Grey 17" Wheels 265/70/17 Falken Wildpeak Tires OV Tune SFOB Premium Tune Accumulator Delete
    Ok folks don't get mad if this has already been asked and answered. I do my best to follow this thread and I haven't seen it answered but any official release date on 2.0?
  17. Feb 21, 2020 at 12:43 PM
    su.b.rat
    NO!
    "official release date" has never happened with OV, has it?
    CygnusX191 and tonered like this.
  18. Feb 21, 2020 at 12:47 PM
    Mike2121
    Mike2121 Club-Coma
    Michael
    Georgia
    Well I thought I read something a while back it was coming on Christmas day, but then that got pushed back due to injury..
  19. Feb 21, 2020 at 12:51 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    I have a prediction. We are NEVER going to get 2.0. Not going to happen.
    TacoJeff19 and Tacoma816 like this.
  20. Feb 21, 2020 at 12:55 PM
    Shellshock
    Iowa
    It was. Then he fell on the ice and got broken
Thread Status:
