2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Feb 29, 2020 at 10:05 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Dood! Whip it in there and give it a shot. It may not be perfect with the Dump Tubes, but I bet you still smile.
    Shit. You need the PCM file. Sorry!
    CygnusX191 likes this.
  2. Feb 29, 2020 at 11:37 AM
    basshole
    basshole Well-Known Member
    chicagoland
    2018 OR MT
    The single torque map does feel much like throttle cable, especially at low rpm.
    26F Cold start cold drive to work this morning I still had a few bucks in 2nd gear.. Let's hope final 2.0 clears this up. If it doesn't, I'm chalking it up to cold engine characteristics of this platform. It's not a big deal, clears up after a couple blocks.
    Is it possible DFCO causes this..? Only happens in 2nd gear, low rpm shifts, 30F and below.
    tonered likes this.
  3. Feb 29, 2020 at 11:41 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    DFCO is only active when coasting for more than a couple seconds.
    The throttle was always extra sensitive on my unicorn during enrichment since day one. It is just making a lot of power on that extra fuel.
  4. Feb 29, 2020 at 11:51 AM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    @OVTune Mat I have a simple request and I think a lot of the guys that purchased the catless tubes would agree. Could you please make the 2.0 catless tune a full out performance FOB/BFO/Fat kid tune,we deleted the cats for performance gains,might as well make the best of it ;) I think 91 and 93 versions would be ideal....OLE would be fine too.
    su.b.rat and tonered like this.
  5. Feb 29, 2020 at 12:11 PM
    basshole
    chicagoland
    2018 OR MT
    This does make a lot of sense when you think about open loop control during warm up. I mean I could just let it idle a couple minutes. But it's hard beating old habits of jumping in driving. Part laziness, part why not use the fuel to drive instead of idling.
    tonered[QUOTED] likes this.
  6. Feb 29, 2020 at 12:24 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Same here. It warms up way faster driving, esp trucks with larger cooling systems.
    For a while when new, I was catching myself out on that 1-2 shift a lot, esp near work where there was a fun corner.
    I know folks who wait 5 to 10 minutes before hopping on their bikes. My motor is almost to thermostat opening within 1.5min of easy riding, in the winter.
  7. Feb 29, 2020 at 2:38 PM
    TacoJeff19
    TacoJeff19 Well-Known Member
    Jeff
    19' DCSB OR
    OVtune, ADM, Hurst Short Throw.
    Any updates on the 2.0? Really excited for it !
  8. Feb 29, 2020 at 2:47 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    2nd gear, cold engine, bucking that you are talking about.
    Does this happen when Driving, or initially getting on the throttle?
    Because there is an initial fuel spray adder that is injected when throttle is applied.
    Lowering this value can cause bucking when fuel is applied. Increasing the value smoothens it.
    I'd wager at very cold engine temps you need more fuel when first applying throttle
    CygnusX191, Shellshock and tonered like this.
  9. Feb 29, 2020 at 2:56 PM
    Tacoma816
    Tacoma816 Microwaving a cantaloupe, you know why
    I-70E KS exit 336 rest stop, 2nd stall
    Fred and Ginger
    custom interior stains
    to be fair, if you sprayed me with your hot fuel, I’d definitely buck all over the place.
  10. Feb 29, 2020 at 2:57 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    For me, it is when initially getting on the throttle after a 1-2 shift. The truck just wants to boogey if I give it a bit too much throttle, which makes it a rough shift. Most all of the time, I don't get on it with a cold motor and have trained my foot to not get in it that deep. Sometimes I over do it though.
    Shellshock likes this.
  11. Feb 29, 2020 at 3:11 PM
    M1Awolf
    Rob
    Montana
    Can vouch for this,if you hit it just right the truck just comes alive,I wish it ran like that in all gears. I would say the rough shift is operator induced...
  12. Feb 29, 2020 at 3:12 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Exactly. But at that level of enrichment, we'd be filling up every 200mi.
  13. Feb 29, 2020 at 3:23 PM
    M1Awolf
    Rob
    Montana
    You don't already...? I get about 13mpg on winter gas/cold tempsrpyqxrxKyMXHnavCpZzV.gif 17-19 once we get the good gas and warm weather. Of course I am rolling heavy @5300# on 32" E plys as well.
  14. Feb 29, 2020 at 3:30 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Hahahaha! The tunes do seem to eat more fuel in colder starting temps. Not sure why with how good they do otherwise. But, I'm still hanging around 19mpg these days with it coming up for the warmer mornings and the One Map tune.
    With summer blend and temps, I'm expecting 21-ish?
    The one size larger SL Wildpeaks maybe stole 0.5mpg? They have paid back hugely in other ways though.
    Shellshock and CygnusX191 like this.
  15. Feb 29, 2020 at 3:49 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    You've gotta have something else going on to get it that bad... armor etc?
    tonered likes this.
  16. Feb 29, 2020 at 4:11 PM
    M1Awolf
    Rob
    Montana
    Yes,almost 1k# over curb weight on heavier,taller E ply's,speedo is calibrated with hypertech module for tire size. My daily drive to work is exactly 1 mile one way. I would burn more fuel letting it get to operating temp than I do just hopping in and driving there..lol. I get better on the highway once it is warmed up but winter gas never gets me over 17
    2017 Toyota Tacoma TRD Off Road Manual 4WD Double Cab Short Box/Curb weight is 4,445 lbs. I am just a bit over 5300#'s
  17. Feb 29, 2020 at 4:17 PM
    basshole
    chicagoland
    2018 OR MT
    My 2018 has done this in cold temps with factory tune, fob, beta, single torque. Bucks the worst while driving- low rpm 1-2 shift, say after a stop sign in town. If I feather the throttle, it doesn't do it. It clears up after a couple stop signs.
    CygnusX191 and tonered like this.
  18. Feb 29, 2020 at 4:17 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is still a lot better than you would get in other trucks and you still get to smile while rowing.
    M1Awolf[QUOTED] and CygnusX191 like this.
  19. Feb 29, 2020 at 4:22 PM
    Shellshock
    Iowa
    @M1Awolf is a fat kid. Just like @RedBeard1
    tires, lift, steel armor, etc. they are heavy
    tonered and CygnusX191[QUOTED] like this.
  20. Feb 29, 2020 at 4:25 PM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Thank god I'm just chunky and not fully obese :thumbsup:
    tonered and Shellshock[QUOTED] like this.
Thread Status:
