2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Apr 10, 2020 at 8:43 AM
    Shellshock
    Iowa
    I turned av off lol I wouldn’t know
    CygnusX191 and tonered[QUOTED] like this.
  2. Apr 10, 2020 at 8:47 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I had no problems flicking it off and on, but usually there is more than one setting that needs to be disabled for it to go smoothly.
    CygnusX191 likes this.
  3. Apr 10, 2020 at 8:51 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    CygnusX191 and pinochle like this.
  4. Apr 10, 2020 at 8:59 AM
    Lutrev
    Lutrev Well-Known Member
    2018 MT black pro
    2.0 SFOB OV tune, ADM, MESO v4,stage 1 tail,maps and dome,etc
    V14, I tried a couple times, may have missed a step,but could not get it going till I did the file swap? The other thing with mine is the key would not copy so I had to enter the bazillion digit code manually. It’s all good, just took some time which I have way too much of these days.
    Not interested in any customization features, just very happy to be on the updated tsb file as a base for the tunes.
    In hindsight OVTune should have only released tunes for the latest tsb and cut his workload in half
    tonered likes this.
  5. Apr 10, 2020 at 9:02 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Interesting. There is no file swap with V14. That was the V12 trick.
    For the code, you have to chose North America code and the other step that I am forgetting. It has been a while and I only did it once.
    As long as your good to go, that's all that matters. Enjoy the new tunes.
  6. Apr 10, 2020 at 9:09 AM
    92ehatch
    92ehatch Well-Known Member
    Kinley
    Hendersonville NC
    2019 Cavalry Blue DC TRD OR 6MT
    I loaded premium base this morning and drove around a bit.
    I don't notice any difference between the two honestly.
    I like sfob, but figured why not taste all the flavors.
    What difference is there supposed to be?
  7. Apr 10, 2020 at 9:12 AM
    Lutrev
    2018 MT black pro
    Yes, I added a useless step, probably pasted the same file over itself?
    tonered[QUOTED] likes this.
  8. Apr 10, 2020 at 9:20 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Maybe? Hahahaha!
  9. Apr 10, 2020 at 7:26 PM
    Akelroy
    Akelroy Member
    2019 O/R 6 M
    Ko2's, lights
    Just loaded 2.0 Premium FOB on my 2019 O/R Manual, and I am impressed. Pulls very smoothly at part throttle, much more so in the higher RPM range than the prior tune. I had to indulge the higher rev limit on a few hard 1-2 shifts, and got lots of 2nd gear rubber. After running the 91 1.05 tune that I purchased for towing a 4,000 Winnebago Mircro Minni for the last 4 months, I was not expecting 2.0 to be a huge improvement. I had no complaints with the last tune, and was actually a little worried that 2.0 would affect the availability of low-end torque that really made it much easier to tow. I haven't towed with 2.0 yet, but so far I am impressed. The truck is straight up fun to drive now.
    pinochle, CygnusX191, mZiggy and 2 others like this.
  10. Apr 10, 2020 at 9:25 PM
    Lutrev
    2018 MT black pro
    Yup, I actually smoked my clutch a little, was shocked at burning rubber in second gear and slipped the clutch for the evil smell.7k 1-2 shift.
    DOH
    :annoyed:
    Junkhead likes this.
  11. Apr 14, 2020 at 12:20 PM
    Shellshock
    Iowa
    if you have one of the older versions of Flash manager, you'll need to uninstall it and get the new one. download and hit update. then you should be able to grab it
    same issue I and some others had.
    https://www.ovtuned.com/blogs/news/...d-with-new-logger?_pos=4&_sid=c38053d2b&_ss=r
    tonered and CygnusX191 like this.
  12. Apr 14, 2020 at 12:52 PM
    Shellshock
    Iowa
    I just went into add / remove programs and uninstalled it.
  13. Apr 14, 2020 at 12:58 PM
    Shellshock
    Iowa
    nope. just download it and install it and hit update. its much simpler now than it used to be
    well and hit the button for install all software.. I had dongle software so I didnt have to do that.
  14. Apr 14, 2020 at 1:42 PM
    Shellshock
    Iowa
    you've got the reg key already so you'll be set
    Melmantaco, tonered and CygnusX191 like this.
  15. Apr 14, 2020 at 2:06 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Lol. @Shellshock knows what he's talking about, no worries mate.
  16. Apr 14, 2020 at 3:56 PM
    Jon760
    Jon760 Well-Known Member
    2016 TRD Sport 4x4 MT
    265/70 R17 Nitto Terra Grappler G2 on TRD Pro wheels BAMF Grill
    I don’t have dongle and had to un install and re install truck to get 2.0 base, it was fine. All the registry stuff is saved.
  17. Apr 14, 2020 at 3:56 PM
    92ehatch
    Kinley
    Hendersonville NC
    I had the same problem.
    Didn't even uninstall the old software, i just downloaded the new one and it worked fine.
    Btw, I've been running 2.0 93 base for the last week or so.
    At first i felt no difference, but as the week progressed I noticed that base is way smoother. Throttle is not as jumpy and no perceived lost power.
    Mpg did increase slightly but it had been warmer and i have my soft topper off. So I'm not sure if that even counts.
    I'm extremely happy with 2.0
  18. Apr 14, 2020 at 4:21 PM
    deemiller
    deemiller Active Member
    Dustin
    2017 TRD Pro
    I have the same issue. I guess I’m fine with sfob 2.0 because gave up trying to download the base.
    Melmantaco likes this.
  19. Apr 14, 2020 at 4:24 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Download the updated flash manager and go for it. Should work fine
    tonered and Shellshock like this.
  20. Apr 14, 2020 at 4:40 PM
    Lutrev
    2018 MT black pro
    Same here, had to update, wanted to download all files to have them, in case anything goes more sideways then it already is. Was an easy 5 minute process
Thread Status:
