2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Oct 20, 2017 at 8:53 AM
    #161
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Can he take all his luggage with him?
    Disclaimer: I've mucked up my share of threads before, TBH :anonymous:
    Reypac24, 17TRDOR and su.b.rat like this.
  2. Oct 20, 2017 at 8:54 AM
    #162
    su.b.rat
    su.b.rat broken truck
    hey a little entertainment goes a long way. even w/o Dylon. :p
    Doggman and MOC221_ like this.
  3. Oct 20, 2017 at 8:55 AM
    #163
    MOC221_
    Frank
    Dylon didn't make me want to hulksmash my monitor though!
  4. Oct 20, 2017 at 8:55 AM
    #164
    Cold_Toad
    Cold_Toad Well-Known Member
    But but but, he's an engineer.
    02Duck, Reypac24, 17TRDOR and 2 others like this.
  5. Oct 20, 2017 at 8:56 AM
    #165
    68injunhed
    68injunhed Well-Known Member
    Jeff
    SE Kansas
    2018 SCrew F150
    A couple things
    Oh he's waaaay smarter than you....Just ask him.;)
  6. Oct 20, 2017 at 8:56 AM
    #166
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    My truck shipped with a bad CKP the dealer refused to diagnose and replace after repeated attempts. The result? Nasty tailpipe emissions from by brand new truck, smelly and sometimes nearly black. eventually a rough idle the dealer continued to say was "normal" I replaced the sensor on my own dime = problem solved. on stock tune my truck was always slamming into gears harshly (can't be good for the truck!?) and smothering itself... press down on pedal, nothing happens, then suddenly it realizes you wanted to GO and slams into 4th at 5k RPMs. nothing in my mind says MY truck was anything other than a hot mess of pollution and inefficiency as delivered by Toyota. Between the sensor replacement, cleaning my oily (from the factory) MAF, and tuning for a cleaner more linear burn I have recovered from the BS Toyota handed me.
    Toyota would have had me driving around in a smog machine until it stalled on the freeway...
    speedtre likes this.
  7. Oct 20, 2017 at 8:57 AM
    #167
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    So am I, the difference is common sense.
    Reypac24, MOC221_ and tonered like this.
  8. Oct 20, 2017 at 8:58 AM
    #168
    su.b.rat
    not stirring the pot here, i have a couple things for you.
    first, the moderator's "bye now" comment was an invitation to keep on repeating yourself, which will get you banned, like RIGHT NOW.
    second, your comments about flashing and the dealers and what have you are uninformed. the info is available in the OVTune Alpha thread. you'll need to spend hours going through it like we have to get some answers. in the meantime if you value your ability to dialog here, stop repeating what you've already clearly expressed. please.
    MOC221_ and nevadabugle like this.
  9. Oct 20, 2017 at 8:58 AM
    #169
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Oh crap. I'm an engineer also. . .
    I hope nobody heard that.
    taco 16 and micwillia like this.
  10. Oct 20, 2017 at 8:58 AM
    #170
    Sociopenguin
    Sociopenguin 2 Fang Engineering
    Tate
    NW MO
    DevilPenguin
    Schtuff
    :bowdown:
    MOC221_ likes this.
  11. Oct 20, 2017 at 9:01 AM
    #171
    TC_Mic
    TC_Mic Well-Known Member
    State of confusion, aka Flori-duh
    2017 Silver Sky 2x4 Limited
    AMP Powerstep, UC Flex, bed lights, Opt7 Tailgate bar, black tailgate lettering Pending: re-configure tail light,s custom storage pocket bags, pinch weld painting, blackout badges, ......
    @tonered I always thought it would be coold to drive a train. :rofl:
  12. Oct 20, 2017 at 9:01 AM
    #172
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    "Engineer"
    And my wife is a professional Instagram model and I'm a professional Forza race car driver.
    TurdGenBrah, 02Duck, Murkules and 9 others like this.
  13. Oct 20, 2017 at 9:02 AM
    #173
    bshammer0
    Brandon
    Nashville, TN
    My response? B/c I clear the learning by disconnecting my battery terminals periodically because I hate the way the truck "learns" shifting behavior over time. Honest answer as something I've done multiple times well before the tune! I also have a TIS subscription and have used it to flash w/ Toyota's stuff. OVs tune behaves just like a TIS reflash (as stated in the dev thread) and our warranty is NOT void by using TIS
    MOC221_ likes this.
  14. Oct 20, 2017 at 9:05 AM
    #174
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    MOC221_ and TC_Mic[QUOTED] like this.
  15. Oct 20, 2017 at 9:06 AM
    #175
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    I'll break down and respond to your entire message. Once.
    Homologation testing on my tune has not been done, and it is not necessary. I have worked with companies that need homogolation testing done and it is almost always when a hardware part is changed and the software is set to match. If you aren't aware, our tunes are developed to work with stock vehicles. Where no hardware emissions component is touched.
    Nothing inside the ECU that are the main controls of emissions standards are changed (like cam phasing for psuedoEGR), Catalyst safety margin tables, EGT temperature control, etc.
    As I said in a previous page, and something an automotive engineer should be well aware of... is that almost all harmful emissions from vehicles these days are during cold start. Cold start control in our tune is left stock. Catalytic converters are very good at what they do in this day and age, and driving around at operating temperature produces much less. A majority of what we do in our tune is changing the driving characteristics through auxiliary controls, Like changing throttle opening dynamics. Changing the dynamics of the throttle doesn't change anything that comes out of the exhaust. Neither does changing how the transmission shifts in the AT.
    I don't think you actually know that much about CARB or the CARB certification process, if you truly cared about emissions and the environment you'd want CARB changed. Many things get carb certification that are nowhere near the standard of OEM.
    I am a 3rd party company that is not in any way affiliated with Toyota. Are you aware that the entire reason of reversing code is to understand it? Are you also aware that in certain manufactures the "logic" and math involved with the calibrations are identical throughout, and once you reverse and understand one, you're not going in and "reverse-engineering code they don't really understand." I'm sure you also know that nearly all ecus have the same controls and basic pathways for controlling an engine.
    I don't think it raises any questions. This is America, not a communist country where you are only allowed to buy "state approved" car modifications for your off-road / race vehicle. Take california as an example. They are Regulation Zealots. But has it actually fixed the problem?
    Are you aware that one of the main contributors to harmful emissions into our atmosphere is the beef industry? Do you protest farms?
    How much do you know about the toyota ECU? Just because ecu "A" is easy, doesn't mean ecu "b" is identical. Like bosch ECUs with T-PROT protection. Just because bosch has T-PROT does that mean some obscure ECU out of a suzuki swift does?
    A dealer can ask you any question they want. Why do you have those wheels. Why did you install that suspension. Why did your ecu get flashed. What they can't do is deny your warranty because they see a modified part or suspect a modification.
    thanks.
  16. Oct 20, 2017 at 9:10 AM
    #176
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    Dude if you don't want to buy it then don't come on the thread for customers of OVTuned and talk shit about it.
    Side note you're wrong about the tuning. The only reason it runs the way it does from the factory is because Toyota is held to very strict regulations. The regulations on the automobile producing industry are stricter than the rules for cars on the road for a variety of reasons (people own old cars, people mod their cars, govt can't force people to buy a new car or a fuel efficient one but they can force a company not to make them), meaning that without directly breaking the law one can modify their car beyond the way it was produced. It also means that manufacturers leave a lot on the table ONLY for the purpose of making vehicles more emissions friendly. A car running rich actually produces fewer NOx emmissions than a car running lean, which is a higher concern than CO2 emmissions. While it is fairly common knowledge that a car running rich also is in general more reliable than one running TOO lean, running 12.4-12.7 AFR is far from too lean. Also, running too lean is only dangerous when you have no way to control it and keep it cool, but this truck has no such problems with it's massive crank driven fan and HUMONGOUS radiator, as well as auxiliary coolers for other important systems, and coolant veins that run through the engine block and even around the exhaust headers before they exit the block. Not to mention forged crank, conrods, and pistons from the factory to limit thermal expansion differences which could eventually lead to reliability/performance issues. Toyota has built in failsafe after failsafe to make this truck bulletproof, and without sacrificing hardly anything to that end, Matt at OVTuned has worked tirelessly for months now to perfect the ECU tuning of this truck and many other vehicles from the DRIVERS perspective, not the Govt's perspective or anyone elses. If it's not your cup of tea then nobody said you had to buy it. We all did, and we all enjoy the results of our purchase, and speaking personally I would recommend this tune to anybody who owns the truck purely for the reason that the vehicle is much easier to drive and more predictable with the tune, which make it safer to drive. It's also faster, and sounds better too so I see no downside.
    Not the thread for your opinion of the product anyway, nobody asked.
  17. Oct 20, 2017 at 9:16 AM
    #177
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
  18. Oct 20, 2017 at 9:18 AM
    #178
    stevotivo12
    Stephen
    I can confirm, have been getting factory maintenance done for 5k miles including now two factory services without so much as a question about the engine tuning. The tech did say it was the best driving Tacoma he's seen so thanks again @OVTune
    2016trdtacoma, MOC221_ and tonered like this.
  19. Oct 20, 2017 at 9:20 AM
    #179
    stevotivo12
    Stephen
  20. Oct 20, 2017 at 9:26 AM
    #180
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Reypac24, MOC221_, Boxerocks and 10 others like this.
Thread Status:
