2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. May 8, 2020 at 10:05 AM
    crigg93
    crigg93 Well-Known Member
    Chuck
    Rochester, NY
    2018 M/T MGM TRD Sport
    Ovtuned, Rokblokz, Toyo A/T II's on F5s, URD U-Spec, Afe Intake, Fox shocks, Dirtking UCAs, KC Flex ambers.
    Nice, that just so happens to be what I am. order placed!
    tonered likes this.
  2. May 8, 2020 at 10:07 AM
    Shellshock
    Iowa
    The ovtune homepage
    tonered and Melmantaco like this.
  3. May 8, 2020 at 10:10 AM
    crigg93
    Chuck
    Rochester, NY
    Karminski likes this.
  4. May 9, 2020 at 8:37 PM
    CorbinDallas
    CorbinDallas Well-Known Member
    Corbin
    Tacoma
    16 MT OR
    So is there any value in getting vf tuner since 2.0 is out?
  5. May 9, 2020 at 9:07 PM
    Shellshock
    Iowa
    If you want to customize. Shift points, throttle sensitivity, charging output, anything else your heart desires
    CygnusX191 likes this.
  6. May 10, 2020 at 8:34 AM
    CaptainVoodoo
    CaptainVoodoo Well-Known Member
    Charles
    Quebec
    2019 TRD Pro Voodoo Blue M/T
    None yet
    I imagine it's not so simple to use, not as plug and play as the Flash Manager. I saw Matt posting on FB about a learning course or something for VF Tuner, not sure if it was for basics or for more advanced users.
  7. May 10, 2020 at 8:42 AM
    Shellshock
    Iowa
    He’s intending to make some of the common things as simple as possible.
    most people aren’t gonna go crazy, it’s gonna be the small tweaks people fight over constantly that most will adjust, not all the other stuff. I think shift points and tip in are top of the list
    people can also share files so that’ll help too
    CygnusX191 and TacoTim85 like this.
  8. May 10, 2020 at 8:43 AM
    crunchytaco13
    crunchytaco13 Well-Known Member
    ‘17 PRO MT Cement
    TRD CAT
    Is there going to be some acclimation period after tuning where I should (or shouldn’t) drive a certain way? Any other thing to note after tuning?
    @Shellshock anything you’d recommend here?
  9. May 10, 2020 at 8:50 AM
    CaptainVoodoo
    Charles
    Quebec
    None yet
    Say no more.
  10. May 10, 2020 at 9:15 AM
    Shellshock
    Iowa
    You can drive however you want but I generally expect some weirdness for the first 100-400 miles while things settle in. It’s not always the case but sometimes you’ll get some weird behavior right after flashing and trims are initializing.
  11. May 10, 2020 at 9:30 AM
    crunchytaco13
    ‘17 PRO MT Cement
    TRD CAT
    What can I expect within the category of “weirdness”? Is there anything to keep an eye out for that would be more than normal weirdness?
    MOC221_ likes this.
  12. May 10, 2020 at 10:31 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Probably seem some goofball in your rearview mirror looking back at you for a bit.
    moondog1 likes this.
  13. May 10, 2020 at 11:04 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    You may experience unsteady idle (goes away quickly) and usually some odd surging when you get on the gas. You're also accustomed to stock "squishy" throttle mapping, so it may seem like your footwork is off when shifting... and it is lol.
    After tuning and idling for a few minutes, I like to drive around normally on back roads and then do a few hard pulls to let her work on the knock correction lol.
    I'll also do a highway run to help sort her out.
    Very unscientific, but fun.
  14. May 11, 2020 at 10:02 AM
    Shadowmachine
    Shadowmachine Well-Known Member
    Ken
    Saltsburg Pa
    2018 inferno dcsb 6mt
    Baby lift, carven muffler, s&b intake, jba uca, ovtune
    Thinking I might try to update my ECU on my own. The surging...or explained "bumpy road" feeling is my only gripe...albeit a very small one and even if it persists I wouldnt ever leave the 2.0 file. Anyone else getting said feeling on the '18 ECU calibrations? Ive been dragging my feet because ive been exhausting myself trying to find a decent alignment shop... 3 times ive had it to places and it still destroys the driver front like ive never seen before on anything ive ever had....turrible
  15. May 11, 2020 at 10:05 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    You sure it's not your alignment causing the bumpy road feeling?
  16. May 11, 2020 at 10:09 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    A lot of folks noted improvements going to 04A71. But, I don't think the bumpy road feeling was posted as a problem before or after. That is usually an AT thing with the TC cycling.
  17. May 11, 2020 at 10:49 AM
    Shadowmachine
    Ken
    Saltsburg Pa
    Id tend to agree but it only seems to do it while accelerating, more pronounced if im pulling a grade...but only in a small rpm window, then it goes away... Almost feels like a tiny parachute behind the truck flapping around lol.
    tonered likes this.
  18. May 11, 2020 at 10:50 AM
    Shadowmachine
    Ken
    Saltsburg Pa
    Id have to actually see when it does it, but its very subtle...just enough that i notice it, ive been told that I read to much into vehicle behavior, so it might just be me...being me
    CygnusX191 and tonered[QUOTED] like this.
  19. May 11, 2020 at 10:57 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Some folks are sensitive to vibes and rattles. Other folks are not. And, there's a big spectrum between those.
    For me, there are some that I don't mind, but shit like unbalanced tires drive me crazy. OTOH, I know folks who say that they don't balance their motorcycle tires.
    It sounds like you isolated it and something is there. Give the ECU update a go. It is not much different than an OVT flash. You just want to be a bit more careful. I know the TSB flash was as big a change on my Taco as was OVT.
  20. May 11, 2020 at 11:36 AM
    Shadowmachine
    Ken
    Saltsburg Pa
    Its there, just a matter of what...i sat on the idea for awhile because im by no means knocking the tune, I just figured id holler and see if anyone else had any input..my to-do list is getting longer, the tundra went into limp mode on Saturday for the cursed secondary air system failure... I just have to quit being scared and just update the ECU myself haha.
Thread Status:
