2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Jun 18, 2020 at 6:52 AM
    jlkphoto
    jlkphoto Member
    Jeff
    2018 Cement Tacoma TRD Off Road Manual 4x4
    OVTuned. Redline oil. TRD Pro Front Skid Plate
    BTW, I can download sid_04A71_2.0_Prem_SuperFOB and I can download sid_04A71_2.0_Reg_SuperFOB but I still get an error when trying to download either of the BaseOL files.
    Any idea why this still happens after downloading the latest software?
    Thanks
  2. Jun 18, 2020 at 6:53 AM
    jlkphoto
    jlkphoto Member
    Jeff
    OK, thanks for that. Any idea why this latest software won't let me get the BaseOL files?
  3. Jun 18, 2020 at 6:55 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You need to update FM. Uninstall the existing version, install the new one, reinstall your REG file, hit the updates in the FM menus (purge, download all software, update . . .):
    https://www.ovtuned.com/blogs/news/ovtune-tacoma-flash-manager-overhaul
    b3itz and CygnusX191 like this.
  4. Jun 18, 2020 at 6:57 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Just saw this.
    You might want to do that dance again? Is the installation folder called OVTuned?
    CygnusX191 likes this.
  5. Jun 18, 2020 at 7:04 AM
    jlkphoto
    jlkphoto Member
    Jeff
    Yep, I see "OVTuned" when I do a system search.
    Weird, it lets me download the STOCK file for 04A71 also. It just errors when I try to get the BaseOL files???
  6. Jun 18, 2020 at 7:09 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is strange.
    Not being able to DL the Base tunes was a characteristic of using the old FM version. If you haven't, maybe try:
    Config Menu: Purge Local Data
    Config Menu: Install All Software
    Tuning: Install OVTune Cable Drivers
    Help: Update​
    Just spitballin' ideas?
    In case, the most current FM version is 1.3.0 and Toyota Flash Tool Version 1.3.2.
  7. Jun 18, 2020 at 8:27 AM
    Shellshock
    Iowa
    btw 04b14 is supported if anyone is waiting
  8. Jun 18, 2020 at 8:33 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Thank you, "king shit".
    :D
  9. Jun 18, 2020 at 8:33 AM
    Sociopenguin
    Sociopenguin 2 Fang Engineering
    Tate
    NW MO
    DevilPenguin
    Schtuff
    As in on FM?
  10. Jun 18, 2020 at 8:39 AM
    Sociopenguin
    Tate
    NW MO
    DevilPenguin
    Schtuff
    Yeah, just saw that reference. Eh, could definitely be worse.
    MOC221_[QUOTED] likes this.
  11. Jun 18, 2020 at 8:39 AM
    jlkphoto
    jlkphoto Member
    Jeff
    OK...success!
    I started from scratch and uninstalled everything I could find. Then went through the above, plus, I had to keep my anti-virus software from putting the file "p5flash_V1.2.2.exe" into quarantine.
    I now have all the current tunes for my ECU.
    Thanks tonered and others for the advice.
    tonered[QUOTED] and CygnusX191 like this.
  12. Jun 18, 2020 at 8:40 AM
    MOC221_
    Frank
    I think he should add it to his sig lol
    Sociopenguin[QUOTED] likes this.
  13. Jun 18, 2020 at 8:42 AM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    MT like
  14. Jun 18, 2020 at 8:44 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Awesome!
    You're welcome.
    :cheers:
  15. Jun 18, 2020 at 11:43 AM
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    Except this one isn't listed as a recall. My VIN doesn't come up on the nhtsb site, it only lists it using Techstream.
    CygnusX191[QUOTED] likes this.
  16. Jun 18, 2020 at 11:58 AM
    crunchytaco13
    crunchytaco13 Well-Known Member
    ‘17 PRO MT Cement
    TRD CAT
    just flashed superfob on b14 - do i reset LV and AT with the engine on, or just with the keys in the ignition? letting it idle right now for a few minutes before taking it for a spin
    **edit ** for reference i tried resetting values immediately after flashing w/o turning the car on first, or disconnecting, and it said it was unsuccessful
  17. Jun 18, 2020 at 12:02 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Just in case for the future:
  18. Jun 18, 2020 at 12:04 PM
    crunchytaco13
    ‘17 PRO MT Cement
    TRD CAT
    done. Is AT values for auto transmission?
  19. Jun 18, 2020 at 12:05 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. The AT Reset is not for us.
  20. Jun 19, 2020 at 5:39 PM
    Shellshock
    Iowa
Thread Status:
