2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Aug 9, 2020 at 4:24 PM
    Shellshock
    Iowa
    They are all better than stock lol
    mine doesn’t have the weird kick the stock tune did but I can definitely feel the power pick up as you climb in rpms.
    tonered and CygnusX191 like this.
  2. Aug 9, 2020 at 4:52 PM
    mrCanoehead
    mrCanoehead Well-Known Member
    Ottawa
    2018 DCSB Sport manual 3.5 l
    Would there be any way for this software to put the truck in 2WD Lo when I shift into reverse? My wife rides the clutch to keep it from going so fast, I just tell her to park it on the street so I can back it in myself.
  3. Aug 9, 2020 at 4:54 PM
    Shellshock
    Iowa
    No but that would be pretty awesome
    I use the 2lo mod from @lapoltba
    CygnusX191, Karminski and tonered like this.
  4. Aug 9, 2020 at 5:01 PM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Yeah it doesn't kick and lurch like it used to, but the boost in power is still not subtle on 2.0, at least not imo lol but it does happen smoothly I suppose.
  5. Aug 9, 2020 at 5:15 PM
    mrCanoehead
    Ottawa
    Truck knows when it's in reverse because it turns rear facing camera on. The rotary switch is just digital I/O to the ECU or some transmission controlller. It "should" be possible.
    AKGSD likes this.
  6. Aug 9, 2020 at 5:15 PM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    No way yet (but I'm not expecting it to be possible). Mat found 4x4 mode code bits in the ECM but hadn't determined if they were for status reporting or control. I am pretty sure it is only for status. All the 4x4 mode selection is handled in the 4x4 ecu.
    CygnusX191 and tonered like this.
  7. Aug 9, 2020 at 5:24 PM
    mrCanoehead
    Ottawa
    Thanks. Could one of you come and teach my wife to back my truck up then. I am not allowed to use the phrase "you're doing that wrong," it makes her really mad.
  8. Aug 9, 2020 at 5:28 PM
    lapoltba
    CT - 06076
    Unfortunately no, reverse is just plain too tall in these trucks. I even have issues backing up in 2Hi sometimes. What I can do is sell you a 2LM harness that she should be able to learn how to use very easily.
    AKGSD, CygnusX191, Shellshock and 2 others like this.
  9. Aug 9, 2020 at 5:30 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    ^^^^^^^^^^^^ This.
    Just crept over the curb and up my driveway with no foot action yesterday to unload.
  10. Aug 9, 2020 at 5:57 PM
    Xer0 SiN
    Xer0 SiN Well-Known Member
    Hilo, HI
    19 TRD SPORT TACOMA / 21 LIMITED RAV4
    this and that...
    take the truck to an empty lot or a place that you can move around freely. get out and tell her to get in the driver seat. tell her put it in reverse, DONT PRESS THE GAS. with the brake and clutch pressed it, let the brake go completely. now slightly let the clutch go slightly, still no gas. keep going till you find its engagement point or "sweet spot". you can actually move the truck all by itself in first without even touching the gas. tell her do that till shes comfortable. when shes got the hang of it then she can start using the throttle. tbh the truck is very lenient in clutch engagement.
  11. Aug 9, 2020 at 6:00 PM
    Shellshock
    Iowa
    The issue is reverse. Going forward in first gear a monkey could drive this thing.
  12. Aug 9, 2020 at 6:08 PM
    mrCanoehead
    Ottawa
    She has been driving manual cars since the Reagan era, and I have no problem with her driving my 360 hp sports car. The problem is the reverse gear ratio on this particular truck.
  13. Aug 9, 2020 at 6:24 PM
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Tuned, geared, armored, BP51s...
    I've read the 2lo harness for reverse it a lifesaver. I need to invest.
    It would be slick if ovtune could do this somehow
    CygnusX191 and Karminski like this.
  14. Aug 9, 2020 at 6:32 PM
    Myles G
    Myles G Well-Known Member
    Myles
    How do people like the ADM with the tune
    Karminski likes this.
  15. Aug 9, 2020 at 6:35 PM
    lapoltba
    CT - 06076
    With or without the tune it is a worthwhile (and cheap) mod.
  16. Aug 9, 2020 at 6:35 PM
    Shellshock
    Iowa
    ADM + tune + 2lo are the 3 best mods for drivability. Highly recommend
  17. Aug 9, 2020 at 6:39 PM
    Myles G
    Myles
    I’ve had it for like 6 months not sure how to install or who to take it too. I’m really good at breaking shit. Just got it cause I knew he was gonna stop making them.
    Junkhead likes this.
  18. Aug 9, 2020 at 6:45 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Same here. I can break the unbreakable.
    But, just follow the instructions and you'll do fine. Just be sure to have a flare wrench.
  19. Aug 9, 2020 at 6:45 PM
    lapoltba
    CT - 06076
    Any good independent shop with a lift should be able to bang it out for an hour of labor. They may need some guidance on what you're trying to do, but it's not complicated. Just show them the tumor under the heat shield and hand them the hard line. Tell them to replace x with y and they should be good to go.
  20. Aug 9, 2020 at 6:50 PM
    TheSt|G
    TheSt|G Well-Known Member
    ‘05 M3, '19 TRD OR, ‘21 Type R
    CSL Bits
    Welcome to every car ever made, except that China MT Mustang.
    CygnusX191 likes this.
Thread Status:
