2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Oct 31, 2020 at 9:44 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
    You too.
    :cheers:
    Junkhead and CygnusX191 like this.
  2. Oct 31, 2020 at 10:14 AM
    su.b.rat
    su.b.rat broken truck
    just another chime in. vF is easy to use, and will ensure everything in the future for you is seamless if you continue to stay on top of your truck's stuff. it's worth the $79 and dongle trade. it will just be a bit inconvenient to wait for the trade, but 04B14 plain will to you right in the meantime.
    Junkhead, CygnusX191 and Shellshock like this.
  3. Oct 31, 2020 at 10:19 AM
    Shellshock
    Iowa
    If you do a dongle trade it’s $0. Dongleless upgrade is $79
    CygnusX191 and su.b.rat[QUOTED] like this.
  4. Oct 31, 2020 at 11:49 AM
    su.b.rat
    oh yeah, oops.
    CygnusX191 likes this.
  5. Oct 31, 2020 at 12:13 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    So, for someone on stock 0B14 this is a $380 package which then gets us a dongle? Dongle serves as license key and hardware to connect to the vehicle and all future updates are included?
    Then submit requests for specific tune files which are tied to the ECU and stock flash?
    And the difference vs stock for MT is significant?
  6. Oct 31, 2020 at 12:15 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    No. The dongles are dead. OVT wants them off the streets and is why no new tunes will come in PCM format.
    Oh yeah. Big time difference.
  7. Oct 31, 2020 at 12:40 PM
    daveeasa
    David
    PNW
    So $380, flash cable only, first post is out of date, pick octane then pick regular, hybrid or peak as far as performance goes?
    And the tradeoff is mostly a trade between performance and fuel economy?
    Also options to self tune by adjusting the tables using software for anyone feeling highly ambitious?
  8. Oct 31, 2020 at 12:55 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The License and Tactrix is $200 + $170. The Tune Pack is another $370.
    All tunes are Octane Learning now. The Prem and Reg are just ignition starting points.
    If have not found a trade off between power and economy. SFOB is the way.
    Yes. The tunes get even better with a few easy edits.
    CygnusX191 and daveeasa like this.
  9. Nov 1, 2020 at 4:18 PM
    GF8er
    GF8er Well-Known Member
    MT. Hood
    18 MGM DCSB TRD OR 6MT
    Off topic but what gear oil are you guys using in your 6MT and diffs?
    CygnusX191 and tonered like this.
  10. Nov 1, 2020 at 4:25 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  11. Nov 1, 2020 at 4:28 PM
    GF8er
    MT. Hood
  12. Nov 1, 2020 at 4:29 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Redline has done great things for me in the past. I got blocked out of 1st a couple times. That is gone.
  13. Nov 1, 2020 at 5:18 PM
    Shellshock
    Iowa
    I’ve got amsoil in mine
  14. Nov 2, 2020 at 8:53 AM
    Mike2121
    Mike2121 Club-Coma
    Michael
    Georgia
    2018 MGM Tacoma TRD Sport 4X4 M/T
    TRD Cold Air Intake TRD Manual Transmission Shift Knob Tacoma All-Weather Floor Mats Tacoma Center Console Organizer Tacoma Roof Rack Tacoma Tri-Fold Tonneau Cover TRD Exhaust TRD Pro Fox Shocks (front & rear) TRD Matte Grey 17" Wheels 265/70/17 Falken Wildpeak Tires OV Tune SFOB Premium Tune Accumulator Delete
    If I flash my truck will that erase any stored settings saved by using sprint booster. Will I need to reinstall my sprint booster and set back to default to load the ovtune pedal settings?
  15. Nov 2, 2020 at 9:07 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    With vF, you can toss that out. The basic tunes will give you different throttle response depending if you are on Base or SFOB or using low or high octane. Beyond that, some tune editing gives you the ability to sharpen the throttle within the maps.
    Sprint Booster, Pedal Commander, and Shift Sense (on the AT side) are just not needed any more.
    Junkhead, su.b.rat and CygnusX191 like this.
  16. Nov 2, 2020 at 9:12 AM
    Mike2121
    Mike2121 Club-Coma
    Michael
    Georgia
    Gotcha, I agree with your statement. My concern is having used sprint booster and set it to my preferred setting, then unplugging sprint booster, that setting is now saved. Once I flash the truck with ovtune will those sprint booster settings be overridden?
    tonered likes this.
  17. Nov 2, 2020 at 9:16 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Assuming the sprint booster adjusts throttle sensitivity via ecu, yes the OVT should override it (same as flashing to 2.0 overrides 1.05 or whatever)
    tonered likes this.
  18. Nov 2, 2020 at 9:19 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I believe that SB stores the info in the adapter, not in the ECU as there is no real interface there, just on the TPS, right? If so, the settings should not changed when you flash.
    CygnusX191[QUOTED] likes this.
  19. Nov 2, 2020 at 9:19 AM
    Shellshock
    Iowa
    Sprint booster has to be in the path for it to do anything. If you remove SB, the ECU throttle is unmodified.
  20. Nov 2, 2020 at 9:20 AM
    Shellshock
    Iowa
    Dammit. I was too slow
    CygnusX191 and tonered[QUOTED] like this.
Thread Status:
