2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. May 26, 2021 at 1:21 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Only immediately after a tune flash.
    CygnusX191 and Junkhead like this.
  2. May 26, 2021 at 1:23 PM
    army_greem
    army_greem Member
    Cresskill, NJ
    2020 Tacoma TRD PRO
    Is there a article explaining this further? Like do you, Reset ECU then flash then Clear TCU and DTC also does this TCU matter with an MT
  3. May 26, 2021 at 1:25 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    This is what OVT said a while ago:
    "Regarding AT / LV Resets:
    Resetting LV / AT after a flash = Not required
    Resetting LV / AT after a flash = Is not harmful, and may be done at your discretion
    Resetting LV / AT after a flash = Should be done IF you have drivability issues (very odd shifting behavior, very odd engine behavior, or you hear any knock / detonation)
    Resetting LV / AT after a flash = May make the truck run noticeably rougher for the first few miles (especially the transmission)
    Resetting LV / AT should NOT be done just because you feel like doing it.
    Resetting the LV / AT should NOT be done if you have not recently flashed.
    If you Reset LV / AT right after a flash = The first 25mi to 50mi, the trucks shifting characteristics can be ignored.
    If you Reset LV / AT or even flashed the truck and are making judgements without putting AT LEAST 25mi on the truck, you are not getting an accurate representation of how the truck will perform."
    Clear TCU is only for ATs.
    CygnusX191, C41n and Junkhead like this.
  4. May 26, 2021 at 1:28 PM
    army_greem
    army_greem Member
    Cresskill, NJ
    2020 Tacoma TRD PRO
    Im sorry but what is LV/AT respectively
  5. May 26, 2021 at 1:29 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Reset ECU Learned Values. The same as Reset ECU.
    Reset AT Learned Values. The same as Clear TCU.
  6. May 26, 2021 at 1:30 PM
    army_greem
    army_greem Member
    Cresskill, NJ
    2020 Tacoma TRD PRO
    Thanks
    CygnusX191 likes this.
  7. May 26, 2021 at 1:31 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
  8. May 26, 2021 at 1:32 PM
    army_greem
    army_greem Member
    Cresskill, NJ
    2020 Tacoma TRD PRO
    one last thing where does the DTC come in ?
    Sorry for all the questions I am new to this
    Its going to be my first time flashing just wanna make sure im doing it right
  9. May 26, 2021 at 1:34 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    DTC is Diagnostic Trouble Codes. Those are reset by any OBD reader or by a battery disconnect. I believe a tune flash automatically resets the DTCs.
    Doing the DTC and LV Resets all at the same time completely clears all learned values giving the Taco a blank slate to learn and adapt.
    No worries!
  10. May 26, 2021 at 5:10 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    I recently discovered that DTC reset will not clear Permanent codes. Yes, it will turn off the MIL if the fault condition no longer exists, but only a few (3 IIRC) drive cycles will actually clear the DTC from the ECM. I read that in Techstream!
  11. May 26, 2021 at 5:16 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. There are layers to DTCs.
    CygnusX191 and MOC221_[QUOTED] like this.
  12. May 26, 2021 at 5:18 PM
    MOC221_
    Frank
    Onions!
    Nothing like limp mode to throw a wrench into your "tuning" fun lol
    CygnusX191 and Shellshock like this.
  13. May 26, 2021 at 5:23 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You just found the middle of the Tootsie Pop.
    C41n, CygnusX191 and MOC221_[QUOTED] like this.
  14. May 27, 2021 at 6:38 AM
    Kronan49
    Kronan49 Well-Known Member
    Ronan
    2020 Tacoma Trd Pro 6M
    What Is coming in 2.0 ultimate? Is it going to be like even more hp and torque than the current 2.0
  15. May 27, 2021 at 6:44 AM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    2.0 ult will probably make user-edited tunes obsolete is my bet from everything we've been hearing lol
    C41n and CygnusX191 like this.
  16. May 28, 2021 at 3:20 PM
    jewboi
    jewboi Well-Known Member
    Time for my tri-yearly check in on this thread. Attempting to keep up with the news on this stuff is impossible if you don’t check near daily, and then anything more than a week means you’ll never figure out wtf is going on... so my apologies if I’m repeating something others have already asked lately but....
    last time I checked in I had to upgrade to vFtuner, flash my ECU to 04b04, then I was able to flash the latest (at the time) 2.0 tune pack.
    what’s this now I hear about 2.0 ultimate? And something about map switching ? And now that there’s vF tuner are you guys running custom tunes or changing anything, or just stick with whatever Mat comes up with?
    again, sorry, just super lost trying to catch up.
    historically @tonered or @MOC221_ shows up to set me straight so I’m summoning them now :cool:
    C41n, 02Duck and CygnusX191 like this.
  17. May 28, 2021 at 3:37 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is the latest at the moment. Ultimate is coming.
    You can try your hand at editing 04B04 MapSwitching if you would like with the latest version.
  18. May 28, 2021 at 3:41 PM
    jewboi
    thanks tonered. Just wanted to make sure there wasn’t some other news I wasn’t aware of.
    I like the idea of doing that but with literally any of the settings in vF tuner I’m like a monkey with an iPad. I’d rather wait it out until those that are smarter than I figure something out.
    Thanks !!
  19. May 28, 2021 at 3:47 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
    Yes. I am not comfortable with the maps that require changes for MapSwitching to work properly. @OVTune said that the Ultimate tunes will have baseline edited MapSwitching.
  20. May 28, 2021 at 3:52 PM
    Shellshock
    Iowa
    @tonered and everyone else are also monkeys with iPads. You’ll fit right in
Thread Status:
