2016 - Present Old Man Emu Kits
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Low Range Off-Road, May 9, 2016.
  1. Feb 28, 2018 at 7:16 AM
    #241
    remgu2000
    remgu2000 Keepin' on keepin' on.
    Ray
    Roswell, GA
    Used to have a 2017 Barcelona Red TRD Off-Road DCSB 4x4
    Hmm...haven't heard of the U Bolt flip kit.
    RobP62[QUOTED] likes this.
  2. Feb 28, 2018 at 7:22 AM
    #242
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I believe it is exactly as the name implies. I have not researched it. Just curious.
  3. Mar 1, 2018 at 2:15 PM
    #243
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I have a question for everyone. I have been meaning to ask this and haven't seen anything on the subject. How come there is no talk about the front drive shaft needing to be corrected, or a differential drop kit needed?
    Thanks,
    Rob
  4. Mar 3, 2018 at 12:44 PM
    #244
    Long Time Toy Fan
    Long Time Toy Fan Well-Known Member
    17 DCOR
    Cookie cutter Tacoma, 888/Dakars/LR/ECGS/Sliders
    Settled height reference
    Double cab Off Road
    OME 888 on 90021 with trim packer on driver's side
    Standard duty Dakars (new style)
    Pelfreybilt bolt on sliders, 1/2 tank of gas, no excessive weight in it and I haven't flogged it off road (yet).
    Settled height hub center to fender bottom
    DF 22 1/2"
    PF 22 5/8"
    DR 23 1/2"
    PR 23 1/2"
    On another note I loaded 150lbs on my front bumper and bounced it around a bit, came down 1/4" on both sides.
    mhshark, remgu2000 and RobP62 like this.
  5. Mar 3, 2018 at 12:48 PM
    #245
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    New style Dakars? Please explain. Thanks.
  6. Mar 3, 2018 at 1:07 PM
    #246
    Long Time Toy Fan
    17 DCOR
    They used to be part number CS047R, now EL095R and EL096R. Read all about it here: https://www.tacomaworld.com/threads/new-ome-dakar-leaf-pack-review.489540/
    Edit, I'll add a quick review. I like the way the truck handles. When I first went out I was trying to cycle the springs to get them to settle some before I had it aligned. Hitting bumps way faster than I normally would it was very smooth. Driving at speed down rough roads much better than stock OR. I have LR UCA's and ECGS bushing as well. I don't like how the rear shocks limit flex. I wish I had bought extended brake lines and done a little more research and got something longer travel. For bolt on though it does ride very nicely. I will be adding a 3 degree shim soon to see if I can get rid of a small vibration.
    Edit: I meant longer travel for the rear suspension since the shocks limit the springs flex. The front is only going to get what it gets.
    Rujack, mcharfauros and RobP62 like this.
  7. Mar 3, 2018 at 1:09 PM
    #247
    fcebedo
    fcebedo Well-Known Member
    2006 Tacoma
    Didn't have a great experience with my add-a-leaf for 3 inch lift. Squeaky and the ride was uncomfortable.
  8. Mar 3, 2018 at 1:12 PM
    #248
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
  9. Mar 5, 2018 at 5:05 PM
    #249
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    What’s your backspacing?
  10. Mar 6, 2018 at 5:48 PM
    #250
    dakar650
    dakar650 Well-Known Member
    Shawn
    Asheville, NC
    2017 Tacoma TRD OR CC SB
    OME lift, Light Racing UCA's, Leer Topper.
    @remgu2000
    Here is what I installed in mine. I did some measuring and went with a 4* shim. Most I have seen use 3-4*.
    https://www.headstrongoffroad.com/store/p120/Axle_Shim_KIT.html
    I only had a vibration from about 40-0 and none on take off, bit this cured it. I also had the needle bearing vibe after lifting, but note prior. Took to Toyota yesterday and they are replacing the entire front diff under the latest TSB. Also have a trans pan gasket leak be g fixed. Hope the new diff is upgraded a d not just the same part. We will see.
    RobP62 and remgu2000 like this.
  11. Mar 6, 2018 at 5:57 PM
    #251
    dakar650
    Shawn
    Asheville, NC
    I also removed my carrier bearing drop, made no difference after shims and took first shaft angle back stock. I also tried the diff drop and it made my needle bearing worse. I took it out also prior to taking into dealer.
    RobP62 likes this.
  12. Mar 6, 2018 at 6:00 PM
    #252
    ManInTheMaze
    ManInTheMaze Well-Known Member
    Mendo
    2003 and 2017
    Hoping someone in here might be able to provide some insight. I want to do a light upgrade on my stock sport suspension, but I am not interested in too much lift at the moment (maybe later). I've been thinking about going with OME 884 coils up front for a modest lift. However, elsewhere on TW, a couple people have said that because the spring rate on the 884s is 590lb and the stock coil is 710lb, that the 884s will sag over time with use. Is there any truth to that? Should I be worried or naw? I see plenty of folks on TW running the 885s on 3rd gens and those also have a 590lb spring rate, so it should be pretty comparable, right?
    RobP62 likes this.
  13. Mar 8, 2018 at 7:15 AM
    #253
    CarolinaBlue
    CarolinaBlue Well-Known Member
    Mark
    Asheville, NC
    2016 TRD Off Road 4x4
    OME full suspension kit with 888 coils and 1/4" spacer, soft-ride struts, full Dakar leaf packs, SPC Light Racing UCA's, Fuel Vapor 17's with Double Dark Tint, BF Goodrich K02's in 285/70R17, Tinted Windows, Headlight signal light smoke outs, Weathertech Mats, full audio system upgrade with JL Audio subs, JL Amps, Audiocontrol Processors and Focal K2 components, LED interior light kit, custom bedside decals, leather interior and heated seats and TRD Pro Tail Lights. SOS Offroad Concepts Low Profile Winch Bumper with Smittybilt XRC Gen II 9.5k winch with synthetic rope.
    It's the SOS Offroad Concepts Slimline www.sosoffroadconcepts.com
    RobP62 likes this.
  14. Mar 8, 2018 at 7:18 AM
    #254
    CarolinaBlue
    Mark
    Asheville, NC
    I used the full OME kit with the Dakar Leaf packs with all leafs left in. I knew I'd be adding weight up front with the winch bumper and so the front has 1/4" aluminum spacers above the struts to compensate for the 1/4-1/2" droop the extra weight added. That way I still clear fine and it still sits the way I want. I ordered everything from HeadStrong Offroad.
  15. Mar 8, 2018 at 7:21 AM
    #255
    CarolinaBlue
    Mark
    Asheville, NC
    4.5" backspacing -12 offset
    Rujack[QUOTED] likes this.
  16. Apr 2, 2018 at 4:44 PM
    #256
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    Dang, thought I had my mind set on the 887s with the soft ride nitrochargers because I only want 2" of lift and thought I would have avoided all the vibration issues and need for new UCAs, but now I'm not so sure...
  17. Apr 2, 2018 at 6:07 PM
    #257
    roth_nj
    roth_nj Well-Known Member
    2017 DCLB trd off-road bbp
    From what I've found, is it's all shit luck. You might have some issues before and the lift fixes it. You might be perfect before and after. Or you might get vibs after. Every trucks different.
    And you don't need the ucas, but it's better with them
    Hellapeno and RobP62 like this.
  18. Apr 6, 2018 at 6:40 PM
    #258
    YotaDriver631
    YotaDriver631 Well-Known Member
    '18 Taco
    Thinking about going with the 885 coils because I don’t want too much lift up front, has anyone done this is on a 3rd gen DCLB OR 4WD AUTO 3.5?
    RobP62 and Rockdaground like this.
  19. Apr 17, 2018 at 1:03 PM
    #259
    meat_wallet
    meat_wallet Well-Known Member
    Portland, OR
    2016 TRD OR Long Bed
    With the OME kit, has anyone determined other pieces that would be useful during initial install? Extended brake lines? Axle shims? Etc? Thanks for any info
  20. Apr 17, 2018 at 1:28 PM
    #260
    Hellapeno
    Hellapeno Well-Known Member
    Austin
    2016 TRDOR
    Choice Goodies
    Ive flexed pretty damn hard, no need for ext brake lines... I needed axle shims... needed 3 degrees, but went with 4. Front what I've read, each truck behaves differently when lifted. My advice would be to lift it, drive around and if there are noticeable vibrations, try to carrier bearing drop kit and hope that takes the vibration out, then shim the rear if not.
    RobP62 and meat_wallet like this.
