2016 Side Bed Rail's are Torqued?
Discussion in '3rd Gen. Tacomas (2016+)' started by moe2o4, Dec 10, 2015.
  1. Dec 10, 2015 at 10:48 AM
    moe2o4
    moe2o4 [OP] Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    Hi guys,
    I just got my 3rd bed rail in for up against the cab and was going to put it on and i was wondering if anyone knew if there was a torque spec on the side rail bolts, the 5 torx bolts?
    Thanks!
  2. Dec 10, 2015 at 2:24 PM
    Wraith600
    Wraith600 Well-Known Member
    2016 AC TRD OR Quicksand
    I would just go with make sure they are "good and tight" spec. It likely doesn't require something so specific.
    I am sure there is a spec if anyone chimes in but I wouldn't get to worried about them not being exact.
    Khrolar likes this.
  3. Aug 15, 2017 at 11:11 AM
    scarroll451
    scarroll451 New Member
    2017 White Tacoma Off Road Double Cab
    thule trac one rack
    I read 66.5 in-lb (about 5.5 ft-lb) on an Amazon.com product description or review once. It was for after-market installation of bed rails. Seems right, they're not very beefy. Let me know if you find out different!
  4. Aug 15, 2017 at 12:16 PM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    I can appreciate everyone wanting to do things right and whatnot, but you don't really need to torque every bolt to spec. I'd just tighten them up. Just a little past snug. Probably not even a half turn past snug.
  5. Aug 15, 2017 at 12:47 PM
    scarroll451
    thule trac one rack
    Thanks Woodrow, point taken. What got me thinking about torquing it is, I purchased the Trac One rack system, and I learned after the fact that I need special clamps for the Tacoma, and separate special clamps for the 2016-17 Taco bed. These clamps leverage the factory bed rail system. Not sure how much I like the whole design, but I'm going to roll with it. Supposedly the Trac One can hold 800 lbs.
    https://www.amazon.com/gp/product/B01CKQPTJ8/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
    https://www.amazon.com/TracONE-perf...e=UTF8&qid=1502826444&sr=1-1&keywords=tracone
  6. Aug 15, 2017 at 1:03 PM
    Woodrow F Call
    Colorful Colorado
    The hard ware is just going to hold the track in place. Most of the support is just going to be from the rails sitting on the bed. 800lbs? I'd think that would try really hard to push your bed rails out. I might would add a bed stiffener....... that might also just be a static rating..... what about when the truck is moving?
  7. Aug 15, 2017 at 1:04 PM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    They're in decently tight from the factory. I think like 35 ft-lbs
  8. Aug 15, 2017 at 2:03 PM
    mauidogg
    mauidogg Well-Known Member
    16 DCSB TRDOR
    The bolts do strip easy so take it easy when you do. I had to replace two of them
