2016 SSO Slimline Bumper
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LostSherpa, Jun 1, 2016.
  1. Dec 28, 2016 at 8:44 PM
    #461
    MooseknuckleV22
    MooseknuckleV22 Well-Known Member
    Charlie
    Clovis, NM
    2017 TRDOR DCLB - Quicksand
    Icon Stage 2, 275/70/17 KO2s, SSO slimline bumper, Warn Zeon 10-S winch, Rigid SR-20 light bar, TRD SEMA rims, Mobtown Offroad sliders, RCI skids, LED light conversion
    I was originally worried there wouldn't be enough clearance behind the spool, but after going out and pre-tensioning there's tons of room since it's wound so much tighter.
  2. Dec 29, 2016 at 7:23 AM
    #462
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Mine is sitting in the garage at the moment and I have a nice 4 day weekend to work on it. How did you guys runs the wiring harness for the LED bar, how did you get it into the cab?
  3. Dec 29, 2016 at 7:35 AM
    #463
    MooseknuckleV22
    Charlie
    Clovis, NM
    I just ran it through from the mounting point on the bumper to the side of the winch and then through one of the openings beside the radiator on the left side of the vehicle. I used the mounting bolt for the battery tray to attach the relay, and ran the wires for the switch through the cab firewall using the same opening where the large rubber grommet is for the other harnesses.
    Tip though: just run the wires to the side of the grommet (between the grommet and the bare metal) - not through it - it's a lot easier.
  4. Dec 29, 2016 at 7:37 AM
    #464
    JoeCOVA
    Joe
    Colorado Springs
    Excellent, thank you
  5. Dec 29, 2016 at 7:39 AM
    #465
    MooseknuckleV22
    Charlie
    Clovis, NM
    Also, if your bumper is not fully affixed yet, make sure you've got the light aimed as you want it in the mount, since once everything is put back together it will be a pain (if not impossible) to adjust.
  6. Dec 29, 2016 at 7:40 AM
    #466
    JoeCOVA
    Joe
    Colorado Springs
    Good call. It's all still boxed up. I plan to read the instructions 100 times over as well as read the modifications needed for the winch before actually installing it. I want to do it one time!
  7. Dec 29, 2016 at 7:46 AM
    #467
    MooseknuckleV22
    Charlie
    Clovis, NM
    Send a PM if you get stuck.
    JoeCOVA[QUOTED] likes this.
  8. Dec 29, 2016 at 7:58 AM
    #468
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    Dang you guys are lucky, on the smittybilt you have to grind off the stock hook if you want to remove it.
    If someone wants to send me an ultrahook for christmas, that would be okay too, just let me know :thumbsup:
  9. Dec 29, 2016 at 8:20 AM
    #469
    MooseknuckleV22
    Charlie
    Clovis, NM
    That's what you get when you pay ~$600 more for the Warn than the Smittybilt...the ability to throw part of it away. ;)
  10. Dec 29, 2016 at 8:37 AM
    #470
    Kennedyusmc
    Kennedyusmc Well-Known Member
    Christopher
    2017 Cement Pro
    Still waiting for it
    Well- I went a bit further, installed a tacomapro bussman RTMR. This unit allows for the prewiring of 5 relayed accessories and offers one 7 wire bundle you send through the firewall (using the grommet just behind the brake booster). That 7 wire unit provide ma both the 12v + and gnd for the switch, as well as the lead back to the accessory. Once installed all I had to do is wire my switch to it and the positive lead to the rtmr... and when I find more places to add switches, I'll add more lights!
  11. Dec 29, 2016 at 8:39 AM
    #471
    Kennedyusmc
    Christopher
    2017 Cement Pro
    I don't reccomend this. Eventually, vibration can/will chew through he wire and short on the sharp edge of the firewall. Get an exacto knife and get hack of that grommet proper.
    TWTaco and T$$ like this.
  12. Dec 29, 2016 at 8:42 AM
    #472
    MooseknuckleV22
    Charlie
    Clovis, NM
    Agreed. It's an inelegant solution unless you wrap the wires with some additional protection or put some stripping on the firewall edge itself....like a beer coozie. ;)
  13. Dec 29, 2016 at 8:43 AM
    #473
    JoeCOVA
    Joe
    Colorado Springs
    FlexSeal!
  14. Dec 29, 2016 at 8:44 AM
    #474
    Kennedyusmc
    Christopher
    2017 Cement Pro
    I though the beer coozie was quite elegant thank you very much...
  15. Dec 29, 2016 at 8:50 AM
    #475
    MooseknuckleV22
    Charlie
    Clovis, NM
    That's what I meant! ;) It's only inelegant if you DON'T use the beer coozie! Coozies are the new standard - they totally one-up the pieces of pool-noodle I use all over the place for similar applications.
  16. Dec 29, 2016 at 8:58 AM
    #476
    Kennedyusmc
    Christopher
    2017 Cement Pro
    ROFL- pool noodle...
  17. Dec 29, 2016 at 8:59 AM
    #477
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    And cut some bits off your truck. You've got me full of regrets :)
  18. Dec 29, 2016 at 9:06 AM
    #478
    MooseknuckleV22
    Charlie
    Clovis, NM
    I'll be the first to admit the Smittybilt is hands-down a better value. I bought the Warn for mostly sentimental reasons - when I was a kiddo and used to salivate over the Quadratec catalog Warn was sort of the marquee brand.
    So....I'll be thinking about you too when I have to shell out another $100 for for a wireless controller when you got one standard. ;)
  19. Dec 29, 2016 at 9:09 AM
    #479
    MooseknuckleV22
    Charlie
    Clovis, NM
    Seriously! They're closed-cell foam and super useful! I use them to pad heavy loads when I'm roof loading, and a short section also makes a great lumbar support. I keep a couple in my gear cage at work for dudes to take sections of if they need 'em.
    Also, they are great for beating my kids/pets.
  20. Dec 29, 2016 at 9:09 AM
    #480
    Kennedyusmc
    Christopher
    2017 Cement Pro
