2016 tacoma bed extenders
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NHfree, Jan 28, 2016.
  1. Dec 16, 2016 at 1:02 PM
    #101
    Smitty4699
    Smitty4699 Well-Known Member
    Brian
    2017 Cement TRD Pro
    do you think the MAX would work on the short bed or are would the wheel wells get in the way?
  2. Dec 16, 2016 at 1:25 PM
    #102
    6172crew
    6172crew Well-Known Member
    New Mexico
    4X4 TRD sport
    Im taking my 848 and hypermotard to COTA this year, wonder if your 848 and SXV(your avatar looks like my old SXV) fit back there? It was tight to get 2 848s in the F150 and I used the lower tiedown ring in the middle of the bed which this truck doesnt have.
  3. Dec 17, 2016 at 11:53 AM
    #103
    stan23
    stan23 Well-Known Member
    stan
    Santa Clara, CA
    2025 DCSB TRD Sport 4x4
    Funny, i have both the 848, and a Hyper 821 as well. You should be able to fit both no problems. I used to haul 2 sport bikes all the time in a different compact truck. The key is not using a center ring as a tie down point that will never work, an will not be stable on the more compact narrow beds. You need to criss cross the tie down meaning loop the tie down across the wheel/tire on both bikes.
    My SXV is long gone, but I miss that bike dearly!
  4. Dec 17, 2016 at 12:16 PM
    #104
    6172crew
    New Mexico
    4X4 TRD sport
    ;) I have the older 1100evo corse and the 848 corse. My 450SXV was cool but I was afraid of the issues that could happen to that MotoGP engine. The 1100 isn't as light but much better torque. I took the 848 to COTA last year and had a blast.
  5. Nov 2, 2017 at 11:27 AM
    #105
    oranjish
    oranjish Well-Known Member
    Josh
    Harris County, GA
    2017 TRD Pro Cement
    VTX Rogue Satin wheels, BFG KM3 tires, Diamondback SE tonneau, KBVoodoo Crossbars
    I'm in the same boat, I have a *brand new* TRD Pro (less than 2000 miles). I previously had an ACLB and switching to a DCSB obviously shortened my bed length significantly. My main hesitations is I think I will sh*t my pants the second I bring a drill to anything on my truck... I'm sure I can have my Toyota dealer install for me but at what cost? (3 easy payments of $99.99 plus tax probably) Has anyone opted for dealer install and can confirm the fee?
  6. Nov 2, 2017 at 1:13 PM
    #106
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Only the Nissan Frontier/Titan have that type of mounting system.
    shakerhood likes this.
  7. Nov 2, 2017 at 1:18 PM
    #107
    cafereef
    cafereef Well-Known Member
    2017 MGM Tacoma TRD Sport
    TRD Sport Exahust, OEM roof Rack, Predator Pro side steps.
    Anyone know of a bed extender that will work with bed stiffeners?
  8. Feb 26, 2018 at 11:18 AM
    #108
    pralix
    pralix Active Member
    William
    2017 Cement Tacoma TRD Pro
    Were you able to get the bed extender and bedrug to play nice? Thinking of doing that setup on my truck.
  9. Mar 24, 2018 at 9:34 AM
    #109
    htan00
    htan00 Well-Known Member
    Bay Area CA
    2016 Tacoma TRD Sport DCSB 4x4
    Does anyone know if I can buy just the little plastic price that’s connected to the extender itself that latches onto the bracket?
  10. Mar 24, 2018 at 10:19 AM
    #110
    pralix
    William
    Not sure. You might want to contact AMP.
  11. Mar 24, 2018 at 10:20 AM
    #111
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Having installed one of these I can truly say that it is an easy installation. As long as you take your time, it's not too terrible to do. Simply use a center punch, a small pilot bit and work your way up through the bit sizes. Then use some touch-up paint and you'll be golden. The template for where to mount the mounts is here:
    https://www.toyotaparts.metro-toyot...EXTENDER_PT329-35050_REV._A_--PT329-35050.pdf
    You may need to adjust the height slightly to your liking, but honestly it's not that difficult.
  12. Mar 24, 2018 at 12:05 PM
    #112
    specter208
    California
    The install is so easy. I did it 5 min. It took longer to assemble the extender than to drill and mount the brackets. Just make sure you tape the templates and check your clearance with the tailgate closed and then Open. Take your time if you are nervous. Having the dealer do it is a waste of money.
    Also, when you set the templates, take your extender and Line up the pin with center of the bracket picture and make sure that your extender is nice and level when it is deployed with the tailgate opened.
  13. Mar 24, 2018 at 12:27 PM
    #113
    parksinferno
    parksinferno Member
    Larry
    '17 Inferno AC
    I think I'm going to get one of these. Thanks for all the info guys!
  14. Oct 14, 2019 at 9:07 AM
    #114
    Glenn247
    Glenn247 Well-Known Member
    Lynchburg VA
    2016 DCSB Manual TRD Sport 4x4
  15. Sep 8, 2021 at 2:40 PM
    #115
    Taco2k16
    Taco2k16 TRD_ShoreTrooper
    Danny
    Los Fresnos, Texas
    2017 TRD OffRoad 4x4 QuickSand DCSB
    Stock Tow Package Bed LEDs
    Anyone have actual link or file for drilling for the OEM bed extender I can’t find it anywhere
  16. Sep 8, 2021 at 2:41 PM
    #116
    Taco2k16
    Danny
    Los Fresnos, Texas
    Let me make it clear I need the template to drill the holes TIA!
  17. Sep 9, 2021 at 7:56 AM
    #117
    specter208
    California
    You can get the template from the AMP research website.
