2016 Tacoma engine failure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cedron55, Jul 28, 2020.
  1. Jul 28, 2020 at 5:27 PM
    cedron55
    cedron55 [OP] New Member
    Ron
    2016 Toyota Tacoma TRD Sport
    NA
    Bought a 2016 Tacoma new in 2016. I have 93,000 miles and just had my 90,000 mile service done at the dealership. Two months later I noticed a miss. I had it towed to Joe Myers Toyota in Houston. I was informed That I have to have the passenger side head replaced for a cost of $6000. Anybody else have this problem? The mechanic says mine is the third one.
    Grossomotto likes this.
  2. Jul 28, 2020 at 5:42 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
  3. Jul 28, 2020 at 5:43 PM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    SR-71A and shakerhood like this.
  4. Jul 29, 2020 at 5:35 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Back in 85 my 4 cylinder toyota had an engine failure with the key on the front of the crank shearing. The crank had to be inspected by the regional rep before the engine could authorized to be repaired. Toyota deemed it a metallurgical failure, saying it was the first time seeing it on their 84 engines. They were pretty good about the entire deal fixing the truck within a week and giving me a rental.
  5. Jul 29, 2020 at 5:38 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Seems 6 grand could buy a nice used engine, harness, transmission, transfer case, and axles.
  6. Jul 29, 2020 at 5:43 AM
    synaps3
    synaps3 Wag more bark less
    Dave
    Los Alamos, NM
    2017 White SR5 4x4 DCLB
    SOS armor, ARE MX walk-in, Fox coils, Dakar leafs, etc
    You need to shop around, that price is crazy high.
  7. Jul 29, 2020 at 5:44 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Not sure about how common that is, but I would replace with a good used engine and not do that repair. Unless you really trust them, I think I would also get a second opinion before doing it.
    Big tall dave likes this.
  8. Jul 29, 2020 at 5:54 AM
    zoo truck
    None
    With all the gen3 taco's built there has to be some good used engines from wrecks hanging around for lots less.
  9. Jul 29, 2020 at 5:56 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    a ' miss ' doesnt necessarily mean a new head
    there are a doz reasons for a ' miss '
    a- bad spark plug
    b- bad coil pack
    a different doz reasons to replace a head
    a- valves
    b-head gasket
    tho im not there U haven't recounted what the mech definitively found broken
    in Ur engine
  10. Jul 29, 2020 at 5:59 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    They usually don’t just tell you, you need a new head when your under a factory warranty unless you do. Sure it may just be a valve. But they don’t have the techs usually do that kind of work anymore. They send out a new or reman’ed head to swap, and the defective one gets sent back to the factory for repair/replacement.
    Hank Heel likes this.
  11. Jul 29, 2020 at 6:16 AM
    cedron55
    Ron
    NA
    Thank you all for your input. The tech originally replaced an injector because he found low compression in cylinder three and five. The service advisor told him rather than to chase down each individual injector to pull and check the head. They have ordered a new head but it’s a week out. I will be calling the dealer where I bought the truck for a second opinion.
  12. Jul 29, 2020 at 6:22 AM
    Gearheadesw
    Davenport Fl
    Good God don't let them just order a head to replace yours, what's there matter with it???? Have then show where it's so fucked you need a new one.
  13. Jul 29, 2020 at 6:26 AM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    At 6k I would shop around. Find a shop that specializes in Toyotas.
  14. Jul 29, 2020 at 6:26 AM
    ROAD DOG
    FEW
    replacing injectors is Not the procedure for ' low compression '
    a leak down or compression check would have been in order
    the service advisor should at least let the mechanic find out exactly whats wrong
    U may need a new head after all.................... NOT because U have bad injectors
    valves
    head gasket
    spark plugs..........surprising how many are loose sometimes NOT even finger tight!!
    1/2 the svc advisors at the dealership couldnt change a tyre or oil& filter in less than an hour
    let the mechanic do his job instead of Starbux explanation
  15. Jul 29, 2020 at 6:27 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    this^^^
    I'd also shop around if that's your first estimate, that's a lot of cash!
    sorry man, the SA is not someone I'd ever take mechanical advice from. Most are nice ppl where I go but technical is not something I'd call any one them, I'd sooner take advice from the kid doing oil changes.
  16. Jul 29, 2020 at 6:40 AM
    zoo truck
    None
    Around here we have a few engine machine shops that have everything to rebuild any cylinder head. I know a few dealers that send their stuff to one of these guys instead of replacing the entire head....that is unless its still in warranty.
  17. Jul 29, 2020 at 6:43 AM
    papito3kids
    papito3kids Well-Known Member
    Patrick
    Colorado Springs
    2020 TRD Sport AC/6MT Cement, 23 4Runner Limited Classic Silver
    With as many of these trucks as are out there, it shouldn't be too hard to find one that was totaled with a perfectly good engine in it, perhaps with a lot fewer miles than your has. I would venture you could find one and get it installed (pretty straight forward install) for significantly less than $6k.
    Big tall dave and shakerhood like this.
  18. Jul 29, 2020 at 8:08 AM
    Pilsner
    Pilsner Well-Known Member
    18 TRDOR
    255/85r16 ST Maxx 6112/5160 w/ Dakar RCI armor, sliders, and rear bumper CBI hidden winch mount w/ Smity 20k
    That's what I thought. I have paid a lot for expensive high flow aluminium heads before, and they were like 2k fully built. Not Tacoma heads though. OEM heads used to run like $200. Doesn't seem like you could possibly put that many labor hours in it to get to 6k.
    Gearheadesw[QUOTED] likes this.
