2016 Tacoma engine
Discussion in '3rd Gen. Tacomas (2016-2023)' started by forana, Jan 10, 2015.
Thread Status:
Not open for further replies.
  1. Jan 12, 2015 at 9:02 AM
    ethanfoy
    ethanfoy Well-Known Member
    ethan
    Little Rock AFB
    99 toyota tacoma xcab 4x4
    as long as they make the 6th gear in the manual higher, im happy. They should have changed it a long time ago. It would have got so much better gas mileage. My 1st gen has a higher 5th gear than the 2nd gen 6th gear.
  2. Jan 12, 2015 at 9:26 AM
    taco206
    taco206 Well-Known Member
    Mill Creek, WA
    14 DCSB SR5 PreRunner 2.7L
    If in fact the dual vvti 4.0 is the "new" motor it will have been about six years since it first came out in the 2010 4runner. That's pretty sad. It should definitely have 300 HP minimum by now if Ford's little pos 3.7L V6 has 300+ hp.
  3. Jan 12, 2015 at 9:31 AM
    imag
    imag Well-Known Member
    Rumors were they would offer a hybrid option. It will be interesting to see, as I don't know how many folks would even be interested.
  4. Jan 12, 2015 at 9:43 AM
    Mr.Gadget
    Mr.Gadget Well-Known Member
    NC
    2011 DC 4x4 SR5 SB/2012 DC 4x4 SR5 LB(sold)
    Toy has it on the web now a 3.5 DI V6
  5. Jan 12, 2015 at 9:58 AM
    n.gardner
    n.gardner Spacer Hater
    Nick
    Hawaii
    '13 SR5 4x4
    OME 3" 887s + Dakars 1" 4 Crawler BL Pro-Comp Uniballs Nitrochargers + Super Bumps Diff Drop + Drive Shaft Drop
    Disappointing
  6. Jan 12, 2015 at 10:06 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    .... been saying for over a year.... 2GR-FSE .... IE Direct injected 3.5L v6.... FUCKING CALLED IT.
    now i just wanna see numbers!
  7. Jan 12, 2015 at 10:08 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    The 2GR-FSE is what I'm guessing too. Looks to have 305~315HP with 278ft/lbs torque.
  8. Jan 12, 2015 at 10:10 AM
    spp
    spp OC, Kalifornia
    OC California
    Atkinson cycle V-6? Has this been used in any other of Toyota's vehicles?
  9. Jan 12, 2015 at 10:13 AM
    nd4spdbh
    SoCal
    YUP..... 2GR-FXE ... looks like they took the 2GR-FSE and the FXE and mated technologies together.
  10. Jan 12, 2015 at 10:18 AM
    Rocky5000100
    Rocky5000100 Well-Known Member
    WI
    2002 4Runner
    The 2GR-FXE makes 338 HP in the Toyota Crown Majesta and the Lexus GS 450h, that'd be awesome if that's what it makes in the US in the Tacoma!
  11. Jan 12, 2015 at 10:20 AM
    cgs2k2
    cgs2k2 old man
    NO REPLACEMENT FOR DISPLACEMENT 4.0 FOR LIFE AM I RIGHT
  12. Jan 12, 2015 at 10:27 AM
    Quentin
    Quentin Well-Known Member
    Eleanor, WV
    2016 Toyota 4Runner Trail Edition, KDSS
    That 2GR-FXE only operates in Atkinson cycle and is way down on power compared to the 2GR-FSE. (The mentioned 340hp numbers above include the electric motor output.) This engine will operate in Atkinson or Otto cycle as needed like the NX200t and the RC-F UR V8. Look for a big efficiency boost when under light load and should have the goodness of the 2GR-FSE when driving hard. I want to see the actual numbers for the truck tune, though.
  13. Jan 12, 2015 at 10:28 AM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    3.5 V6 will be offered with 6 speed auto or 6 speed manual
    2.7L I4 will be 6 speed auto only :thumbsup:
  14. Jan 12, 2015 at 10:28 AM
    Quentin
    Eleanor, WV
    2GR-FSE doesn't operate in Atkinson cycle. He isn't correct.
  15. Jan 12, 2015 at 10:40 AM
    #35
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Yup and that 2GR-FXE is plagued with problems. Definitely not a quality engine, which makes curious why would Toyota install one.
    Usually Tacoma had the same engines as Hilux/4runner/prado since they all the same sizes weight and purpose. Suddenly we get f hybrid engine.
  16. Jan 12, 2015 at 10:41 AM
    #36
    SMHdavid
    SMHdavid Well-Known Member
    David
    California
    Sport
    Heard it is the same one mated to a 6 speed auto
  17. Jan 12, 2015 at 10:42 AM
    #37
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    What? No...I have the 1.8 in my Corolla S, and my wife has it in her Prius. The Prius is Atkinson, but the Corolla isn't. My Corolla (2ZR-FE) pulls more HP (132) than the Prius, which pulls 110 base, but pulls 134 total (hybrid). With the 5-speed, my Corolla is a LOT quicker than the Prius, but my mileage is about half that of the Prius (city driving, lead foot).
    The torque on the Prius isn't bad off the line initially, but the CVT isn't geared for drag racing. After that first 30 feet, though, the engine revs high as the computer kicks in "power" mode.
    If they do hybrid the Tacoma, expect initially lower HP ratings on the gasoline side of the system, but with the right electrical motors it could have a lot of low-end torque.
    I just don't know how smart/safe it would be when using a hybrid to pull a boat out of the water. My only hybrid experience is with Prii, and they aren't known for their towing. But the system has been really solid.
  18. Jan 12, 2015 at 10:48 AM
    #38
    81shark
    81shark Well-Known Member
    no manual for the 2.7. that sucks
  19. Jan 12, 2015 at 10:49 AM
    #39
    Quentin
    Eleanor, WV
    The 2ZR-FE in the Corolla runs Otto cycle only. The 2ZR-FXE in the Prius runs Atkinson cycle only. This Tacoma engine can run both Atkinson cycle and Otto cycle. It isn't a 2GR-FE, 2GR-FXE, or 2GR-FSE. It would have the all new VVT tech that those old engines don't have. This Tacoma is NOT a hybrid. You can run the engine in Atkinson cycle without being a hybrid.
  20. Jan 12, 2015 at 10:59 AM
    #40
    CaptAmerica
    Cap
    Well then that will be very interesting indeed. I can see it switching modes - Otto in the city, Atkinson on the highway.
    Now to wait for them to keep doing mileage testing for the next six months...
Thread Status:
