2016 Tacoma engine
Discussion in '3rd Gen. Tacomas (2016-2023)' started by forana, Jan 10, 2015.
Thread Status:
Not open for further replies.
  1. Jan 13, 2015 at 6:39 AM
    #141
    GoHuskers
    GoHuskers Well-Known Member
    Nebraska
    2012 White DCLB TRD Sport
    3.5L V6 makes 290 HP and 282 ft lb Torque
    19/26/22 mpg
    0-60 in 6.8 seconds.
  2. Jan 13, 2015 at 7:28 AM
    #142
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    To me this is end of an era.
    I am one of those loyal Toyota customers Toyota rep mentioned during the presentation.
    I had 1gen, have 2gen Tacoma plus own two more Toyota trucks.
    If Toyota thinks I am gonna buy Tacoma with Camry size engine they need to have their head examined.
    If I wanted Camry size engine I can buy Camry.
    Toyota could have dropped 3UR 5.7 V8 with AB60 (six speed) in Tacoma and it would have been perfect combination. Mileage would be almost the same as current 4.0 L (maybe difference in 1-2 MPG)
    And 3UR is Truck engine.
    Now yeah I am sure there will be suckers buying that truck with that tiny engine. Thats their problem, people dont understand that in a truck you rather have less HP in lower RPMs than more HP in higher RPMS. Its a truck not a race car. If I wanted race car I would get Sti.
    As for the engine. There is only one engine with 3.5 V6 direct injection and Atkinson cycle in Toyota line up.
    They may have to change it slightly so its more truck like (dual oil pan for example) but on the end this is still crappy engine. this is 3.5 L not even with Turbo. Atleast Ford put Turbos in their ecobost.
    If you think you gonna tow anything bigger than canoe with this thing you need your head examined.
    If I we can not have diesel at least give V8 option or new 1GR from 4runner. Da f we need Camry engine for
  3. Jan 13, 2015 at 7:45 AM
    #143
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    No, its not a "True Atkinson" cycle engine. Its a modified Otto cycle.
    A direct injected engine can produce more torque, and at lower RPM, than a larger engine that has port fuel injection. To add, a 3.5/3.6 L engine has much less friction area between the piston, and cylinder walls, allowing it to be more efficient. I would be surprised if the new engine doesn't have more torque, and at a lower RPM than the current 1GE motor.
    Also, over the last 5 years, most every auto manufacture has gotten their CAFE up by 3 mpg across the board. Toyota has LOST .2 mpg over the last 5 years.
    RBfastback likes this.
  4. Jan 13, 2015 at 7:54 AM
    #144
    mummel
    mummel Well-Known Member
    HAHA!
  5. Jan 13, 2015 at 7:55 AM
    #145
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    that quote on the Atkinson cycle is what I was thinking when I posted above.
    I stand corrected on the full Atkinson engine, but isn't it more Atkinson than otto?
    its geared more for recharging the batteries and running at cruising speed than stop/go, heavy loads, pulling.
  6. Jan 13, 2015 at 7:58 AM
    #146
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    no. An Atkinson cycle engine uses a "lever" thing (not sure what its called precisely) which is attached to a pivot with linkages, then connects to the crank shaft.
  7. Jan 13, 2015 at 8:02 AM
    #147
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    How dare Toyota put a tiny 3.5L V6 that is as powerful as the 4.6L V8 I had in my Caddy :stirthepot:
  8. Jan 13, 2015 at 8:08 AM
    #148
    BlueT
    NorthEast
    I Dont know about that, look at the curve of 2gr-FSE below 2000 RPMS its way below what 1GR is. In truck you need torque from idle to 2000 RPMS because more often than not you going to be idling through stuff not high revving.
    When you flood engine at idle it stops, When you flood engine at 2000 RPMS your crank comes out from the block.
    V8 would have been good option, Diesel would have been even better option.
    3.5L Camry engine is horrible option.
  9. Jan 13, 2015 at 8:10 AM
    #149
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its all tuning. You can get the torque lower in the new motor. And the days of flooded engines are pretty much over. If you flood a newer engine, you have underlying issues.
  10. Jan 13, 2015 at 8:13 AM
    #150
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    First grapf is the Chevy 3.6 V6 engine:
    This is the Tacoma 1GR-FE:
  11. Jan 13, 2015 at 8:14 AM
    #151
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Torque curve is nice an flat, with an additional 1000 rpm, and dam near 70 more hp.
  12. Jan 13, 2015 at 8:20 AM
    #152
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Source?
  13. Jan 13, 2015 at 8:22 AM
    #153
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    Exactly what I said before (if actually confirmed). A little more power, a little more grunt, a little quicker and a focus on MPG. I'd like to see a TRD supercharger option a little more efficient as well and you've got a recipe for one kick-ass truck! That puts mixed MPG at about 20 which is probably 5mpg better than I get now or about a 30% increase in fuel economy which is no small feat.
    People who are crying about not getting a V8 or a Diesel want a full size truck. I'm SO sick of these cry babies who wouldn't be buying anyway. Toyota would be foolish to put so much R&D into a truck that 2% of buying customers will actually seek out. The rest will be sold at massive discounts by salesmen who are incentivized to move units that have been on the lot for months. If you want a diesel for torque... why? Without the proper frame/brakes/suspension you cant' take advantage of it for towing anyway. If you want diesel for fuel economy.... why? If they can make a gasser more efficiently with less weight and better sound... why are you hell-bent on a diesel? Have you been living in a cave for a decade and not seen the difference in regular unleaded and diesel at the pump?
    IMO, the Tacoma is NOT a V8 or Diesel truck. It just doesn't make sense when you get down to the #'s and the fact that Toyota has been ignoring the noisy minority proves exactly that. Everyone here complaining about not having a V8 or diesel option still owns a Tacoma and is posting on a Tacoma forum so....
  14. Jan 13, 2015 at 8:25 AM
    #154
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    Same horsepower as my Olds 403 Rocket, and I don't have to go from gas station to gas station to enjoy it.
  15. Jan 13, 2015 at 8:27 AM
    #155
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    :thumbsup:
  16. Jan 13, 2015 at 8:27 AM
    #156
    cgalloni
    cgalloni Well-Known Member
    BRAVO!! exactly my thoughts. I don't see why people keep complaining aboout that. I don't think Toyota would be foolish to lose market share by putting an engine that simply will not be better than the current one. People are just speculating we do not know the numbers for torque or hp but i bet the numbers will be better than the current 4.0L.
  17. Jan 13, 2015 at 8:29 AM
    #157
    BillyFargon
    BillyFargon Well-Known Member
    Oregon
    2001 Tacoma
    I'm looking forward to test driving! I hope this new engine isn't as noisy as my 2014 4.0 was.. always thought it made too many odd noises for a brand new motor.
  18. Jan 13, 2015 at 8:32 AM
    #158
    BlueT
    NorthEast
    Yes and that GM engine already had two massive recalls.
    Yes you can tune 2 L Honda engine to have 1000HP but it aint gonna last.
    Idea is to have engine that fits truck description and lasts. Hence why Toyota designed 1GR, it was designed for Land Cruiser. Its used on almost every Toyota truck that Toyota cares. 4runner is not getting 3.5 nor any of the Land Cruisers getting it.
  19. Jan 13, 2015 at 8:33 AM
    #159
    GoHuskers
    Nebraska
    Autoguide listed 300/280 hp/tq.
  20. Jan 13, 2015 at 8:42 AM
    #160
    cgalloni
    like I said before . Pure speculation, nobody knows if this is an engine that is currently used in another toyota vehicle. Just because it is a 3.5L does not mean is the Camry engine. People please!
Thread Status:
