2016 Tacoma with leaking sunroof
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sherryf, Nov 11, 2015.
  1. Nov 23, 2015 at 8:30 AM
    tmz1m
    tmz1m Well-Known Member
    That's a good point. I've had a few drops after a car wash but nothing in a heavy snowstorm (twice).
  2. Dec 21, 2015 at 9:17 AM
    VinTaco
    VinTaco Well-Known Member
    Burnaby bc
    2016 Black Tacoma TRD OR
    Good trick..
  3. Jul 26, 2016 at 8:24 PM
    M2loco
    M2loco Member
    2016 Tacoma or lb
    Yes mine is leaking. Toyota put a new seal on and it still leaked. Then they put a whole new sunroof in and it still leaks. Now it leaks in the rain when before it use to only leak in the touch less car wash. This sucks I have a 2006 Malibu and it doesn't leak at all. Hard to believe my Malibu has a better sunroof then my 2016 Tacoma. They quit fixing it this past time and told me I had to escalate it to Toyota and I had to call the 800 number because Toyota told them it was an acceptable amount of water entering the vehicle.
    shakerhood likes this.
  4. Sep 15, 2016 at 6:46 PM
    Dcam123
    Dcam123 Member
    2016 Tacoma Trd sport
    M2loco I'm having the same problem did they ever fix your sunroof?
  5. Jan 9, 2017 at 10:37 PM
    M2loco
    M2loco Member
    2016 Tacoma or lb
    Nope after the main tech came up from Ohio he said it was an acceptable amount of water and that it didn't leak as bad as the new 2016 on the lot. Cracks me up other people say there's does not leak but don't do the test that I have done. Stick for paper towels and all four corners of the sunroof go through a power wash and more than likely they will get water on the paper towels. And in my situation One of the four paper towels is so wet I can ring it out. But nobody on this form goes and does it. I know a higher power wash is an extreme situation but I get the same results even when it rains. I go in for my 10,000 mile service and I'm gonna tell him the same thing hopefully something will get done I wish they would just buy this piece of s**t back
  6. Jan 9, 2017 at 10:46 PM
    TacoFister
    TacoFister Well-Known Member
    Josh
    2016 QS TRD 4x4 Off Road
    OP be trollin
    dYL0n likes this.
  7. Jan 13, 2017 at 12:58 PM
    Dcam123
    Dcam123 Member
    They said the same thing
  8. Jan 13, 2017 at 1:01 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Zero Water is acceptable, that main Tech is an idiot!
    dYL0n likes this.
  9. Jan 13, 2017 at 1:08 PM
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    Thats how Tacoma World gets you...
    dYL0n likes this.
  10. Jan 13, 2017 at 1:38 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    So the passenger can shoot Pronghorns "on the fly"...!! Makes sense to me...:cheers:
  11. Jan 13, 2017 at 2:50 PM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    So FYI, the "seal" around the sunroof glass is mostly a dust and light water seal. When the water comes down much heavier, there are chances the water will get past the seal around the glass. The vehicle body incurs a lot of flex and motion, so there no way it can provide a 100% watertight seal. That's what the sunroof drip pan is for, just above the headliner. Attached to that are 4 drains that need to stay clear and helps evacuate moisture down drain tubes. So if you put the paper towels there, it will soak. It's exactly what the Toyota techs found and say your situation is within acceptable tolerances. As long as you're not getting water on the headliner or your body, you should be fine. We're not supposed to know that the water actually seeps past the seal and down the drip pan, but that is exactly how it works.
    When there's heavy fog here in LA and enough moisture condenses on the exterior roof panel, I'll hear the water trickling down the drain tubes and that just tells me its working. Recent regular rain in Southern California had me alarmed at first as it was really heavy at times and I'd hear the draining loud and clear. It reminds me of thin walls and drainage sounds often heard in cheap apartment buildings.
    I'm not trying to downplay your situation or concerns, but if it's NOT actually dripping to the point where your headliner or interior parts start getting soaked, I'd say it's normal. I've wrenched at dealerships, I remember these complaints all too often. There have been a few threads about water leakage here from the roof, but they show soaked headliners and seats. Not sure exactly what your situation is, but from reading your two posts in here, it doesn't seem like you have this problem. Mine also DOES NOT leak into the interior, but I do get wet spots around the seal. Just have the dealer check to make sure the drain tubes are free and attached to the drip pan and the glass roof panel and mechanism is aligned properly.
    Edit: I just remembered a trick we used to use! Depending the type of seal you have, but it's worth a try. I forgot what chemical we used, but it has to be petrol based. You're trying to get the rubber to "swell" a little bit and expand the sealing ability. Then we'd apply this Silicone based grease that we used when we replaced window run channels and similar seals, to help lubricate and protect the rubber afterwards. It needs to stay supple. While we shouldn't be doing this to a new vehicle, it might be worth a shot. I remember that tube was manufactured by Shin-etsu, a Japanese company. We had to use that stuff religiously and the dealers are supposed to lube those seals when brought in for service, most techs don't bother.
    smitty99 likes this.
  12. Jan 13, 2017 at 4:45 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Learned something today. Ty
    dYL0n and GPsevinSixx[QUOTED] like this.
  13. Jan 16, 2017 at 6:37 PM
    M2loco
    M2loco Member
    2016 Tacoma or lb
    Thanks for the reply but that still seems weird for that much water. As I said before my 06 Malibu doesn't get wet when I put paper towels in there. Now what I don't get is if it was meant to get water in there then I would expect consistency. What I mean is I would expect all four paper towels to be the same dampness but it's not. Other three are damp and the other is sopping wet. Plus to top it off it leaked less before they adjusted and replaced it. Before I took it in only Two were dry and the other two were damp. So when I complained to Atleast get it back to where it was before they worked on it. They said it was an acceptable amount of water coming in. So if what you say is true then why even try to attempt it in the first place.
  14. Jan 16, 2017 at 7:35 PM
    shakerhood
    Southern Ohio
    Water can go past the glass but should go right out the drains, none should enter the interior. I can put paper towels in all 4 corners on my 25 year old Mustang and there will not be a drop of water.
  15. Jan 16, 2017 at 8:08 PM
    #35
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    This is the most important thing with sunroofs; you've GOT to check the drains periodically as normal maintenance. If one of them is stopping up, get it cleared out. Weed whacker line can serve the purpose.
  16. Jan 16, 2017 at 8:58 PM
    #36
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Don't bring it through the drive through wash. Those things are a paint killer.
  17. Jan 17, 2017 at 4:30 AM
    #37
    gpb
    Atlanta
    aka "scratch factory". I also never have the dealer do a wash.
    shakerhood and dYL0n[QUOTED] like this.
  18. Jan 17, 2017 at 4:45 AM
    #38
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Some guys have all the luck.
  19. Jan 17, 2017 at 5:24 AM
    #39
    dYL0n
    Dyl0n
    New Orleans, LA
    Im a 2 bucketing, foam gun spraying, blow dry drying animal. :goingcrazy:
    shakerhood and gpb[QUOTED] like this.
  20. Jan 17, 2017 at 5:28 AM
    #40
    gpb
    Atlanta
