2016+ Toyota Tacoma OVTUNE 1.05 - Tune Development thread
Discussion in '3rd Gen. Tacomas (2016+)' started by OVTune, Jun 9, 2017.
  1. Feb 20, 2019 at 9:02 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Wasn’t going to, was just gonna have it for watching diagnostics every once in a while
  2. Feb 20, 2019 at 9:03 AM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB OV-tuned
    OV tuned
    My carista has worked fine.
    Anchovy likes this.
  3. Feb 20, 2019 at 9:14 AM
    tazmoto1526
    tazmoto1526 Member
    Texas
    2018 Silver OR 4x4
    OVTUNE
    Download of the new FM went very smooth.Installed the flash manager and downloaded all files ready for my A4A60.I loaded the base 87 tune and let the truck run for 10 minutes.Truck drives much better on the new 1.05 87 tune.I found the entire process very simple on an old windows 7 laptop around 10 years old with not many window updates.Awesome job Mat...
    hbaade, SpeySquatch and ihatemytruck like this.
  4. Feb 20, 2019 at 9:23 AM
    prodemann
    prodemann Well-Known Member
    Phil
    Carver, MN
    2017 TRD Off Road AT DCSB Silver Sky
    TRD Pro grill, OVTune
  5. Feb 20, 2019 at 9:30 AM
    cm517chris
    cm517chris Active Member
    2016 Tacoma V6 Limited
    Bed cover, rain shields, paint protection, hitch cover, led fod lights. OVTune(Pending)
    B030 2016. 2016 so, unable to obtain the performance tunes for the 3 octanes, I have installed the base options, and thats alright, because for me the base tunes are grest. But after plugging in and running toyflash, and "flashing it" I get the message "error downloading tune". Anyone else come across this one yet?
  6. Feb 20, 2019 at 9:35 AM
    prodemann
    Phil
    Carver, MN
    I’m the same version as you and can only run the base tunes. The error I get is the same when I try to download the performance tunes and that is because they aren’t available to us yet. End of month is what Matt says.
  7. Feb 20, 2019 at 9:37 AM
    cm517chris
    Gotya. The problem that I'm having is that the base tunes are the ones giving me the "error downloading tune". Going to give it another try soon, and hopefully sort things out. The error occurs while flashing.
  8. Feb 20, 2019 at 9:39 AM
    ihatemytruck
    Dave
    Southern California
    OV tuned
    Are you dongle or no dongle?
  9. Feb 20, 2019 at 9:39 AM
    prodemann
    Phil
    Carver, MN
    You’re downloading the tune before flashing, right? When you flash it asks you to choose the tune you’ve already downloaded
  10. Feb 20, 2019 at 9:40 AM
    cm517chris
    I'm dongle-less. With the fancy orange obd connector.
  11. Feb 20, 2019 at 9:50 AM
    Wixo
    Wixo Best Member
    Mau
    '17 Tacoma TRD Off-Road Inferno
    And now we wait...
  12. Feb 20, 2019 at 9:53 AM
    InternationalHarvester
    InternationalHarvester Well-Known Member
    Sparks, NV
    2017 TRD DC LB OR 4x4
    OVTuned, Can-Back, In-Bed tool box, Sprinter D Rings in Bed
    To be fair to @acemastr, he did mention in an earlier post that he only had 1 misfire and shared the celebration with us by posting it.
    I too have been struggling with high misfire count. I haven’t had time to log anything on the new 105 tune though. I don’t plan on making any judgments on it until I have several miles in the clock.
    My hope is that the new 105 helps reduce my count.
    In full disclosure, I haven’t replaced my crank shaft sensor (it’s not on the list), but I may do it as a next step if 105 doesn’t help.
    Reypac24 and Deucer01 like this.
  13. Feb 20, 2019 at 9:56 AM
    GPatriot
    GPatriot Well-Known Member
    Cincinnati, Ohio
    2016 Black Tacoma Sport 4x4 V6 DCSB AT Loaded
    OVTune, 265/70/R17 KO2s, RCI Sliders, Misc mods to make mine unique
    Thanks for asking this question. I was wondering this myself.
  14. Feb 20, 2019 at 9:56 AM
    ihatemytruck
    Dave
    Southern California
    OV tuned
    Did you double check that where it says dongle, you selected no.....it defaults to yes I believe.
  15. Feb 20, 2019 at 9:57 AM
    ihatemytruck
    Dave
    Southern California
    OV tuned
    How many do you typically get?
  16. Feb 20, 2019 at 10:00 AM
    Sparks, NV
    On the previous 105 tune, I’d see as few as 3 and as many as 27 according to Mode $06>$0C on Fusion
  17. Feb 20, 2019 at 10:01 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    May or may not have any impact on misfire count but it's something worth eliminating for sure. My truck was not on "the list" for the recall either, my 17 built in Aug 16 Baja.... and dealer/toyota to this day says it shouldn't have needed replacing. It was a $100 part and I was at my wits end at the time so I bought it myself and took 10 mins to install. Instant difference in how the truck ran, idled, even steered as though the pump was getting proper power... The tell tale sign of mine was idle being erratic on hot days - not just a little and even without A/C on along with increasingly rough idle. I knew in my case though if I let it go long enough it would fail based on how it was degrading and I wasn't taking the chance on a breakdown or engine damage just to wait to PROVE to Toyota there was indeed a problem...
    Reypac24 and taco 16 like this.
  18. Feb 20, 2019 at 10:05 AM
    Sparks, NV
    Thanks for your input. As always, it’s much appreciated.
    bshammer0 and Reypac24 like this.
  19. Feb 20, 2019 at 10:10 AM
    ihatemytruck
    Dave
    Southern California
    OV tuned
    I haven't had that high of a number... typically get some on startup and cold engine, but has never been over 10. So I'm not worried about it. Got around the same on stock tune.
  20. Feb 20, 2019 at 10:12 AM
    SpeySquatch
    2016 TRD OR DCSB
    C4Fab LoPro, BAMF Sliders, Adj. Ext ADS, 4.88's, OVTune
    Question is, would people have noticed the misfires had they never looked into it? Seems like it may be out of our control, hence I don't look for them
    PRO_Taco, Shellshock, sig916 and 4 others like this.
