2016+ Toyota Tacoma OVTUNE 1.05 - Tune Development thread
Discussion in '3rd Gen. Tacomas (2016+)' started by OVTune, Jun 9, 2017.
  1. Sep 8, 2017 at 1:15 PM
    #4001
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Lifted on 275/70/17
    Hopefully just a warning?
  2. Sep 8, 2017 at 1:16 PM
    #4002
    DES2009
    DES2009 Unknown Member
    Southeast Louisiana
    2017 MGM Limited
    OVT 2.0-Final 91 Stk Garmin DashCam 56 RFCC/Natika F-Cam Toyota PK3B6-35JS0 Power Tailgate Lock
    Yes. This is what I was getting at in my post from a few days ago . . .
    inksin and Egnaro like this.
  3. Sep 8, 2017 at 1:17 PM
    #4003
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    I am bias based on my experience, but it seems that anyone who had a Tacoma produced before this spring should invest $100 in a bit of insurance with that sensor. Mine wreaked so much havoc - I just hope it wasn't enough to cause long-term damage over the first 10k miles I owned it. Mine was shuttering a LOT before replacement, running super-rich, idling 2x what it did afterward... but Toyota of course said it was all in my head and there was nothing wrong with my truck since no CELs. Idiots.
    I enjoy my truck now and I'm sure many others who have and will continue to take advantage of this mod will find themselves swapping sides from the Turds to the Unicorns soon enough...
    deadgame and speedtre like this.
  4. Sep 8, 2017 at 1:17 PM
    #4004
    perkj
    perkj Well-Known Member
    @OVTune
    if I understand correctly I think what you are saying is that due to variences in the CPS and with some of the CPSs teetering on the verge of being out of the acceptable variance or already outside the acceptable variance, the tune is experiencing this issue due to it being more aggressive with the ignition timing. Whereas with the stock tune not being as aggressive, its able to tolerate the out of bounds variance. That basically it in a nut shell?
    taco 16 likes this.
  5. Sep 8, 2017 at 1:21 PM
    #4005
    speedtre
    speedtre Well-Known Member
    DirtySouth
    '17 DCLB TRD OR AT 4x4
    I hope this ends up being me. I'm just can't get off my wallet until the shifting is more sorted than it sounds like it is still with 1.02....that is my #1 complaint by far.
    sig916 likes this.
  6. Sep 8, 2017 at 1:25 PM
    #4006
    Quicksand Jesus
    Quicksand Jesus Well-Known Member
    Derrick
    Littleton, Colorado
    2002 Toyota Tacoma TRD DCSB
    3" OME Lift with Dakar Leaf Pack - SPC Upper Control Arms - Trail Gear Weld On Rock Sliders - 285/70/16 BFG KO 2's - Fuel Matt Black Anza Wheels - Bushwhacker Cut In Fender Flairs- Deck Plate Mod - Paranoid Fab Scangage Mount - URD Throttle Body Gasket - Flowmaster American Thunder Cat Back Exhaust - Compustar Security, Remote Start, Keyless Entry.
    Agree! I was experiencing the shudder as well before I had the CPS replaced due to the re-call. After replacement no shuddering whatsoever! Ran like a different truck.
    bshammer0 likes this.
  7. Sep 8, 2017 at 1:26 PM
    #4007
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    No worries, post like this is not snarky or condescending, this helps me to target what to do next.
    I have driven one but no over long periods. On the dyno I watched how it shifted in D with various amounts of throttle and it *seemed* to shift like a normal car. Between 2000 to 3000 quickly.
    it's kind of difficult to gauge what everyone is asking for.
    The transmission learning and control maps are simply hard to tune. To really perfect shifting I would need someone who would be willing to drive on many different shift parameter maps. Because I cannot disable the learning. When I do the truck simply doesn't shift at all.
    Being unable to disable the learning leaves to me just trying to tailor the learn to maximize " best" shifting, but the complexity is compounded because every torque map uses raw numbers that simply have no meaning.
    as insane as it sounds it's the difference of less than 1* advance on the table in certain low load areas. Areas where the difference in ignition is 0.5* and I feel the CKS issue is compounded when the ECU is trying to differentiate a half degree through a crank wheel / sensor giving bad readings.
    Fixing it is adjusting toyotas OEM maps that I normally don't have to touch.
    anyways guys I'll be back later to get anyone with the issue sorted out.
    riz_atx, bshammer0 and inksin like this.
  8. Sep 8, 2017 at 1:48 PM
    #4008
    fxrman
    fxrman Well-Known Member
    palm springs
    Quicksand 2016 trd double cab off road
    OVT 1.03 Tacoma bed matt Husky floor liners Insain fab aluminum bumper with Baja design s8 30" light bar DB custums grill with Baja design s8 30" light bar
    What is a good laptop that is no too expensive that would be only used for this install...?
    Thinking i might get one just for this.
  9. Sep 8, 2017 at 1:48 PM
    #4009
    Egnaro
    Egnaro Watch this
    Brett
    AZ
    16 Inferno DCSB Offroad 4x4
    Ricochet full skids, Mobtown rear with swing-out, toytec boss 2.0, OV tuned
    My shifting seems fine, drive like grandma it shifts like grandma. Drive like a teenager, it shifts high in rpm range. Normal driving to me it shifts around 2-3k, if im lazy driving it shifts lower. I just let it do its thing. The BIGGEST improvement to me with this tune is the hesitation is gone when I do want to give-er-hell. Now it just gets up and goes, shifting is responsive, throttle is responsive. The hunting for gears thing on the freeway is what its designed to do to maximize fuel efficiency. If anyone thinks their gas mileage is bad and shifting is to blame, ask a 2nd gen guy what his gas mileage is and you might not mind the shifting as much.
  10. Sep 8, 2017 at 1:49 PM
    #4010
    Egnaro
    Egnaro Watch this
    Brett
    AZ
  11. Sep 8, 2017 at 1:49 PM
    #4011
    bshammer0
    Brandon
    Nashville, TN
    Only thing I can say to this is that while the shifting is still weird... the actual quickness and smoothness of the shifts makes a big difference. It's not really so annoying now as it is weird how fast it upshifts, but downshifts aren't delayed. Press the gas a bit, and you're downshifting smoothly. The other changes make the shifting less of a bother b/c it's so smooth... and all of the other drivability improvements are worth the price of admission!
    sig916 and Egnaro like this.
  12. Sep 8, 2017 at 1:52 PM
    #4012
    fxrman
    palm springs
  13. Sep 8, 2017 at 1:56 PM
    #4013
    rnicholls
    rnicholls Well-Known Member
    2016 TRD OR DCLB
    Waiting for my files like :goingcrazy::goingcrazy::goingcrazy:
  14. Sep 8, 2017 at 2:03 PM
    #4014
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    Can those shift parameter maps be duplicated? So 16 maps are still in place but all 16 have the same parameters? Or is that what you did in consolidating as much as it could be?
  15. Sep 8, 2017 at 2:29 PM
    #4015
    bshammer0
    Brandon
    Nashville, TN
    Just had to run a quick errand and in trying to put the weirdness into better clarity, what I think is different now is that it almost seems to skip a gear between 4-6. It seems to shift pretty normally up to 3rd, but then just goes shift shift 6th. I'll have to validate the RPMs and actual gears with my OBD when I have more time but that's what feels different about it on mild acceleration whereas it actually did hold the gears a bit longer on 1.01b. Again - need learning before I can say this isn't temporary and it ISN'T the end of the world, but is odd...
    Edit: but DAMN that throttle :) makes me very happy.
  16. Sep 8, 2017 at 2:35 PM
    #4016
    sig916
    sig916 Well-Known Member
    Got this specifically for the tune. No need to disable anything. Its small and portable to keep it inside glove compartment.
    perkj, 17TRDOR and speedtre like this.
  17. Sep 8, 2017 at 2:39 PM
    #4017
    Tacoma2GR
    Tacoma2GR Well-Known Member
    Hesperia, CA
    2020 TRD Sport 4x4
    Which website sells this?
    fxrman likes this.
  18. Sep 8, 2017 at 2:40 PM
    #4018
    speedtre
    DirtySouth
    I hear you, but if the schizophrenic highway shifting is not fixed it's just not worth almost $800 to me. I'll wait a while hoping OVTune can sort that out but if not I'll be test driving (extended test drives!) 2019 Rangers and Frontiers next year (maybe Tundras if they finally update it). That Ranger Raptor with the 3.2 diesel looks to be the dogs bollox! :D
    AFMurse2014, Ares32 and bshammer0 like this.
  19. Sep 8, 2017 at 2:44 PM
    #4019
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD
    BBP 2016 TRD Sport Access Cab 2wd
  20. Sep 8, 2017 at 2:47 PM
    #4020
    su.brat
    su.brat Tacomakart
    TW
    we all love each other here i'm sure.
    but at this point the MT guys are hating the AT trucks more than ever. gawd. :anonymous:
    yeah. just wait until 2019. sounds like a plan. why are you posting here, again?
