Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jun 19, 2019 at 7:50 PM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT DCSB, SC YotaWerx, 4.88's
    None of this is necessary because according to the MT owners they have no issues - so just keep making the AT's better - someday we might be included in the MT family of Tacoma. ;)
  2. Jun 19, 2019 at 8:05 PM
    ry18Tac
    ry18Tac Well-Known Member
    North Texas
    2018 Quicksand Tacoma TRD 4x4
    Ovtuned
    Is there a way to get the truck out of limp mode if it throws the brake override malfunction so I could drive it to the dealership with the light still on?
  3. Jun 19, 2019 at 8:12 PM
    Shellshock
    Iowa
    When @Cav_BluTRD truck went to limp mode we unplugged TSS and cleared codes and it was fine for a couple days.
    uploadadventure likes this.
  4. Jun 19, 2019 at 8:27 PM
    ry18Tac
    North Texas
    Ovtuned
    I cleared the code earlier and reflashed. I was just thinking if it comes up again I would just take it straight to the dealer but not if it stays in limp mode.
  5. Jun 19, 2019 at 8:30 PM
    AnotherPDXTacomaGuy
    AnotherPDXTacomaGuy Member
    2018 OR White Tacoma MT
    Just speakers, wheels and plastidipped emblems
    Awesome, I was about to buy the 1.05 now honestly, should I wait, or do current owners get the upgrade to 2.0? Or are they only eligible for 1.X versions?
  6. Jun 19, 2019 at 8:47 PM
    Tbrooks2444
    Tbrooks2444 Well-Known Member
    Go ahead and purchase if you like. All future updates are free of any extra charge.
  7. Jun 19, 2019 at 9:32 PM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    Just because we don't have issues doesn't mean there is not room for improving the tune;)
    tonered likes this.
  8. Jun 20, 2019 at 1:24 AM
    Phich
    Phich Porkchop Express
    San Antonio
    2017 TRD Off Road tuned to KDMax perfection
    Six Demon Bag
    I have not reset the learning values since installing 1.05 and have run 91 base and 87 base. I have the instructions but I'm feeling very lazy - can the LV's be reset by battery disconnect or do I have to drive to my work to pick up my laptop?
  9. Jun 20, 2019 at 2:11 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2016 Black AT DCSB 4x4 TRD
    JL Audio C2690tx Speakers Alpine MRV-F300 JL Audio 10" Sub - Full length Ported Sub Box Kicker Tweeters BFG KO2's 265/70/17 Tint N-Fab Bars Husky WB Mats AVS Visors Console Divider Tacoma Tonneau Cover ALL PRO 1.5" wheel spacers aFe CAI w/ Dry filter TRD Wheels Custom Remote Starter TRD Pro Grille ROAV Dash Cam 3" RC Lift Turn-down exhaust pipe TRD PRO Shift Knob vF Tune
  10. Jun 20, 2019 at 5:22 AM
    2017 TRD Sport
    2017 TRD Sport Active Member
    David
    2017 TRD Sport
    456 gears. OV tune. Lift. 285/70/17 tires
    I have seen this asked several times but can’t find any definite answer. Will my truck throw any codes if I install the new dump tubes?
  11. Jun 20, 2019 at 5:44 AM
    GPatriot
    GPatriot Well-Known Member
    Cincinnati, Ohio
    2016 Black Tacoma Sport 4x4 V6 DCSB AT Loaded
    KDMaxPro 10.0, OME 2" Med Duty lift, RCI Sliders, RoofRack, Skid Plate, etc.
    Thank God. My truck still has it's good days and bad days. One day I'm smiling the next I'm aggravated. 1.05.1 93 Performance.
    HelloMyNameIs likes this.
  12. Jun 20, 2019 at 7:54 AM
    CementTaco2019
    CementTaco2019 Well-Known Member
    2019 TACO
    K&N Intake
    If they don’t have an adapter to pull the 02 sensor out to read less flow it’s going to throw a code. Or there would be a selection within the tune system to eliminate the sensor. These are essentially removing the Cat which in turn would always throw a code on a factory set up. Even if it didn’t throw a code of the inspection shop looks under the hood or under the truck they are going to reject it as soon as they see aftermarket down pipes with no converter.
  13. Jun 20, 2019 at 8:51 AM
    dabbinuguay
    dabbinuguay Well-Known Member
    PDX, Oregon
    2017 Tacoma TRD OR DCSB
    I'm sure this info has already been shared somewhere on pages 1124 - 1756, but couldn't find it in a search.
    Didn't want to run the flash manager on my work laptop, so instead of picking up a dedicated laptop on craigslist (will probably still do this), I'm trying to get flash manager up and running on my wife's old windows 7 (64bit) laptop.
    After installing the flash manager, I got an error when trying to start up.
    Error was super useful microsoft error, something like "Application cannot start because blah blah code 0xc000007b"
    Turns out I needed to update the visual c++ packages on this machine.
    Took me a while to figure this one out, because the flash manager install looks like it installs a c++ package, which I assumed was a dependency.
    I downloaded and installed them from here, and that apparently fixed the problem without a reboot.
    https://support.microsoft.com/en-us/help/2977003/the-latest-supported-visual-c-downloads
    Hope that helps anyone who runs across the same problem.
    Is there a different thousand page thread I should have posted this in?
  14. Jun 20, 2019 at 8:53 AM
    JD45535
    JD45535 Well-Known Member
    Jeff
    2017 Black TRD Sport
    Pro Comp Series 34 Wheels Falken Wildpeak Tires Rough Country Bed Cover Cali Raised LED Fogs and Ditch Lights
    I vaguely recall seeing something about a handheld tuner in the works?? Was this true?
  15. Jun 20, 2019 at 9:03 AM
    dabbinuguay
    PDX, Oregon
    Of course, now that I get to the registration procedure, it sure seems like getting a newer laptop seems like a better solution.
    I get that proprietary code must be encrypted and secured, but man, just getting this thing setup is a process, and then it's not portable between laptops?
    No license key that can be activated on multiple laptops, even if it's tied to a single VIN?
    Sorry, that's pretty weak sauce. Hope you guys come up with a more practical solution in the future.
  16. Jun 20, 2019 at 9:08 AM
    Phich
    San Antonio
    Six Demon Bag
    How does one reset learning values in PCMFlash?
  17. Jun 20, 2019 at 9:09 AM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Practical how? How many laptops do you need to have it on. The rest of us do just fine using 1 laptop. If you need to change to a new laptop, Mat will send you a new reg key (only a certain amount of times).
  18. Jun 20, 2019 at 9:38 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Sorry, but this is a piece of cake IMHO. I got a new computer and got a REG file for it quickly.
    In a market where mods are replicated shamelessly, it makes all the sense in the world and is pretty invisible after the first go around.
    BlazinBlueTaco and Shellshock like this.
  19. Jun 20, 2019 at 9:39 AM
    dabbinuguay
    PDX, Oregon
    So ....
    My work laptop is a no-go because of corporate anti-virus issues. My desktop is a no-go, because it's a desktop.
    My wife's laptop is an old windows 7 laptop. It will probably end up working, but I don't want to depend on it long term.
    Yes, I will buy a new laptop and be happy, I was just hoping to put it off a bit.
    Again, no big deal, but it delays getting the tune on the truck, so there's that...
    I will be keeping a laptop in the truck for a while, because I've read enough of this thread to see that some issues do pop up, and Murphy's law states that will happen to me in the Alvord desert.
    I'd like that laptop to be more dependable than my wife's old one. (Battery holds a charge for 10min)
    All that up to this point, is entirely solve-able, and I don't really have any issues with that.
    I need a new laptop, I get it, it's fine.
    My main beef ( or concern, or feedback), is the registration/activation process.
    I can't think of any software I use that has this type of registration and licensing process.
    Set it up halfway, send an "EMAIL?!?!?" with some codes, and receive an activation key 1-3 business days later.
    Maybe it's much faster than that, I'm just going by the instructions in PDF file.
    What if you run into an issue and you need to re-flash, or pull codes, or anything in a hurry, but the 1 laptop you have registered happens to be unavailable where you are?
    You can't borrow your buddy's laptop for a day just to get back up and running.
    I get that OV needs to make sure that tunes aren't shared/pirated, but it's 2019. Seems like this is the sort of software problem that has been solved already.
    Maybe there is some logical reason it must be this way.
    Sorry if I sound harsh, but i'm pretty excited to get this tune in.
  20. Jun 20, 2019 at 9:45 AM
    Shellshock
    Iowa
    This isn't that bad. try licensing and activating enterprise software. this is nothing.
    BlkTaco47 and tonered like this.
Thread Status:
