2016+ Toyota Tacoma OVTUNE 1.05 - Tune Development thread
Discussion in '3rd Gen. Tacomas (2016+)' started by OVTune, Jun 9, 2017.
  1. Nov 29, 2019 at 8:07 AM
    LuvMeSumTacos
    LuvMeSumTacos Well-Known Member
    Richmond, VA
    2020 Tacoma TRD Off-Road DCSB
    3 inch level/lift, Toyo Open Country R/Ts, and MBRP exhaust.
    Anyone know if I can use the OVTune dongle and software to run a diagnostic on a older Tacoma (‘98)?
  2. Nov 29, 2019 at 8:10 AM
    Shellshock
    Shellshock Guy who drives a lot
    Iowa
    2017 DCSB TRD OR MT QUICKSAND
    you can use the kit with techstream
    LuvMeSumTacos likes this.
  3. Nov 29, 2019 at 8:37 AM
    LuvMeSumTacos
    Richmond, VA
    Is techstream free to download and use?
  4. Nov 29, 2019 at 8:44 AM
    agabriel78
    agabriel78 Active Member
    2018 Cement DCSB
  5. Nov 29, 2019 at 8:44 AM
    LuvMeSumTacos
    Richmond, VA
  6. Nov 29, 2019 at 8:45 AM
    OMGitsme
    OMGitsme Well-Known Member
    2019 OR DCSB MGM
    All you guys have a Windows laptop?
  7. Nov 29, 2019 at 8:48 AM
    Shellshock
    Iowa
    I have a Mac running bootcamp
    double_duez likes this.
  8. Nov 29, 2019 at 8:49 AM
    progmater
    progmater Member
    Omaha
    2018 Inferno TRD Sport
  9. Nov 29, 2019 at 10:08 AM
    Venator_2033
    Venator_2033 Well-Known Member
    4" inch lift Dakar leafpacks/Bilstein 5100 B110/Fox 2.0 coil-overs/Catless Dual Exhaust w/H-pipe/OVtuned1.05/RCI Sliders/HID kits Hi/Low/AFE Intake with scoop and 76mm throttle body/Total chaos Fab UCA's
    Only the betas that had octane learning in them (designated by having OLE in the file name) did Mat put up in instructions to do a few 2nd or 3rd gear pulls to about 5000-5500 RPMs and he also said they weren't necessary as they merely helped speed up the process of learning the knock correct learn values, KCS trims, ignition timings things like that based on the octane of fuel used.
    So with the current beta files that are on the beta page just do what you normally would do after a fresh flash.
  10. Nov 29, 2019 at 11:12 AM
    DES2009
    DES2009 Well-Known Member
    Southeast Louisiana
    2017 MGM Limited
    OVTune 2.0-Beta3
    See attachment
  11. Nov 29, 2019 at 11:24 AM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    I just drive it like i stole it. i don't notice all the changes that other people mention. drove great right off the bat.
    Shellshock likes this.
  12. Nov 29, 2019 at 12:54 PM
    PhogDog
    PhogDog Well-Known Member
    16 Grey Limited
    I think that was only recommended if you reset learned values.
  13. Nov 30, 2019 at 10:50 AM
    ihatemytruck
    ihatemytruck Professional dumbass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB.
    OV tuned
    Just drive it
  14. Nov 30, 2019 at 3:28 PM
    Chasespeed
    Chasespeed Well-Known Member
    WMass
    2018 TRD OffRoad
    Seeing how long I can keep stock(ish) OVTuned
    Okay, posting, while I search, and scan...
    Tactrix came in today.
    Software is all set.
    I cannot connect to the truck, via download mrg, the datalogger, or TIS.
    I am sure I am missing something, unless I have a hardware issue. But tried all the USB ports on the laptop(and I know they work). I have lights on the interface....
    Thanks,
  15. Nov 30, 2019 at 3:31 PM
    El Chivo Norteño
    El Chivo Norteño Well-Known Member
    Central Oregon
    2020 White DCLB 4X4 Off-Road
    Need to use a USB2 port and make sure you installed the Tactrix driver. Beyond that make sure your in ignission on mode (2x push on start button without stepping on the break)
    EDITED For definition error
  16. Nov 30, 2019 at 3:31 PM
    Shellshock
    Iowa
    Did you turn the truck on?
    SpeySquatch likes this.
  17. Nov 30, 2019 at 3:32 PM
    GoldenBrew
    GoldenBrew Subscription Terminated
    Factory Fresh Taco
    install open port drivers/software ? Push start button twice = truck on not running?
  18. Nov 30, 2019 at 3:39 PM
    rdpoe
    rdpoe Well-Known Member
    Central Kentucky
    2018 TRD OR DCLB (dead), 2019 TRD OR DCLB
    Not accessory, ignition on mode
    El Chivo Norteño likes this.
  19. Nov 30, 2019 at 3:44 PM
    El Chivo Norteño
    Central Oregon
    Correct my mistake! I’ll edit my post
    rdpoe likes this.
  20. Nov 30, 2019 at 3:45 PM
    Chasespeed
    WMass
    2018 TRD OffRoad
    Missed the openport drivers. Downloaded, and connected.
    Now, I need to re-read.
    Thanks
    rdpoe and El Chivo Norteño like this.
