Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Dec 5, 2019 at 10:56 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    $325 like always
  2. Dec 5, 2019 at 10:58 AM
    OVTune
    OVTune
    Yes, with what we are able to control. To get around the limitations we are testing where the ecu selects a completely different transmission map when cruise is active. It's the only way. So we are making a whole new set of tables for each gear when the cruise control flag is on in code
  3. Dec 5, 2019 at 10:59 AM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    Awesome,I will let him know and proceed from there.
  4. Dec 5, 2019 at 11:00 AM
    mackdave
    mackdave Active Member
    2019 TRD OR QS
    2" bilstein lift, custom grill, ditch lights, fog lights, light bar, rear work light, switch pros, remote start, kicker speaker upgrade, alpine amp, raptor lights, carbon fiber dash trim wrap, OVTUNED, Method MR315, Falkin wildpeaks, MESO 3rd Brake, Meso puddle lights
    Thanks for all you do.
  5. Dec 5, 2019 at 3:32 PM
    Pruby18
    Pruby18 Well-Known Member
    2019 DCSB OR 4X4
    Been a while since I’ve been on here. Will the 2.0 be brining back the Regular use of ECT? Or is it only to switch tunes?
  6. Dec 5, 2019 at 4:37 PM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    That’s a lot of work. Sucks.
    I wish that the parameter for the adaptive cruise can be changed from fast to normal. Such a pain in the ass.
  7. Dec 5, 2019 at 6:37 PM
    SpeySquatch
    2016 TRD OR DCSB
    Yes, in the final tune.
    BeardedYinzer likes this.
  8. Dec 5, 2019 at 6:52 PM
    Bigetaco22
    Bigetaco22 Well-Known Member
    Kenny
    2016 DCSB TRD OR
    Bilstein 6112/5160s. OME leaf springs. 285/75/16. RC tonneau cover. Supernova v3 led lows, highs, and fog lights. Kicker speaker upgrade.
    Has anyone noticed their truck running super rich at start up. I know it is tuned to run rich for like 10 seconds at start up, but it was so bad tonight that it actually smelled rich in the truck when I started it and i have never had that issue before.
  9. Dec 5, 2019 at 6:54 PM
    SpeySquatch
    2016 TRD OR DCSB
    Like money coming out of the vents?
  10. Dec 5, 2019 at 6:55 PM
    Bigetaco22
    Kenny
    2016 DCSB TRD OR
    I could only wish that was the case lol
  11. Dec 5, 2019 at 6:55 PM
    LTacoman
    LTacoman Well-Known Member
    Luis
    Gilbert, Az
    2019 F150 Lariat EB
    :eek:
  12. Dec 6, 2019 at 2:34 AM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    right now I don’t like how the transmission is with cruise control on. At lower speeds, the TC never locks while cruising. Tried on both versions of 2.0.
  13. Dec 6, 2019 at 5:04 AM
    OVTune
    OVTune
    If the temperature outside was very cold it will do this. Rich enough to smell like raw gas if it's cold enough.
    Also, we will be donating $50 from all tune kit/handheld orders placed from today through the 15th to St Judes
  14. Dec 6, 2019 at 5:21 AM
    Bigetaco22
    Kenny
    2016 DCSB TRD OR
    Good info I guess. It was probably 30 degrees. Just didn't think I had ever seen that before. Maybe the wind was blowing just right or something that made it seem a little worse.
  15. Dec 6, 2019 at 5:21 AM
    chittyrox
    chittyrox When in doubt, throttle out.
    2018 Tacoma TRD Off-Road DCLB
    Much thanks for stepping up and donating that to a great cause!!! =]
    slvrtaco11, shacol and SC4333 like this.
  16. Dec 6, 2019 at 6:08 AM
    Deucer01
    Deucer01 Well-Known Member
    North Georgia
    2023 Tacoma ORDCSB 4x4, 2024 4runner TRD ORP
    I finally remembered to check this morning. Set cruise control to 40 mph and watched OBDFusion and torque converter remained unlocked.
    Tac0Tic0[QUOTED] likes this.
  17. Dec 6, 2019 at 7:11 AM
    OVTune
    OVTune
    Torque convert locking or not depends mainly on the gear you are in and speed, not just the speed
    and when cruise control is active, throttle demand position via accelerator is 0%, so it rides the bottom ends of all the tables, so a majority of the time will not lock
    awdvkd115, ihatemytruck and BOMBS like this.
  18. Dec 6, 2019 at 8:27 AM
    ohioboater
    ohioboater Well-Known Member
    2017 DCLB 4x4 Sport
    Seems like your 2.0 shift logic makes a lot more use of the torque converter than Toyota's original code. Is there any risk of long term wear as a result, or is it still within design specs?
    Don't get me wrong - I think the truck drives way better with 2.0's shift logic. Just want to make sure I'm not compromising longevity.
    YotaDriver631 likes this.
  19. Dec 6, 2019 at 8:28 PM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    but why does it lock when not in CC? If it’s unlocked, I remove CC, it locks.
    it always locked in every other version of the tune I’ve ran.
  20. Dec 6, 2019 at 8:29 PM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
Thread Status:
