Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jan 6, 2020 at 2:29 PM
    crookedcoast
    crookedcoast Well-Known Member
    2025 OR MT
    Before I pull the trigger on my order. Anybody have any issues flashing with a Surface Pro? I only have usb 3.0 ports.
  2. Jan 6, 2020 at 2:29 PM
    stiles88
    stiles88 Well-Known Member
    Seattle (Bothell WA)
    2020 GLE 350, 2008 FJ
    I'm at least a few thousand miles since the last flash. I flashed it in August because it seemed like it was driving like stock again. Then it started revving on it's own in October and so I reflashed it again in November. I'm not sure if it's tune related or something else, but I haven't made any modifications recently that should cause something like that.
  3. Jan 6, 2020 at 2:32 PM
    SpeySquatch
    2016 TRD OR DCSB
    There has been a few versions of the 1.05 87 octane. Which version? beta?
  4. Jan 6, 2020 at 2:32 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I have a Pro 6 with only the one 3.0 port. Never a problem for me.
  5. Jan 6, 2020 at 2:38 PM
    stiles88
    I don't think it's the beta, but I have also had a hard time keeping up with all of the updates. I believe it's just the base 1.05 87 tune. I downloaded it in August and I reflashed that same tune in August and again in November. Thank you for the help btw!
  6. Jan 6, 2020 at 2:38 PM
    Inferno!
    Inferno! Well-Known Member
    El Dorado Hills
    2018 TRD OR Inferno 285/65/17
    Supercharger, sway bars, lift, leather, tires, Gobi, etc.
    I'm still running the 1.05_87 tune. I love it, although I will try 2.0 when it's official.
  7. Jan 6, 2020 at 2:39 PM
    SpeySquatch
    2016 TRD OR DCSB
    If you like how it drives just keep it for a while and see if the high revs fade, if not, then switch. Wish I could help more, but better advice would likely come from someone else. Also, side note...could be winter gas...just a guess
    stiles88[QUOTED] likes this.
  8. Jan 6, 2020 at 2:42 PM
    MunchTIME
    MunchTIME Well-Known Member
    SD, CA
    Make sure your AC is off, it can cause some pretty aggressive surges.
    SpeySquatch likes this.
  9. Jan 6, 2020 at 2:43 PM
    stiles88
    I like how it drives after the revving stops. It's less ideal when I'm trying to very slowly back out of my driveway and it tries to launch itself! I feel like if it wasn't tune related, the problem would exist more often than only after the initial start up. Winter gas could be a factor as I didn't have the tune this time last year.
  10. Jan 6, 2020 at 2:44 PM
    stiles88
    I live in Washington and the AC hasn't been on for months! :)
    MunchTIME[QUOTED] likes this.
  11. Jan 6, 2020 at 2:46 PM
    Shellshock
    Iowa
    I just don’t share my truck. Problem solved.
  12. Jan 6, 2020 at 2:46 PM
    SpeySquatch
    2016 TRD OR DCSB
    Sounds like you may be using a higher tip-in version. I don't recall one being available in 87 octane except for 4.88 gears, but I could be wrong
  13. Jan 6, 2020 at 2:49 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I'd typically share the same mentality... but shit happens. I even worry that a dealer/mechanic may feel inclined to add fuel and would add 87. The Lexus dealer has filled our tank in the past.
  14. Jan 6, 2020 at 2:53 PM
    stiles88
    I think it is actually the 87 performance tune I'm running. I definitely didn't have these issues before the last few months though and I know I've used the same tune from day one in May 2019. I just downloaded it again in August to make sure I wasn't missing anything.
    SpeySquatch[QUOTED] likes this.
  15. Jan 6, 2020 at 3:03 PM
    Saeros
    Saeros #dealermole
    Canada, Eh!
    2022 Venza Limited
    If you have defrost mode on or the floor/defrost mode, the AC will still cycle.
  16. Jan 6, 2020 at 3:06 PM
    stiles88
    Now that I do have on almost all the time! I will do some testing without the defrost mode on the next few times I start the truck up and see how it does. Thank you to everyone for all of the help!
  17. Jan 6, 2020 at 3:26 PM
    92ehatch
    92ehatch Well-Known Member
    Kinley
    Hendersonville NC
    2019 Cavalry Blue DC TRD OR 6MT
    im on a surface pro "5" it worked fine. i took the keypad off, but left it in desktop mode. not sure what tablet mode would do
    tonered likes this.
  18. Jan 6, 2020 at 4:04 PM
    TWTaco
    TWTaco Well-Known Member
    Dave
    Switched back to 0944+87+4.88+gearlock from 19800 + 87+4.88 First drive into work this morning MPG's jumped up from 16.5 to 19.1 nice surprise! After twin turbos are released i hope to be able to maintain that 16.5 to 19.1 with them . I would expect it to drop below 16.5 because i will be heavy on the skinny pedal for a while!:mudding:
    conceptmachine likes this.
  19. Jan 6, 2020 at 4:06 PM
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    Did that tune ever come out for 04b31?
    G8R_Taco and RyanDCLB like this.
  20. Jan 6, 2020 at 4:08 PM
    TWTaco
    Dave
    Not sure . I am04B04
Thread Status:
