Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jan 16, 2020 at 9:06 AM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    It's hit or miss for me and I haven't been able to figure out what causes it. Occassionally startup is rough, or requires extra cranking. It doesn't seem to matter if it's hot/cold though.
    When hot, sometimes the engine will fire and then immediately stumble which feels like a knock. It's really strange and not caused by the tune. It was there stock.
  2. Jan 16, 2020 at 9:07 AM
    Shellshock
    Iowa
    same. I've had a few odd balls, but its not consistent.
  3. Jan 16, 2020 at 9:16 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    It is definitely worth testing, because the ECU will use almost primarily port injection at very low rpm when cold.
    Then after the engine has warmed and only after it hits warmed up temp, it will switch to using DI only (except in some few conditions, like idle is still port).
    I wouldn't be surprised if this is part of the cause. When the ECU runs on PORT ONLY, the AFR is much less consistent. I've only discovered this after individually logging each banks wideband results using LSU WBs without cats. Pair that with the fact the fuel pressure demand variable, there is a lot of inconsistency with AFR on Bank 2 (passenger side, Cylinders 1, 3 ,5)
    Luckily I can flip only 2 bits in the ECU and turn the port injectors off entirely.
    While I cannot *confirm* yet I think this has to due with the start up stratification request. Start up is primarily or majority port injection on full blast, and does a momentary dumping of fuel into the cylinders, and does not get any correction until the 02 sensors have come online.
    Inferno__Taco and wahoobie like this.
  4. Jan 16, 2020 at 9:16 AM
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    turd vote on this one - but we are not getting many <40 degree days around here.
  5. Jan 16, 2020 at 9:18 AM
    Shellshock
    Iowa
    Its currently 1 here and feels like -15 if you want to come visit.
  6. Jan 16, 2020 at 9:18 AM
    seelyartacus
    seelyartacus Well-Known Member
    San Diego
    '16 TRD Sport 4x4, grey, tech&tow pkg
    FNWheels six shooter matte bronze, Falken WildPeak M/T 295/70/r17, All-Pro Expedition leafs, Fox Factory 2.5 w/ res (front/rear), Icon billet UCA w/ sphericals, custom sliders, 4.56 re-gear, RCI bed rack , Tepui RTT, Prinsu Designs Cabrac, CBI T3 alum front bumper, CBI T3 rear bumper with dual swing away and tire carrier, 20in light bar, Warn VR10s winch, Factor 55 fairlead, flatlink, and hitch recovery point, All-pro alum skid, Rotopax, CMC, Timbren bump stops, rear Rigid Duallys, Rigid Dually ditch lights, ARB awning with LED lights, Currie F9 rear axle housing w/ Strange Engineering 3rd memb and ARB air locker., rear diff beather relocation, ARB compressor under hood, Bussman panel, 3d printed switch panel,OVTune ECU
    I am and I wasn't thinking fuel, but maybe I should? It rumbles at a light (in D, foot on brake), but is goes away when in N. It hasn't been a huge priority for me to track it down just yet.
  7. Jan 16, 2020 at 9:23 AM
    lapoltba
    CT - 06076
    I'm trying to think of why they would want to do that. Faster startup time and reduced cranking, eliminate a lean condition on startup?
  8. Jan 16, 2020 at 9:24 AM
    OVTune
    OVTune
    To heat the cats up with fuel as fast as possible.
    Inferno__Taco and Tac0Tic0 like this.
  9. Jan 16, 2020 at 9:24 AM
    Reegsy
    Reegsy Well-Known Member
    MA
    2018 TRD OR
    I did that tsb update a while back, engine still lopes @ ~1Hz on cold start (50* F garage) from time to time. If that's what you are referring to. Saw it before the tune, saw it with the tune still see it sometimes after I did the TSB. I've learned to live with it, though it is slightly embarrassing when the wife and friends ask, "wtf is wrong with your truck?"
  10. Jan 16, 2020 at 9:25 AM
    Shellshock
    Iowa
    as time goes on, it seems we could ask that about nearly everything Toyota did in the 3rd gen lol
  11. Jan 16, 2020 at 9:25 AM
    lapoltba
    CT - 06076
    Yeah, but that's after the engine actually starts. Why blast a ton of fuel into the cylinder as it's cranking?
  12. Jan 16, 2020 at 9:29 AM
    OVTune
    OVTune
    To help start the engine. It's not uncommon actually to have big pulse widths during cranking, because you need the fuel to fire.
    However watching this on my widebands on each bank, the AFR is all over the place.
    it will never truly be perfect because the calibration uses 1995 method of closed loop.
    But I'd like to test out on trucks that have this issue how they respond to PI disable on cold engine
  13. Jan 16, 2020 at 9:39 AM
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    I can’t say I’m Having any startup issues. If needed for a test guinea pig then I’d be glad to help any way I can just don’t think my truck is having any major issues here in Alabama while we’re having 60-70 degree days mid January. In about 3-5 days it’s gonna drop to highs in 40’s but nothing like the cold climates up north.
  14. Jan 16, 2020 at 9:54 AM
    BigBeej
    BigBeej Well-Known Member
    Bryan
    Vista, Ca
    Anyone in the San Diego area (preferably north county Vista area) have experience with the install and setup? Got mine for Christmas and am ready to install but computers are my nemesis.
  15. Jan 16, 2020 at 9:54 AM
    mAtTyG04
    mAtTyG04 Well-Known Member
    Edmonton
    2019 Quick Sand OR
    6112 Front Suspension, Fox 2.0 Rear Shocks, Nitto Ridge Grappler - LT285/75R17 C, Rear Blackout Tacoma Badge, De-badged, Icon Rebound Wheels, TRD Grill Gights, CBI Ditch Light Brackets w/ Baja Design Lights, Husky Liners, JBA UCAs, Geenlane Off-road Sliders, Tacotrooper Decal, DuraBump Rear Bump Stops, Pro-clip USA Phone Mount
    It's been -40 C here all week. No rough start ups / unsmooth engine idling. 2.0 BETA 4.88, 91 performance.
  16. Jan 16, 2020 at 10:01 AM
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
    My engine has idle fluctuation when cold, although no startup issues. I’d say 50 rpm in both directions, enough to feel and see the needle bounce around. Can’t remember if it was there with stock tune or not, I’m on 2.0 19800 04a61.
    MOC221_ likes this.
  17. Jan 16, 2020 at 10:03 AM
    BOMBS
    BOMBS Well-Known Member
    2017 Black Tacoma TRD Off Road
    I'm on Beta 2.0 with no start up or idling issue.
  18. Jan 16, 2020 at 10:15 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    ^^ Same as this with OEM calibration (04B41).
    Once in a while (and this is very infrequent), the truck sounds and feels like it's going to die for a split second and then immediately sorts itself out. My '16 did the same thing.
    TRDOBSESSED and Shellshock like this.
  19. Jan 16, 2020 at 10:19 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I'll look at my data logs and compare misfire rate on this bank to other. I do recall cylinders 1,3 were seen quite often.
    Thanks for looking into this.
  20. Jan 16, 2020 at 10:21 AM
    shawnkc10fe
    shawnkc10fe Well-Known Member
    Western Pennsylvania
    2016 Barcelona Red Tacoma Sport
    Duped Badges Removed Front Airdam Hondo Vent Mount and Radio Knobs Shift Sense Pro
    @OVTune What would this do on a decatted dump tube exhaust? I think there are only about 6-10 of us out there but just curious? I have this occur quite often.
Thread Status:
