Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Sep 7, 2018 at 10:30 AM
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    I drove 04b04 for about 40 miles then flashed 1.04R91. You can always flash back to B04 if you dont like it but I think you will since it has all those things you mentioned :)
    dskakie, Prairie Hawk and dingel5 like this.
  2. Sep 7, 2018 at 10:44 AM
    Prairie Hawk
    Prairie Hawk Unknown Member
    North border of Weird
    2016 Silver DCLB OR
    SOS Concepts Sliders Softopper OVTune 87 iphone charger WeatherTech Floor Liners F/R De-badged Rear Differential Breather Mod
    I ran 04B04 (thanks to @riz_atx) for about 3 weeks. I just flashed to 1.04r 91 yesterday and I can already feel the difference. I hear the shifts but don't feel them at all anymore, unless I'm heavy on the gas.
    dingel5, speedtre and riz_atx like this.
  3. Sep 7, 2018 at 10:49 AM
    riz_atx
    Sohail
    Spicewood Texas
    Right on! I was gonna ask you and all the others folks how that B04 tune was treating ya other than the misfires. Feels like misfires are an issue across the board.
  4. Sep 7, 2018 at 10:58 AM
    Prairie Hawk
    2016 Silver DCLB OR
    I stopped seeing the misfires after the first few days on the 04B04, but I don't put too many miles on my truck. It felt ok, but I liked 1.04 better than the tsb.
    riz_atx[QUOTED] likes this.
  5. Sep 7, 2018 at 11:40 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Yeah, my truck is one of the beloved who seem to have a hard time with low-speed ignition stability. But it's better with B04 than it has been previously. I used to get about 10-15 misfires on a city commute (17 miles one way, lots of stop and go, bit of highway) after a cold start on either stock or OVtune. Then subsequent trips if the engine was already warm would be <10 misfires but they'd still happen.
    On the latest TSB it still misfires but far less. Probably 3-5 most mornings based on my logs, then it often doesn't at all in subsequent trips and if it does it's rarely more than 1-2 in a trip which is pretty normal.
    Pretty much always happens under low load when either accelerating from a near stop or decelerating - and engine generally below 2,000. Never ever misfires on the highway or under much load though.
    So, part of me is curious whether the timing advance on 1.04r will introduce more misfires or not but is also one reason I've been holding out for 1.05 b/c I know misfires and detonation are issues he's looking into for this next release.
  6. Sep 7, 2018 at 11:45 AM
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    IS this file worth updating if one HAS NOT gotten then TSB or should I just wait for 1.05?
  7. Sep 7, 2018 at 11:48 AM
    dpippel
    dpippel Well-Known Member
    Phoenix, AZ
    Super White 2020 TRD Off Road 4WD DCSB A/T
    If you haven't had the TSB applied to your truck, you shouldn't apply 1.04R. It's ONLY for people who have the TSB.
  8. Sep 7, 2018 at 11:49 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    If you haven't gotten the TSB you must wait for v1.05, unless you get the TSB first and then install v1.04r.
    2016trdtacoma[QUOTED] likes this.
  9. Sep 7, 2018 at 11:53 AM
    Hank Heel
    Hank Heel Well-Known Member
    WA
    It’s not that you shouldn’t, it’s that it won’t let you. Dealt with this yesterday, solution was to install TIS flash latest tsb, only then could I flash 1.04r
    speedtre likes this.
  10. Sep 7, 2018 at 11:53 AM
    2016trdtacoma
    Trevor
    Utah
    Thank you. I did not get it so I;ll be waiting for 1.05
    Stoked4 likes this.
  11. Sep 7, 2018 at 12:13 PM
    jekerskel
    jekerskel Well-Known Member
    Zach
    Bellingham WA
    2004 SR5 Extended cab 2wd 5 speed
    V-LED low and high beam headlights.
    I too have had the stumble below 1500rpm on both the stock tune and the 87 1.04 tune. On some days it is very bad. The whole truck shakes. I have found that the 91 1.04 almost elimates it as does running 91 octane on the stock tune.
  12. Sep 7, 2018 at 12:41 PM
    bshammer0
    Brandon
    Nashville, TN
    Yeah, this is different than that but I know what you're referring to and I had the same experience where it kind of stumbles or feels like a slight miss - in most cases the data showed this was not actually a misfire. This is often undetectable to the driver, unless it's 2 or more cylinders misfiring at once in which case there is a slight stumble feeling
    What you describe though is why I switched to 93 (VPower
  13. Sep 7, 2018 at 12:46 PM
    jekerskel
    Zach
    Bellingham WA
    Yeah 91 octane seems to help quite a bit. I do not think this engine is designed well for 87 octane. 11.8:1 is high compression! Too high for 87 octane despite the direct injection.
    Hank Heel likes this.
  14. Sep 7, 2018 at 12:51 PM
    YotaDriver631
    YotaDriver631 Well-Known Member
    '18 Taco
    Stock tune had very slight stumbling below 1600rpm on 87.
    1.04 91 had terrible stumbling below 1600 rpms on 93octane fuel.
    TSB has no stumbling below 1600.
    Weird.
    bshammer0 likes this.
  15. Sep 7, 2018 at 1:19 PM
    Hank Heel
    WA
    Flashed 1.04r, much better, though there are slight jitters at low speed/partial throttle, it is leas prominent. I also like the behavior of transmission with 1.04r, I hated 1.04 where it would lug the motor. Much better now.
    Now the wait for 1.05 continues
    Prairie Hawk likes this.
  16. Sep 7, 2018 at 1:32 PM
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    So, we've come to the conclusion that every single truck is completely different in how it acts regardless of stock/tune/tsb/tuneR and fuel type lol
    TRACKER54, taco 16, inksin and 7 others like this.
  17. Sep 7, 2018 at 1:33 PM
    riz_atx
    Sohail
    Spicewood Texas
    driving style, elevation, temperature, humidity, ...
    so many variables lol
    dpippel and bshammer0 like this.
  18. Sep 7, 2018 at 1:39 PM
    dpippel
    Phoenix, AZ
    I'd say it's more likely we've come to the conclusion that every DRIVER'S PERCEPTION is completely different regardless of stock/tune/tsb/tuneR and fuel type.
    TRACKER54, treimche, speedtre and 3 others like this.
  19. Sep 7, 2018 at 1:43 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Wohooo. I'm rolling on 04A61, so am in the list. But I'm still on the non TSB of 1.04 so assume I'm not going to gain too much by doing this. But... I'm optimistic that 04A61 will be in the 1.05 initial release now.
  20. Sep 7, 2018 at 2:14 PM
    Frito
    Frito Well-Known Member
    Damn... is this just how it's gonna be for as long as we own these trucks or will there one day finally be a solution to these problems and all will be right in Tacoland ?
    (Oh how I wish I had bought another Gen 2 :frusty: This blows)
    thelifeaquatic likes this.
Thread Status:
