2016 Transmission Update and Fluid Levels
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wheelie, Feb 22, 2016.
  1. Mar 5, 2016 at 10:23 AM
    #201
    eseckinger
    eseckinger Well-Known Member
    Eric
    2018 TRD Sport
    Bathtime
    4a14e07e15a44a6e45d2e928468cbb56_380f7ee47ffa7393a3927122f0d0e3e640bcccb3.jpg2726f163c374267bc9cf07b21da408bc_afb6948e7169051a836167f0d24639354d781ec1.jpg3b989c98cdd83523e5da1085dbaeda49_888c50b5e44e716c8e08bd9adee54377c2d42e97.jpg
  2. Mar 5, 2016 at 1:42 PM
    #202
    16TacomaSport
    16TacomaSport Well-Known Member
    Jon
    Pittsburgh PA
    2022 Camaro SS 1LE 6spd
    What processes did you do?
    Connect a wire to port 4 and 13 on the OBD and used the trans temp detection mode?
  3. Mar 5, 2016 at 3:25 PM
    #203
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Yes
  4. Mar 5, 2016 at 3:33 PM
    #204
    splitbolt
    NW Arkansas
    Also, during the N-D-N-D... cycle, D doesn't really stay illuminated for 2 seconds. You'll see something like N-D-N-D-N-D-N-D-D-D.
    Took about 15 minutes for it to come up to temp from; truck was overnight cold.
  5. Mar 6, 2016 at 4:18 PM
    #205
    16TacomaSport
    Jon
    Pittsburgh PA
    thanks I am gonna have to do this soon.
    This is my first auto I have purchased so not sure 100% how they are supposed to behave. from R-D it takes a little bit to get going and the trans seems so indecisive on what gear to use when cruising at low speeds for me and when I am going slower speeds and then reach a slight grade going up it switches gears around trying to figure what to use and just seems odd as it takes like 2-3 tries before it picks something. I have to really put my foot in it to make it switch a gear properly and actually get moving up the hill.
  6. Mar 6, 2016 at 4:46 PM
    #206
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    how many miles on the truck do you have? After somewhere around 1500 the tranny settles down, its learning your driving style then chooses a map close to that.
  7. Mar 6, 2016 at 4:52 PM
    #207
    16TacomaSport
    Jon
    Pittsburgh PA
    i have 500miles on it so far
  8. Mar 7, 2016 at 12:34 PM
    #208
    Js16taco
    Js16taco Well-Known Member
    2016 Tacoma trd sport
    After you atop seeing the "N" do you just throw it into park and wait?
  9. Mar 7, 2016 at 1:07 PM
    #209
    splitbolt
    NW Arkansas
  10. Mar 7, 2016 at 3:10 PM
    #210
    fxrman
    fxrman Well-Known Member
    palm springs
    Quicksand 2016 trd double cab off road
    OVT 1.03 Tacoma bed matt Husky floor liners Insain fab aluminum bumper with Baja design s8 30" light bar DB custums grill with Baja design s8 30" light bar
    Well took mine in to the dealer today and they gave it to their top tranny tech and was told after a three hr. wait that the fluid level was fine but since i had called toyota corporate and had a case, they wanted the truck overnight to try and replicate the symptoms in the morning when cold.
    Mine does the r to d lag and sometimes harsh engagement intermittenly so ill guess and say they wont find anything. This morning after not driving the truck for three days it shifted fine. Frustrated and hope it does it for them so they can sort it out.
  11. Mar 7, 2016 at 3:46 PM
    #211
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    if you luck is like mine it will not act up until you get it home!
    smitty99 likes this.
  12. Mar 7, 2016 at 4:57 PM
    #212
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Mine still drives as he describes and mine has over 5000mi on it.
  13. Mar 7, 2016 at 5:01 PM
    #213
    smitty99
    Scottsdale
    Won't be good for future 2016 Taco resale values if that happens
  14. Mar 7, 2016 at 5:13 PM
    #214
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    then perhaps its the dreaded low fluid issue.
  15. Mar 8, 2016 at 7:51 AM
    #215
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    That would not surprise me. How many people would buy a used car knowing it was run with no oil or little oil? I suspect Not many.
    Transmission fluid is filled with machine so if 10 trucks are low, it means they all low on fluid, its just not everybody can feel it.
    So its safe to assume every 2016 Tacoma so far is running undefiled shredding transmission.
    [sarcasm]
    High revving engine spinning torque converter and transmission pump, in little oil.... I don't see what could go wrong here.
    [/sarcasm]
    :rofl:
  16. Mar 8, 2016 at 9:00 AM
    #216
    16TacomaSport
    Jon
    Pittsburgh PA
    this is how I was thinking about checking mine.
  17. Mar 8, 2016 at 9:05 AM
    #217
    splitbolt
    NW Arkansas
  18. Mar 8, 2016 at 9:13 AM
    #218
    16TacomaSport
    Jon
    Pittsburgh PA
    so D lit up at 95 on the pan and started blinking as over temp by 106 at the pan. So doing the check on the pan at say the 100degree mark seems like it should be in the range for the fluid check no?
    Why didnt toyota just make the straw long enough so that it could be checked at operating temp. not this stupid in between game crap
  19. Mar 8, 2016 at 9:18 AM
    #219
    splitbolt
    NW Arkansas
    I never got a blinking 'D'. I was able to get it done, quick.
    The post I linked said he had at least 5 minutes.
    At 100 degrees, I would think you're cutting into your check time a lot.
  20. Mar 8, 2016 at 9:19 AM
    #220
    16TacomaSport
    Jon
    Pittsburgh PA
    ok so starting the check at 95degrees
