2016 Transmission Update and Fluid Levels
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wheelie, Feb 22, 2016.
  1. Feb 29, 2016 at 1:20 PM
    #81
    gearcruncher
    Canadain bumper technician
    Easy to check ......Some dealerships are indicating a computer flash fixes the low fluid problem ??????o_O
    Find out for yourself at the link below
    Check to see if there are any Technical Service Bulletins available for your truck http://www.toyotaproblems.com/tsbs/Tacoma/
  2. Feb 29, 2016 at 1:26 PM
    #82
    BigWoods4x4
    BigWoods4x4 Active Member
    The Big Woods of Northern Wisconsin
    2016 Tacoma Limited Magnetic Gray Metallic 4x4 5ft Short Box
    According to your site there is nothing for a 2016 period. Ive got the slow engage but I don't know if this warrants another trip to the dealer. It seems a lot of,people say they're low on fluid. I'm getting the symptoms but without the diagnosis I was looking for.
    Shit.
  3. Feb 29, 2016 at 1:39 PM
    #83
    gearcruncher
    Unless you can find a better site for checking tsb,s ?
    Did you watch the technician check the fluid ?
    I am willing to bet your fluid is still low and this is coming from your explanation .
    Why not try practicing getting your fluid into temp mode ?
    Its all I can suggest after a dealer visit .
    I am not sure if every dealer is following the same check fluid procedure as there have been soo many discrepancies with the many reports coming in . Seems like Toyota is a little behind in keeping their technicians up to date .
    There are also discrepancies in the actual fluid filling procedure . Guys that have a thermostat . Are the technicians actually pinning the stat or not
    According to the actual Toyota procedure at the bottom of the poll , there is no mention of pinning the thermostat
    https://www.tacomaworld.com/threads...be-low-on-fluid-directly-from-factory.405642/
  4. Feb 29, 2016 at 1:44 PM
    #84
    oz90630
    oz90630 Active Member
    Oscar
    TrdAC
    Does anyone know the correct OBD2 PID for reading the trans fluid on a 2016 V6 model, AC60E.
    I've tried 2182 with the Torque app and it returns 0000.
    My trans was low a quart, but the symptoms have not gone away.
    So, I need to recheck.
    I suspect the check has to be done at full operating temperature, with the thermostat open to where fluid is circulating through out.
    But, then the issue is the check "straw" is too short.
    Probably something Toyota has to correct...
  5. Feb 29, 2016 at 1:46 PM
    #85
    BigWoods4x4
    What is your opinion on taking it to a valvoline? Would they know proper procedure? Would this void my warranty? As you can tell, Im hesitant to touch a ssingle bolt with a vehicle that has 500 milesmon it and is under warranty.
  6. Feb 29, 2016 at 1:47 PM
    #86
    baron55
    baron55 Well-Known Member
    2025 Tacoma TRD Sport 4X4
    Yep the TSB for the 4cylinder was back in September of 2015. Nothing out on the V6 yet.
  7. Feb 29, 2016 at 1:51 PM
    #87
    BigWoods4x4
  8. Feb 29, 2016 at 1:51 PM
    #88
    baron55
    One of two things, if they checked the AT fluid hot without the special tools in post #73, they indeed would come to the conclusion that the AT fluid was overfilled. If the did use the special tools, which most dealers don't seem to have, then they actually drained the fluid even lower.
    That is why most have to leave the trucks at the dealer to get the transmission temp down to 95-114 degrees F.
    Taking it to another oil change shop most likely will result in disaster.
  9. Feb 29, 2016 at 1:52 PM
    #89
    baron55
    How long was your truck in and how long did it take.?
  10. Feb 29, 2016 at 1:54 PM
    #90
    CanyonRunner
    CanyonRunner 100% PENETRATION
    Pacific Northwest
    2016 TRD 4X4 DCSB
    $$$ Money Pit $$$
    How could they check and say it was overfilled when after driving to the dealer and not sitting for hours to let properly cool, it would be "too hot" to properly check level. Hot expanded fluid would definitely run out the overflow in this case if not checked in the precise temp range. Sitting idling a totally cold engine does not take long to get to temp check stage, but once you are over it takes A LONG time to come back down to where you need to be.
    I don't believe they even checked it, and are just feeding you lines to STFU
  11. Feb 29, 2016 at 1:54 PM
    #91
    BigWoods4x4
    Two hours roughly
  12. Feb 29, 2016 at 1:56 PM
    #92
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    did you watch the video above your post? did the tech describe the process he did close to what the video showed? the guy in the video said common mistake is to check it too hot and the result it will seem to full.
  13. Feb 29, 2016 at 1:57 PM
    #93
    baron55
    Not true necessarily. Last year Toyota came out with a new procedure to check the fluid hot. Look at the video in #73. A vacuum is applied to the transmission through the fill port, then the check plug is removed (vacuum holds in the fluid) a new check plug is inserted that accounts for the higher temp fluid height. This would on take 10 to 15 minutes to do. But the procedure and tools came out middle of last year so many service centers aren't equipped yet
  14. Feb 29, 2016 at 1:58 PM
    #94
    baron55
    You know, guys at the factory probably say, no worries, the dealers will catch it at PDI.............
    gearcruncher likes this.
  15. Feb 29, 2016 at 2:05 PM
    #95
    gearcruncher
    Use the procedure at the bottom of the poll to check your fluid level . Its the most accurate that I know of for checking the level at home
    If you pin the thermostat open with a small screwdriver , you will essentially be checking the complete cooling system
  16. Feb 29, 2016 at 2:05 PM
    #96
    eseckinger
    eseckinger Well-Known Member
    Eric
    2018 TRD Sport
    Just got mine back today. A quart low they said. VIN starts with 3. They kept it all day and said they checked it both hot and cold.
  17. Feb 29, 2016 at 2:07 PM
    #97
    baron55
    This is sounding more and more like the 1 quart low due to the tow package. I know it has been asked already, anyone have low fluid and no tow package?
  18. Feb 29, 2016 at 2:14 PM
    #98
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    It's been stated many times, there is no update for the automatic transmission software for the 3.5L regardless of how many times someone reports otherwise. If/when there is an update someone will be able to post a real reference instead of repeating the BS the dealership told them
    eseckinger likes this.
  19. Feb 29, 2016 at 2:53 PM
    #99
    BigWoods4x4
    I think Im leaning towards simply letting it be. Not to say that it's 100% without a doubt fine on fluid but at least now I have documentation that states this was an issue from the start. I would be lying if I said that I would be holding on to it past 5 years/60k. I just never hold on to vehicles that long. With (rumors) of a diesel and with the Pro coming out I think Ill still be under warranty when I sell.
  20. Feb 29, 2016 at 4:13 PM
    #100
    Taco Luvr
    Taco Luvr Well-Known Member
    2016 TRD 4X4 OR
    King Ext, TC UCA, 1.5 AAL, VTX Rogue SL, BFG KO2 285/75R16
    HA! Got truck back about 2 hours ago. What do ya know? Low tranny fluid! Topped it off. Yes, I have the tow package. Don't want to call it too soon, but it seems smoother so far. Could be my imagination though. I will be able to better assess after a few days of driving.
