2016 TRD auto 6 will not move in Drive or Reverse
Discussion in '3rd Gen. Tacomas (2016-2023)' started by heyphillip, Nov 12, 2017.
  1. Nov 12, 2017 at 7:20 AM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    Sticky rear brake drums? Have seen that issue from time to time on TW.
  2. Nov 12, 2017 at 7:39 AM
    kodaco771
    kodaco771 Well-Known Member
    So Cal
    2017 OR DCLB 4x4
    6112/5160's & Wheeler's Progressive 3AAL SCS SR8’s
    On my old truck after I would drive on wet roads then park it in sub freezing temps with the e brake engaged, it would freeze so I would have to warm the truck up for about 10 min then give it some gas to break the frozen seal.
    BillsSR5, RocTaco and mateo_roberto like this.
  3. Nov 12, 2017 at 8:37 AM
    mateo_roberto
    mateo_roberto Well-Known Member
    Mateo
    San Diego, CA
    1995.5 Tijuana Teal 4x4
    Stock
    I’ve also had my e-brake stick. If there’s no lights on the dash, my vote is to do exactly what the guy above me said.
    RocTaco likes this.
  4. Nov 12, 2017 at 8:42 AM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    I doubt that, I get in my truck, start it count to about 10 and drive off. In just over a mile the heat is starting to crank.
  5. Nov 12, 2017 at 8:57 AM
    medic2230
    Murph
    Bama! Roll Tide
    Stomp the top of each tire from the side with your foot. Should break it loose if they are stuck. When the brakes stick they won't let the truck move. Had to do this a few times with both Tacoma's. Especially after getting wet or washing it and it sat overnight. Most of the time you will hear the pop when they turn loose kicking them.
    boynoyce and kodaco771 like this.
  6. Nov 12, 2017 at 9:50 AM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    I agree with the frozen brakes. Especially if it is humid where you are. Have you tried putting it in 4X4?
  7. Nov 12, 2017 at 10:09 AM
    solscooter
    solscooter Sh!t Outta Luck
    Brian
    Minnesota
    2016 TRD OR DCSB 4x4
    Floor it. If one wheel is frozen it's a stuck drum. Happened to me. Broke out a hammer and hit the back side until it unfroze.
    In my instance I had driven in some dirt and muddy water. Washed the truck later and let it sit. The much piled up and froze one of the drums.
    Easy enough fix if you figure out which is stuck and have a hammer.
  8. Nov 12, 2017 at 10:38 AM
    Nick13
    Nick13 Well-Known Member
    Dominic
    2017 sr
    Did it even feel like trans engaged when you shifted? You need to at least feel that before I would be thinking brake issue. See if the rpm drops any when you shift from park to drive and rev.
  9. Nov 13, 2017 at 8:09 AM
    heyphillip
    heyphillip [OP] Well-Known Member
    DARRYL
    OK guys here is an UPDATE on my truck.Got home from work Sunday night at 11pm. I have auto start for both my cars so I started the Tacoma from the house.Waited about 12 minutes to go out and see if the truck would move and it did I drove it a couple of miles and it's running as normal.So I don't know what caused the truck not moving in drive Saturday morning.
    jake72, Spare Parts and RangerComa like this.
  10. Nov 13, 2017 at 8:10 AM
    Herniator
    Edmonton
    I still think it was the brakes. Have seen that happen before.
    Clay7160 and medic2230 like this.
  11. Nov 13, 2017 at 8:12 AM
    heyphillip
    DARRYL
    Do you mean they may have been stuck frozen because it was 23 degrees ?Oh also I forgot on Friday I ran the truck through the car wash but I don't think that would have anything to do with the truck not moving the morning after
  12. Nov 13, 2017 at 8:14 AM
    medic2230
    Murph
    Bama! Roll Tide
    Moisture in them. Next time try the stomping the top of the tire from the side. You'll go immediately then. Usually always the rear end holding it like we said earlier.
  13. Nov 13, 2017 at 8:17 AM
    Herniator
    Edmonton
    Thats why I mentioned if it was humid outside. When you parked the truck some moisture might have gotten into the brakes then froze. I have had my brakes grab for a bit and kind of make a thud sound when I drove away. The sound was the brakes unsticking.
    BillsSR5 and medic2230 like this.
  14. Nov 13, 2017 at 9:04 AM
    heyphillip
    DARRYL
    I washed the truck the day before(Friday) went through a full service car wash
  15. Nov 13, 2017 at 9:07 AM
    #35
    Herniator
    Edmonton
    That was probably the reason.
  16. Nov 13, 2017 at 9:09 AM
    #36
    eon_blue
    Azusa, CA
    That's what the guys are saying. You washed the truck the day before, parked it at home with moisture still in the brakes and the cold weather that night cause that moisture to freeze and the brakes to stick. They probably unfroze not long after you tried starting it on Saturday morning if the weather warmed up a bit. Not uncommon in cold climates.
    Herniator likes this.
  17. Nov 13, 2017 at 9:15 AM
    #37
    Dawnpatrol
    Dawnpatrol Well-Known Member
    PNW
    As a general rule which I'm sure most of you folks do, I never apply my safety brake when on the level at a ski resort or anywhere it's going to dip below freezing. I'd rather block my wheels for safety sake than deal with frozen drums. Glad to hear OP that your problem is resolved. :kona:
  18. Nov 13, 2017 at 9:20 AM
    #38
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    I guess frozen brakes is more noticeable in an auto. I’ve always used my parking brake in the winter as a habit from when I parked in a steep driveway but I’ve never had an issue just giving it some gas to break free (manual).
  19. Nov 13, 2017 at 9:42 AM
    #39
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Drum brakes have a lot of surface area. Moisture (even a small amount) between the shoes and drum will really make them stick like glue until warmed or popped loose.
    As medic2230 mentioned several times above, just give your rear tires a good kick along the top edge to make the rim torque the drum a tad.
    Since the shoes are basically vertical in relation to the drum, you will get all the leverage you need to break the leading edge of each shoe free at their top edge when the drum is shocked.
  20. Nov 13, 2017 at 10:16 AM
    #40
    gator2764
    gator2764 Well-Known Member
    Mid Ga
    2016 TRD DCLB 4X
    Washed mine without driving it around and the brakes were froze the next day. Would not even budge in reverse or drive. I couldn't even feel it move a mm. Sounded rather sick when it broke loose but all is fine now.
    remgu2000 likes this.
