2016+ URD Y-Pipe and Cat Back Exhaust
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rat107, Jan 2, 2017.
  1. Jan 2, 2017 at 10:10 PM
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    21 Ram TRX Sold 2015 White DCSB Offroad
    Supercharger Hybrid audio stage 3 and stage 2 rear with 2 image Dynamics IDQ10's and alpine amps Bilstein 5100 with OME 887 Dakars and Icon 2.0 in the rear URD SPEC U Headers URD Y Pipe Borla muffler 18" Magnaflow Resonator Morimoto fogs
    You still have the primary cats it's a little louder but it really depends more on your muffler choice
  2. Jan 2, 2017 at 10:35 PM
    erok81
    erok81 Well-Known Member
    Imposter
    I come from an import car back ground.
    Turbo cars and no cats are perfect since the turbo can reduce the noise. Plus they sound really good with straight 3-4" exhaust.
    The only no cat experience I have is seeing hondas at the track. After a few of those my ears would start to bleed. :rofl:
    Actually I had a 1 ton jeep with a 350 and no cats. That was painful on trips. But like you said...you still have the the front cats. So maybe not too bad. And it's an easy swap for inspection time.
    The last thing I'd be worried about is the secondary o2 sensors. I know on all other cars I've had when you remove the cats getting the rear o2's to work without software is a huge pain.
  3. Jan 2, 2017 at 10:37 PM
    TacoJova
    Central Oregon
    Well the thing is on Tacoma it goes 02 Cat 02 and then cat so the last set of cats doesn't get monitored so no CEL
    Scott4032, auskip07 and Trdboi like this.
  4. Jan 2, 2017 at 10:39 PM
    TacoJova
    Central Oregon
    I have this Y Pipe on my second gen so unless they changed it for the third gen it should be the same
    dYL0n likes this.
  5. Jan 2, 2017 at 10:51 PM
    erok81
    Imposter
    Nice! That's works perfect then. :thumbsup:
    How's the sound? I'm partly worried on 400-500 miles drives how bad it'll be. With my cat back and tires i have trouble hearing the passenger sometimes. :rofl:
  6. Jan 2, 2017 at 10:55 PM
    TacoJova
    Central Oregon
    The drone is the same as before when I only had my borla the bigger difference is at wot. It really adds character to the sound though before it really sounded bleh now it actually sounds nice
  7. Jan 2, 2017 at 10:56 PM
    TacoJova
    Central Oregon
    I've done a couple 5-6k road trips and honestly the tire roar will piss you off more
    llibrm likes this.
  8. Jan 2, 2017 at 11:03 PM
    erok81
    Imposter
    Thanks man! Now I'm going to be 500 bucks poorer!
  9. Jan 3, 2017 at 4:50 AM
    Haany4x4
    Haany4x4 Well-Known Member
    Calgary, Canada
    2016 Blue TRD Sport 4x4
    Would you loose low end torque with the rear cats gone do too loss of backpreasure?
  10. Jan 3, 2017 at 9:00 AM
    erok81
    Imposter
    I heard back from them. This gets rid of the rear cats.
    dYL0n likes this.
  11. Jan 3, 2017 at 9:50 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    They said it's the same. So it removes cats? Throw any faults?
  12. Jan 3, 2017 at 10:01 AM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    I'm surprised URD says that it doesn't. In my experience, O2 simulators are required but according to URD's product description, none are needed.
  13. Jan 3, 2017 at 10:16 AM
    TacoJova
    Central Oregon
    No the second set of cats are not monitored
    Scott4032 likes this.
  14. Jan 3, 2017 at 10:17 AM
    TacoJova
    Central Oregon
    02 Sims are required when you take out the front set of cats
    llibrm likes this.
  15. Jan 3, 2017 at 10:22 AM
    #35
    Joe23
    So would it pass emissions?
  16. Jan 3, 2017 at 10:23 AM
    #36
    erok81
    Imposter
    In my state it will fail a visual.
  17. Jan 3, 2017 at 10:23 AM
    #37
    TacoJova
    Central Oregon
    Depends on if they have visual inspection
    It won't throw a CEL
  18. Jan 3, 2017 at 10:25 AM
    #38
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    Million dollar question
    Joe23[QUOTED] likes this.
  19. Jan 3, 2017 at 10:30 AM
    #39
    Joe23
    Here it's just computer. So probably fine.
    Next is does it ruin power from less back pressure.
  20. Jan 3, 2017 at 10:35 AM
    #40
    trianimal
    trianimal Certified
    TX
    2007 Tacoma TRD Off-Road DC 4x4 BSP
    TRD Supercharger, URD UCONN EMS, URD 2.85 pulley, URD 7th Injector, DTLT Headers, URD Y-Pipe, URD 02 Sensor, Walbro 255 fuel pump, TRD cat-back exhaust, TRD CAI, Donahoe Racing (pre-Icon) 2.5" dia. adj. front & rear resi shocks, All-Pro Offroad 3" rear leafs, All-Pro Offroad U-bolt flip kit, All Pro-Offroad Aluminum Skid Plate, Light Racing UCAs, Tom Woods 1-piece driveshaft, Shrockworks sliders, Avid light bar w/o lower tubes and a pair of Rigid Industries Dually LED Driving lights, Toytec diff drop, Color matched grille, Diaz Devil Horns, Redline hood struts, EZ Down tailgate, Undercover bed cover, 750 watts of sound (JVC, Morrel, Rockford-Fosgate & Infinity), BHLM w/ PIAA 4000K, FLM w/PIAA 4000K, LED interior lights. FN wheels with Toyo Open Country A/T II 285/75R 16 tires
    I've been running this setup for a while with no issues -
    TRD Supercharger, URD UCONN EMS, URD 2.85 pulley, URD 7th Injector, DTLT Headers, URD Y-Pipe, URD 02 Sensor, Walbro 255 fuel pump, TRD cat-back exhaust, TRD CAI.
    The truck passes inspections just fine. I also have a tune that takes the rev limiter to 6200 rpm and eliminates the speed limiter, but I rarely go over 110 mph on 285/75R-16 Toyos.
    Biscuits likes this.
