2017 AUX port question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by HolyReptar, Jan 24, 2018.
  1. Jan 24, 2018 at 11:56 AM
    HolyReptar
    HolyReptar [OP] Well-Known Member
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Some Bolt ones here and there
    I was wondering if anyone has moved or added a USB port that connects to the radio. I have my phone mounted above the dash and want to add charging and the ability to play music from it. Tired of having the cable running around the dash to the port at the bottom.
  2. Jan 24, 2018 at 11:59 AM
    Taco16LB
    Taco16LB Well-Known Member
    On my 16 OR the usb port on the dash next to the power outlet , is connected to the radio . there is a stereo jack port there also .
  3. Jan 24, 2018 at 12:00 PM
    HolyReptar
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    I want to find out if there is a way to access that port that is down there and move that port elsewhere, or have dual access from another point. AKA Tap it and run another connection to it so that I can run my phone/ipad from a mount up there and not have a 3ft cable running around my dash.
  4. Jan 24, 2018 at 12:04 PM
    Taco16LB
    You might try running a usb cable along the headliner down like has been done for hard wiring a dash cam . Search dash cam . I bought a 10 ' usb cable for my dash cam but did not install it yet.
  5. Jan 24, 2018 at 12:07 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    A couple things.
    The stock port is a stupid low amperage. I think it might be only 0.5A? Not enough to keep most any device happy. So IMHO, it is probably only good for an audio connection.
    I installed one of these:
    https://www.amazon.com/gp/product/B01FFL2E6Q/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
    I used the blank left side spot above the charging pad on my non-tech / non-prem Sport. It doesn't seem to put out a full 2.1A, but does slowly charge my phone while using navi and music.
    Getting an audio connection from an aux charger is probably not possible without an aftermarket head unit?
    Also, just throwing out a big recommendation for the Hondo Unholy Mount. I had a suction mount on top of the dash that didn't cut down visibility too much, but it was a big reach even with a 5in RAM arm. The Hondo mount is in the perfect spot and the USB cable is out of the way of everything.
  6. Jan 24, 2018 at 1:16 PM
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
  7. Jan 24, 2018 at 1:39 PM
    HolyReptar
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
  8. Jan 25, 2018 at 7:02 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Nice! My bad on the original assumption.
