2017 DC Sport throwing Check ABS System message
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ksjohnson09, Jun 19, 2017.
  1. Jun 19, 2017 at 6:07 PM
    ksjohnson09
    ksjohnson09 [OP] Member
    2017 TRD Sport DCLB
    Within the last few days my truck has popped up with an error 3 different times after I've started it. The message on the dash says "Check ABS System". The ABS light and Traction Control light come on. The issue that I'm having is that if I shut the truck off and restart it, the code is gone. It's only happened a handful of times and the dealership said they couldn't replicate the issue. Anyone else have this issue?
    Truck is 4x4 AT, if that helps.
  2. Jun 19, 2017 at 6:10 PM
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    Are you part of the CPS recall?
  3. Jun 19, 2017 at 6:11 PM
    ksjohnson09
    2017 TRD Sport DCLB
    Not according to my dealership. I haven't checked personally. I've been slacking.
  4. Jun 19, 2017 at 6:15 PM
    ksjohnson09
    2017 TRD Sport DCLB
    No open recalls on my VIN
  5. Jun 19, 2017 at 6:22 PM
    tacoflavoredkisses1
    I'm on my cell so searching is a bitch, but I want to say people had weird lights with the cps failure.
    Do you have a lift? Big tires?
    bulalo likes this.
  6. Jun 19, 2017 at 6:31 PM
    ksjohnson09
    2017 TRD Sport DCLB
    Nope. All stock.
  7. Jul 3, 2017 at 9:30 AM
    Quicksand Jesus
    Quicksand Jesus Well-Known Member
    Derrick
    Littleton, Colorado
    2002 Toyota Tacoma TRD DCSB
    3" OME Lift with Dakar Leaf Pack - SPC Upper Control Arms - Trail Gear Weld On Rock Sliders - 285/70/16 BFG KO 2's - Fuel Matt Black Anza Wheels - Bushwhacker Cut In Fender Flairs- Deck Plate Mod - Paranoid Fab Scangage Mount - URD Throttle Body Gasket - Flowmaster American Thunder Cat Back Exhaust - Compustar Security, Remote Start, Keyless Entry.
    I have the same thing happening to to my truck as well. Some times I have to turn it off and on 4 time for the ABS light to go off. Ill have to stop off at the dealer next time it happens and I will report back with any Info.
  8. Jul 3, 2017 at 10:16 AM
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    If the dealer can't reproduce it, film it next time you start the truck and it happens. I assume the light stays on until you turn the truck off? Film the light staying on until you turn the truck off and start it up again.
  9. Feb 25, 2018 at 1:14 PM
    sxe4533
    sxe4533 Well-Known Member
    Edmond, OK
    2016 TRDORDCSBAT
    2015 TRD PRO suspension
    I had that come up once about 2k miles ago I asked the dealer to check it yesterday they said to not worry about it and the truck it still learning itself!!!!!! My truck is 2 1/2 years old and 55k miles!
  10. Oct 13, 2021 at 9:01 PM
    alasko
    alasko Member
    Humboldt
    2017 TRD off-road 4 door long bed
    My 2017 Tacoma put up the warning signal for "check ABS system" with the two lights on the dash. Did anyone find a resolution to this problem because I couldn't find one from my research, or is Tacoma not wanting to recall because too many trucks would need to be?
  11. Oct 13, 2021 at 9:12 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Are they disabled? Sometimes the wheel sensors may send a bad signal or maybe a wire was stretched or damaged.
  12. Oct 13, 2021 at 11:16 PM
    alasko
    alasko Member
    Humboldt
    They shouldn't be disabled. It happened one time before, and happened yesterday night and came on today as well. My truck is stock. Someone did back into my front right side tire and caused some damage. I don't it's that when I have read so many people have had this problem. My truck has 85,000 miles.
  13. Oct 13, 2021 at 11:24 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Do u have a power / fuse tray on the driver's side?
  14. Oct 14, 2021 at 12:37 AM
    spamy
    spamy Truck guy
    NorCal
    2017 Tacoma Sport 4x4
    Mine had popped up the traction control alarm one time when I let the truck sit and idle for like 15 min. I cant remember if it did the abs too or not.
    I had to clear it through obd and it never came back.
    Also 2017 Sport, mines a DCSB.
  15. Oct 24, 2023 at 5:40 PM
    alasko
    alasko Member
    Humboldt
    So, after a few years of dealing with this problem, I took it to the dealership, I bought it at, and we got the codes, which was speed sensor and circuit break in harness. They found out that grease from the bearing going bad was getting into the connector of the ABS and possibly kicking the light and those codes. They replaced the bearing and cleaned the connector. Now I just have to wait for it to rain again and see if it makes it go off again because it would only come on when it rains. If it doesn’t, then we know that this fixed the problem.
    Canadian Caber likes this.
  16. Oct 24, 2023 at 5:45 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Thanks for the update. Hopefully that resolves your issue.
    alasko[QUOTED] likes this.
  17. Oct 24, 2023 at 5:59 PM
    Bill400
    Bill400 Well-Known Member
    Bill
    2023/7170 (SR5, V6, DBL Cab, 4X2) Red, Advanced Tech Pkg
    OEM BSM/CTA retrofit complete
    Replacing the connector would make sense. If the connector leaked, replacing or lubricating the seal would be indicated.
    As a minimum, lubricating the seal would be a good idea.
  18. Nov 2, 2023 at 2:57 PM
    alasko
    alasko Member
    Humboldt
    Well, I hate to inform that it did not solve this problem for me and the ABS and traction control light came back on as soon as it rained.
