2017 DCSB is SAGGING and I NEED HELP
Discussion in '3rd Gen. Tacomas (2016-2023)' started by HAUBY123, Jan 12, 2018.
  1. Jan 12, 2018 at 11:51 AM
    HAUBY123
    HAUBY123 [OP] Member
    2017 TACOMA OFF-ROAD 4WD
    I have a 2017 DCSB that I have added a Leer 100XR and a "Decked" Storage Drawer Unit to the Bed. I swear it looks like the back end has settled about an 1-1/2" and the front and rear are now level.
    I have not even loaded my tools into the "Decked" Unit yet. I know I will have to get an AAL or Sumo Springs? I want to add camping gear and a RTT to the back too.
    Whats your suggestions or recommendations? What will work? I don't want a suspension lift.
  2. Jan 12, 2018 at 12:03 PM
    Markc1024
    Markc1024 Well-Known Member
    The Sumo springs work well. That should limit the squat without adding a lift. I've done that along with the Icon progressive AAL.
  3. Jan 12, 2018 at 12:09 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    I'm no expert, but the Taco springs are weak....if you are going to carry all that weight, you'll have to do something for sure.
    In my 2006, I took it to a spring place and they added an extra leaf and "straightened" the OEM's.... Truck drove way better after that; however, I did not carry a heavy load all the time.
    Depending on the weight you plan to carry all the time, you night have to replace the springs with a new pkg. and maybe add air bags..?? I had air bags back in '74, in my Chebby..... worked great....
    When I needed the extra, I just added air from an on-board tank.... Today I'd do an on-board compressor....!
    OnHartung'sRoad and Captqc like this.
  4. Jan 12, 2018 at 12:17 PM
    Mountain
    Mountain Well-Known Member
    Revelstoke BC
    15 Acess Cab TRD
    Wheelers 5 leaf HD pack maybe? Or something similar? I don’t know much about it other than their description on the website. It says there is some lift but doesn’t say how much. Might be better in the long run than the AAL, just more $$$. But that’s a lot of extra weight after the tent and all your gear is in there.
    over60 likes this.
  5. Jan 12, 2018 at 12:31 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    If your leaving that stuff on for good, I would go add a leaf or better leaf springs
    OnHartung'sRoad and over60 like this.
  6. Jan 12, 2018 at 12:42 PM
    Mountain
    Revelstoke BC
    15 Acess Cab TRD
  7. Jan 12, 2018 at 12:45 PM
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    Dakar heavys ftw
    DesertTaco4x4 and jmaack like this.
  8. Jan 12, 2018 at 12:52 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Yup, a plug but an honest one: I added a single leaf and it fixed my loading sag, but call Headstrong off-road for your best answer to your specific needs.
    over60 likes this.
  9. Jan 12, 2018 at 12:58 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Go with what Over60 said and go with air bags, that way you can easily adjust for various loads.
    OnHartung'sRoad likes this.
  10. Jan 12, 2018 at 1:08 PM
    OnHartung'sRoad
    A good suggestion but airbags that bolt on both ends limit your differential movement, particularly when off-road flexing, so you have to consider that too -I tow a trailer but also off-road, so I went with a Dakar set instead . Really suggest talking with Marie at Headstrong off-road about it.
  11. Jan 12, 2018 at 1:12 PM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    I have an ARE CXHD on My 2017 with a rhinorack on top of it. It weighs every bit of 250lbs. With a few things in the back my springs were almost bottomed out and It bounced like a trampoline. I installed a $200 "open box special" firestone airbag kit back there (pita). Didn't want to screw with a new spring pack until i'm at least past My 25k mile warranty period. The air bags do a good job and the ride/stance is back to normal with about 25psi.
    eurowner and OnHartung'sRoad like this.
  12. Jan 12, 2018 at 1:18 PM
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    sumo springs work well, but thats a lot of weight. i have a cap, prinsu and custom drawers at around 350 lbs. you may want a custom leaf pack from alcan or something.
  13. Jan 12, 2018 at 1:28 PM
    over60
    Muskoka, Ontario
    I agree...if it's permanent weight...then you need a permanent fix...!
    Beefier springs for sure..... If you add/remove a lot of weight.... Consider air bags..!!
    My 3.5 cents CDN... hehe
  14. Jan 12, 2018 at 1:58 PM
    HAUBY123
    I may have 150# worth of tools, 200# of camping gear and 145# for the RTT. The tent I plan to leave on as well as the tools in the "decked" unit. I won't off road except occasionally a gravel road during my Alaska and Canada Trip over a 60 day period. I'm getting the idea I may have re-work the spring pack and do Air Bags?
  15. Jan 12, 2018 at 2:00 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    YOU DEFINITELY NEED A HEAVY DUTY LEAF PACK
    over60 and OnHartung'sRoad like this.
  16. Jan 12, 2018 at 2:01 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    sorry not yelling, but that is a ton of weight, almost literally
  17. Jan 12, 2018 at 2:03 PM
    TexAggie
    TexAggie Well-Known Member
    Eric
    Houston, TX
    OME Lift
    If you're going to change the rear springs I recommend replacing the entire suspension and lifting all at the same time. I've got OME on mine and the Dakars are way better and flex far less.
  18. Jan 12, 2018 at 2:04 PM
    HAUBY123
    Thanks for the kind words of advice.
  19. Jan 12, 2018 at 2:04 PM
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    Hey its not 3.5 cents now... its down to 3.0 cents :D:canada:
    over60[QUOTED] likes this.
  20. Jan 12, 2018 at 2:11 PM
    HAUBY123
    Nice Truck BTW Dozzy4212!
