2017 E-Locker
Discussion in '3rd Gen. Tacomas (2016-2023)' started by traumahawk, Jan 4, 2019.
  1. Jan 4, 2019 at 12:25 PM
    traumahawk
    traumahawk [OP] Well-Known Member
    2017 Tacoma TRD Sport manual, quad cab, short bed
    Icon stage 4 +3in with spring pack, OV Tuned, total chaos UCAs, Victory 4x4 strike front and rear bumper, Warn 9.5ti winch, full CBI underbody armor, AP kick out sliders, softtopper canopy, method wheels, BFG AT KO2, leather seat kit, Safari snorkel, 4.88 gears, MBRP cat back exhaust.
    Awesome, this looks like a good starting point. I kinda want to see how well the andrino board works and bench test that
  2. Jan 4, 2019 at 12:32 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Sounds good.
    Read over the beginning of that linked thread, to get an idea of the duty cycles, etc. I assume use the ardiuno to switch a transistor, to do the heavy lifting?
  3. Jan 4, 2019 at 12:39 PM
    traumahawk
    Correct, use the board to mimic the duty cycles with a transistor inline.
    MOC221_ likes this.
  4. Jan 5, 2019 at 9:44 AM
    traumahawk
    After spending the night researching it, I think I have an idea of where to go. I believe I will need to use two arduino boards. The first will have three states : PWM 3.7A @ 77%, PWM 3.7A @ 50%, and null amperage all controlled from an a constant on/off switch in the factory location. https://www.arduino.cc/en/tutorial/PWM I will use these signals to power the a diode grounded circuit through the + and - side of the locker. If the PWM is high enough frequency, it should be able to directly power an LED, but if not, I will use a secondary arduino to read each state of the first and power the locked indicator lights.
    BigWhiteTRD, do you still have the techstream readouts that show what frequency the ECU PWM is at?
    AKGSD likes this.
  5. Jan 5, 2019 at 9:48 AM
    traumahawk
    Drive train specialties has new E-locker take outs that are fairly cheap. Gear housing is the same in all the TRD models, I will just need to remove the plugs on the top of the housing for wiring.
  6. Jan 5, 2019 at 11:28 AM
    traumahawk
    Okay, I have the board laid out. It can all be done on one board which is nice. So here goes my idea: The board will have a switched input that will send a PWM signal to a 3.4A 12v mosfet at 77% cycle for the first 5 seconds, then switch to 50% cycle for maintenance, off will be no signal. The second function will be ohm monitoring on the locker, I will have to establish a baseline once it is on the bench, but then I will have a safety function that will turn off the PWM signal if resistance increases over a certain threshold. The third function will be an tri-LED, red for over limit resistance, yellow for the 5 second 77% locking function and green for 50% locked signal. Let me know what you all think. I am currently working on the code.
    MOC221_ likes this.
  7. Jan 5, 2019 at 1:13 PM
    Pyrotech
    Pyrotech Well-Known Member
    when I got my Yellow fever shot it made me sick as a dog for a about a day or so
  8. Jan 5, 2019 at 1:18 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
  9. Jan 5, 2019 at 2:18 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    And that's why I bought an O.R. :anonymous:
  10. Jan 5, 2019 at 5:22 PM
    traumahawk
    Yeah, but you don't get 2 wheel drive locked donuts and 75mph in the desert!
    Epic3rdgen, COTacoTime, AKGSD and 3 others like this.
  11. Jan 5, 2019 at 5:55 PM
    BigWhiteTRD
    Ted
    I dont THINK the 5 sec is a good idea. It can be a pain to get it to lock sometimes (in my opinion) and 5 seconds isnt a lot of time to get it lined up unless you are doing it right. However, you can always cycle it again, or dont activate until you are doing S turns, etc.
    I would think you could use the lock feedback to tell the board which program to run (77% or 50% based on the grounded pin or no). But I have only played with those boards once, so not an expert...
    I would do led red for power to the lock circuit but the lock feedback shows unlocked, green for power to the lock circuit and lock feedback shows locked. Maybe green for feedback shows locked, power or no power...
    I wouldnt personally bother with any resistance monitoring. I would personally just fuse or breaker the power to the coil...
  12. Jan 9, 2019 at 9:09 AM
    traumahawk
    Before I build the full board, I am going to try BigWhiteTRD's idea of a resistor in line with a flyback diode. The locker was just delivered and everything else should be here in the next few days. I will report back with some bench tests.
    AKGSD and SR-71A like this.
  13. Jan 9, 2019 at 9:22 AM
    bijick
    bijick such mods much want
    E
    Stl
    2013 MGM Singular Cabular Selectable
    OME 884’s ,Dakar hd’s, Jba uca, lce header, 4.88’s, Arb locker , j shift tcase-T4R, arb bumper, leer topper, 3500w inverter, mad wife, scratched paint, skid plates, snorkelerer, led flush mount reverse lights, etc..
    Love threads like these, thank you for doing cool things. Good luck!
  14. Jan 9, 2019 at 9:49 AM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    Would you have a link for them? Seems to be many with same/similar names.
  15. Jan 19, 2019 at 3:20 PM
    #35
    traumahawk
    Jowett[QUOTED] likes this.
  16. Jan 19, 2019 at 3:20 PM
    #36
    traumahawk
    Anyone have a suggestion on how high of an amperage resistor to use to get the power down to about 4 amps?
  17. Jan 19, 2019 at 3:41 PM
    #37
    Jowett
    Brian
    North Adams, MA
    Thank you for the link. Also, thank you for all the info... It's pushing me to build a 9.5" Tundra/200 Series Land Cruiser axle for my truck, rather than do the swap you are pioneering. Nice work!
  18. Jan 19, 2019 at 3:42 PM
    #38
    BigWhiteTRD
    Ted
    Try a 1.5 ohm resistor as a first shot. (That is best estimate based on coil resistance at rest, when locked it might be a bit low).
    I would go with a 1.5 ohm 100watt resistor. (2 pack about $10 on Amazon)
    Otherwise try a zero to 5 ohm potentiometer and get it dialed in manually on the bench. (only about $12 on amazon)... depending on how it goes you can then buy the right resistor.
  19. Jan 19, 2019 at 4:11 PM
    #39
    Dragracer_Art
    Dragracer_Art Tundra for the win
    GA
    2020 Tundra Crewmax 4x4
    Dumb question...
    Didnt the TRD Sport come with the 8.0" diff and the Offroad with the 8.75" ???
    Pretty sure I read that somewhere.
    I do appreciate you techno guys geeking out over a solution to this.
    Im too old school and if a PNP solution isnt created...most likely will just send 12v to the locker via toggle switch. :rofl:
  20. Jan 20, 2019 at 8:16 PM
    #40
    traumahawk
    The non TRD models came with a 8.0" rear end. Sport, Offroad, and Pro all are 8.75".
